You can replace lock actuators with the windows UP.
E39 DIYs done: Wipers, O2 sensors , MAF , Upper/Lower Intake Boots , FSU , ABS module fix , Power Steering Reservoir , Changed Rear Differential Oil , DISA , SAP, Vacuum lines , Radar Detector Hardwire , Fuel Filter , LED Angel Eyes , Headlight Adjusters--> [1],[2], [3] , Headlight Polishing, Punted: Fan Clutch/Tensioner/Pulleys , Oil cap O-rings , Window regulator ,Crumbling Cowl
Sorry to bring up a dead thread but I'm in a dead end don't know where to go. I've followed the DIY and replaced the 2 front actuator(OEM ) I haven't assembled it yet cuz they are not responding. Already checked and rechecked all the connection and all seems good but the darn locks just won't give a sign of working
01 E39 525i - 172850km
02 E53 4.6is - 148000km
03 E46 M3 - 42853 Miles
09 Pajero - 149000km( the traveller)
You either missed a plug connection (the smaller one to the lock mechanism may be hidden from view, the big one to the actuator well, you wouldn't miss that. Also check your fuses. If you are trying to test the actuators before re-sealing the door, I hope you made sure to re-connect the airbag before all that, otherwise you'll have an SRS fault light on once you're done.
Check out the first post in this thread, step 10 in particular. Could be your issue:
http://forums.bimmerforums.com/forum...or-Replacement
<== Steptronic Sealbeach740
2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
Everything checked no blown up fuses, tabs lined up and connections all made correctly, can't figure it out wtf is wrong
The thing is only the 2 front sensors are not working, the back one works flawless(thank god)
I finally tackled this job after months of procrastination. All of the door locks started functioning normally for a few months and then suddenly, my rear passenger door would not lock. I have no idea how many times I went to the store and locked the car, only to have the rear door remain unlocked. I only noticed it by chance, and then checked it every time thereafter. It would fail to lock about half the time. I followed the instructions posted on this thread (thanks Fudman and OnTheFence) and just completed the job about an hour ago. Took me about 3 hours and it was a bit of a pain in the rear. It's all buttoned back up and everything works as it should with one small issue. Even though it works fine, the inside door handle has a bit of play in it that it didn't have before. My guess is that when I moved the yellow cable clip from the square retainer hole, the yellow plastic clip pretty much disintegrated and I was unable to secure it properly like it had been before I disconnected it. I'm not really concerned with this as it still works and the rear seats are rarely used, but it does bug me a bit as my car has been pristine since i bought it new. If anyone has any tips on getting the slack out of the door handle I'd appreciate it.
2000 528i sport
EMP Stewart water pump
Dice iPod adapter
Alpine amplifiers
MB Quart speakers
MTX BGE12 subwoofer
AudioControl EQL equalizer
Why don't you order another yellow plastic clip?
Or somehow ziptie the cable to that little square opening?
Opening the door back up will only take 30 mins. this time.
I had this happen to me, I think the issue is that you didn't reconnect the cable for the door handle right. The cable thing has a ball or hook or whatever on the end that you need to drop in place, but that thing also grabs onto the plastic sheath over the cable to keep it tight. I know you have the ball or hook thing connected, your door handle wouldn't work otherwise, but if you look close where it's connected, you'll see that the sheath pushes into the end thing too. It's hard to describe, but you'll see it if you pull the door card.
If I remember correctly, the yellow plastic lip was part of the cable itself, not a separate part. Now that you mention the zip tie, I can't believe I didn't think of that.
I wish I would have taken pics during this job. I did not disconnect the cable from the door handle though.
2000 528i sport
Dice iPod adapter
Alpine amplifiers
MB Quart speakers
MTX BGE12 subwoofer
Great DIY Thanks! Still kind of a PITA though in general... haha thanks though for the writeup
E90 335i
On3 Performance top mount single turbo kit, Precision 6466 Turbo, ECS Tuning charge pipe, 7in FMIC, JB4 w/ MHD backend flash, Stage 3 fuel pump, Port injection, E85, some wheels that came w the car but are thick
E39 540i (SOLD)
6 spd swap, "Almost Nardo" Vinyl Wrap, JB Racing LTW flywheel, M5 clutch & control, BC Racingcoilovers, cat back straight pipe, E60 SSK, ZHP shift knob, hard wired aux, Style 32 17", BFG G-force Sport Comp-2 tires, shadow-line trim, reenforced differential bushing, ATE Type 200, Hawk HP Plus pads, intake res delete, 10W40 M1, trans fill 50/50 Redline MT-90 & 75w90NS, solid shifter carrier bushing, pixel fix, red needles
Many thanks! Mine had just gone out a couple weeks ago.
05 330i Alpine White
Past:
02 330i Titanium Silver
R56 MCS
00 540i6
Help. I am doing the actuator on the front passenger side on a 2001 M5. I have this apart right now. I am testing to assure locking function before reassembly. now NONE of the locks work if I use the central lock button on the console.
They DO work with the remote. This includes the one that I replaced. Seems to function as it is supposed to with the remote (up and down).
I have assured that the tabs in step 10 are aligned. I have checked the fuses. I have the lock in the full closed position to simulate door closed. The large connector is attached (there is no other electrical connector for the actuator on the PS door). I have even connected the airbag, the window switch and even the speaker.
Battery was disconnected for dis-assembly and reconnected for test.
Why is there NO lock function on any doors now from the central lock switch in the console ? HELP.
EDIT / CLOSURE: Since everything worked with the remote, I just went ahead and put it all back together. Everything works. Don't know what the deal was with it apart.....
Thanks to those who compiled this info. The rear doors on my 2002 Touring started to not lock or unlock on the first press a couple of months ago, this and other info helped me find the cause quickly (actuators) and replace them. The main hassle with this job was getting the door trims off, particularly in a Touring with the sun shades. The rest was quite simple and easy and doors now lock and unlock perfectly.
Cheers
Uber
Checked the 3 fuses of the central door lock switch near the gear shift lever and they seem to be good. If the button does nothing, what might be wrong? The doors lock and unlock via FOB normally, however. Thanks.
Thank you to everyone that contributed to this thread. Made what would have been a day to figure out how to disassemble the assembly into a two hour job. And big plus, my key fob works perfectly again. I had a replacement battery ready to go not realizing the problem was the actuator. No idea why the two would be linked in any way.
Hello! Great write up. It has been very useful.
After the initial install my door lock on the driver side is not going up and down.
It does not sound like power is even getting to the actuator. The window control panel on the drivers side door work only for the driver window.
The door lock switch in the center console works for all doors except the drivers side door.
Any thoughts on how I can trouble shoot my drivers side door lock?
It feels like everything was done correctly. (but obviously not)
Thanks again for the great write-up! ejj in Colorado
