Followed Geoff guide, got a 65776900727 with 2.5 software from Ebay (a new one). It came off from an E39, I used it in my E38. Interestingly, no coding was needed. Once I put it in all errors cleared and the check light went off. Quite amazing!
Also, coding with BMW Scanner worked but not perfectly, although I could change the VIN it still showed E39. This was easily address by coding with NCS Expert (SP Coden writing), it has changed it to E38. Probably didnt matter much but since it's considering safety I rather did it properly.
What an amazing feeling driving without the checklight on! I also bought another module as a backup for $30, they are getting really cheap on Ebay. Compare that to the list price of $1300 https://www.ecstuning.com/b-genuine-...t/65776900727/
Spirit force, first thanks for posting. I think I also need to replace my AirBag Module on my 2000 E39 528i for F0 INTERNAL CONTROL UNIT FAULT. ALSO CODE 11 POWER SUPPLY. Only shows Airbag at start-up, then restart car light goes away. Replaced weak battery (needed one anyhow 8 yrs old) and did bypass for Occupancy sensor did not help. Tried clearing those codes but they always come back. So my feeling is the Airbag module is no good. Now my real question. If I pickup a used ebay one, same part number and version, and from the same model and yr as my car can it just be plug and play? If not, do you know if the Vin has to be coded into the replacement module? Did you have to send yours to a Airbag reset service that I've read about online? If so which one did you use? Thanks again
You should be able to reset and code the used airbag module with NCSExpert...
If you read the EEPROM and disassembled all the code that does the self test, then you could identify your specific failure. But, my guess is there’s a whole list of checks and the first one that fails does an early exit from the routine with an error. Folks who have poured over the DME code could probably infer what types of checks the self test does.
Need a DME or EGS update?
https://forum.e46fanatics.com/showthread.php?t=1081716
Coding 530i after AT->MT Swap
https://www.bimmerforums.com/forum/s...ter-AT-MT-Swap
