My e30 vert build http://forums.bimmerforums.com/forum....php?t=1899641
Nothing But Bass: E30 Bass
I have money, I just want to use yours.
Got the interior kit from Katzkin and got the seats done. The kit was really easy to install. Deansbimmer over on E30tech made an awesome tutorial with alot of pictures.
Untitled by E30Bass, on Flickr
Black wrapped with a red insert.
So many pieces.
Front seats done.
Rear seat done.
Rear seat in car.
Full interior done.
Interior is 100% done now. Exterior only needs to have the rocker trim pieces put on. Then comes the mechanical work, which includes replacing the clutch, changing the valve cover, and replacing the fuel injectors.
Damn. Nice work man! Looking forward to seeing an extensive photo set.
e30 Vert project
"The two loudest sounds a gun owner hears is a bang when he expects a click and a click when he expects a bang"
Recently heard - "The shear number of people who have made me wish there was a hell for them to rot in has forced me to re-examine my atheist beliefs."
I got around to swapping the stock injectors with M50 injectors, changed the valve cover to my painted one, and reinstalled the strut brace.
Nice addition of color to the engine bay.
DSCF0167 by E30Bass, on Flickr
Decided I needed a photo to frame on my wall.
DSCF0164 by E30Bass, on Flickr
If anyone is interested, I will paint the old valve cover to sell. I also will have the old wheels and tires, and the full metal bumper setup.
FUUUUUUUUUUUUUUU.. such a nice build man.. good lord.. my vert aspires to be like that..lol i am doing things in the opposite order of you i believe..all my engine and suspension work will be 1st..and then the paint job will be next winter/spring i just cant figure what color i want to paint it..lol
I do have a question on the prep work for your paint job.. what products did you use and was it all by yourself or did you have help?..also the color sanding.. how did that go? (specifics..) the only reason i ask if the fact that i have seen a ton of people say the paint job is all in the prep work..
"You can wake up tomorrow and the person you love can and will love somebody else...but a 100 dollar bill is still a 100 dollar bill"
The prep work is the most important part of any paint job. The surface has to near perfect for the paint to adhere properly. All that I needed to do since I was respraying the car the same color, was to take the clear coat off. For the areas that required filler, I had to go down to bare metal and then feather the filler so it was perfectly smooth. All I used was a DA sander with 80 grit to take the clear off, then 220 to smooth it down before primer. after the final coat of primer I used 400 to get it ready for color. My dad did the color sanding, I will get him to explain what his steps were.
Long time since an update. Today I replaced the selector shaft seal and installed the z3 shifter. The old seal was simple to take out and the new one went in without a hitch. The shifter was simple to swap out. The only issue came with the selector rod. Had to put a slight bend in it to clear the vibration dampener. Works like a champ and no clearance issues.
Old seal out
Old vs. New
New seal in
Old sponge vs. New sponge
Figured I would take a picture of my exhaust system. All one piece.
Everything else gets put back together tomorrow.
Just came across this thread. My 'vert aspires to be as well-cared for as yours. Awesome work!
--Chris
1992 325iC ... 3.25 LSD, Bilsteins, Borla. Otherwise stock.
Mein anderes Auto ist auch deutsch.
Beautiful job. just went through the whole thread. How much was it for the entire paint job, all materials included? Just curious because mine needs it bad (abusive PO with too many rustoleum cans)
Just the paint cost me about $1200 for the base and clear. It was $500 for the shop to spray it. All they had to do was spray the base and clear, no other labor for them. As far as other materials those totaled about $300-400. The bodywork took the most amount of time to do. A shop will kill on the labor cost do the bodywork. It was alot of work, but I really enjoyed doing it. I would love to do it again, not on my car though.
Wow, incredible job. This thread intrigued me!
Time to start my clutch job. Its gonna apart for a couple weeks so it is the perfect time to clean up the engine bay.
DSCF0390 by E30Bass, on Flickr
Took the front end off for easier access.
DSCF0391 by E30Bass, on Flickr
Bag and tag
DSCF0392 by E30Bass, on Flickr
Sad look but it has to get done.
DSCF0393 by E30Bass, on Flickr
DSCF0394 by E30Bass, on Flickr
Started bright and early this morning removing all necessary components.
DSCF0402 by E30Bass, on Flickr
So much room!
DSCF0405 by E30Bass, on Flickr
Not as much as I thought it would be.
DSCF0406 by E30Bass, on Flickr
DSCF0407 by E30Bass, on Flickr
Hopefully will pull the motor/trans tonight. If anyone is thinking of doing this all I have to say is label, label, label.
Finally got it out. Simple and easy to do. The next step is to clean everything thoroughly.
DSCF0408 by E30Bass, on Flickr
DSCF0409 by E30Bass, on Flickr
DSCF0410 by E30Bass, on Flickr
DSCF0411 by E30Bass, on Flickr
DSCF0412 by E30Bass, on Flickr
DSCF0413 by E30Bass, on Flickr
DSCF0415 by E30Bass, on Flickr
Time for cleaning and completely resealing the motor. Gaskets will be here tomorrow.
Can you please tell me what brand/type of paint you used on the valve cover? Does it need heat resistant paint? Thanks.
Been making some good progress. The motor is staring to take shape again.
Back from the machine shop and painted
Cylinders rehoned.
Crank reinstalled with new bearings.
Intermediate shaft reinstalled.
Pistons are in with new rings.
More work to be done tomorrow. Still waiting on parts from the dealership which should be there Thursday.
Alot of progress today. The head is fully assembled and the block is taking shape.
Clear coated the oil pan just because I love the look of aluminum.
A little valve lapping action going on.
It only about a minute of lapping to get it perfect.
Intake valves done.
Exhaust valves done.
New valve stem seals in. 11mm socket was a perfect fit.
All valve springs in.
Camshaft, rockers, and rocker arms in. Head is done.
Front crank and intermediate shaft seals on.
Getting the rest of my parts from the dealer tomorrow. Then full steam ahead. The motor should be complete this weekend. One step closer to getting it back in the car.
Looking super nice. Great job. That is going to even more incredible when you get done with it.
Keep posting the progress!
e30 Vert project
