Results 1 to 23 of 23
Thread: quarter window shades repair clips
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Here some pics of the new and stronger repair clips I sent to Avec, can be used when the old ones are broken or separated from the triangle shade, use a scissor and cut the screen straight, bolt on the new clip, done.
    These pics are from the first series made, nowadays the bolts and screws are galvanized to match the color of the plastic clip, not in chrome shining.
    Available from now till stock lasts. Parts made on a CNC machine
    Zionsville, IN
    93 740i, 84 533i
    The clips Shogun sent work really well. Not only are they very secure, the allow for adjustment of the shade tension. If the spring wears out, the clip can be removed, the shade roller turned a completed revolution and the clip put back on - tensioned back to where they should be.
    DV8OR, I have a set remaining, although not quite the quality as the ones pictured above. Bookmark this thread and let me know down the road. I haven't even looked at them for a while. Too many other things going on.
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
    USA
    e34 540ia/e32 740il
    I received my pair of these clips from shogun, and they work great and fit perfectly on the shade. They're a perfect solution to the torn off clips on the corner sunshades. I was gonna try to find new shades but they're pretty difficult to come across, so this was good alternative.
    Mar 2011
    Vancouver, BC
    too many, see sig
    Shogun: thanks. Appreciated.
    Avec: yep, I found a spare set of shades in a 750 a guy south of Seattle was parting out. Drove 2.5h to go fetch it all.
    They're out there guys - watch your local CL and stuff for part outs; maybe you'll get lucky.
    Now if only I could find a leather upper dash...
    My Current Cars:
    E70
    2010 X5 4.8i Xdrive Spacegrau
    E90
    2008 M3 6MT Silverstone II
    E34 1992 M5 3.6 J-spec Calypso
    E34 1990 535/5 turbo Bronzit
    E32 1990 750iL Highline Delphin
    E30 1988 325i M54 swapped Schwartz Convertible
    No longer with me:
    E46 2001 330Ci Titanium Silver
    E32 1993 740iL Lazurblau
    E34 1992 525iT Kashmirbeige
    E34 1990 535/5 Cirrusblau - Former Miller Performance Stage 2 Test Mule Car
    E34 1989 525i Cirrusblau - the Slug
    E21 1981 320i w/ M20 swap Arktisblau
    E21 1979 320i Turmalingrun
    Oct 2008
    Brisbane, Australia
    E34 M5
    I'll take a pair of clips to Australia, Shogun!
    Oct 2014
    Rock Hill, SC
    93 & 94 740iL
    Received mine - thank you.
    Current Collection:
    1993 740iL - daily driver; 1994 740iL - project #1; 1994 740i - project #2
    1991 Buick Roadmaster Estate Wagon - beast of burden & tool/parts hauler
    Dec 2015
    Porto,Portugal
    325i 525i 730i V8
    Erich thank you for shipping them so fast !
    Dec 2014
    Spartanburg s.c.
    91m5
    Shogun received sun blind clips today, these things are sweet and well worth it.
    thanks again in advance Gmoney19
    Dec 2005
    Baltimore, MD
    81 Scirocco-92 750il
    I'm in for a set. I need the quarter window clips at the very least. If you have a repair kit for the tabs on the larger side shade I'd like those too. Also, if you know where I can find them, I need the frames for the rear quarter window as mine are broken.(Where they screw to the door window frame)
    Thanks!
    Jan 2005
    Japan
    The clips for the triangle sunshades are not available as single item from BMW, my ones are special made and available from me, better and stronger than the original ones and can also be added onto a broken shade as shown above.So with my clips defective triangle shades can be repaired instead of spending $200 for a new one, if still available at all. Clips price at cost $24 per piece, shipped by airmail, non registered. In case someone wants to have them by airmail, registered, add $5. Cheaper than a cpl. new triangle shade for $160, in case you would get one. Can sell either one piece or as a pair for both sides.When these are gone, no more new production
    Jan 2005
    Japan
    As there were many inquiries for these triangle repair clips and the original version made by CNC machine is NLA, here is the new cheaper version available made with a 3D printer, tested over 2 years with different materials to find out the best material mix which can stand extreme cold and heat +UV. Target was to make it cheaper with same function. This is a DIY kit, only the plastic material will be supplied by me = left + right side bracket + handle. Not included 2 screws + bolts (M2.5*6 fits perfect) + the wire/rod holding the handle, that has to be glued in or first use a soldering iron to melt the material around it + then add a bit of glue, see sample. Plus you have to make a angled hook , example see in my post # 1 or my drwg below.
    Because of 3D production instead of CNC machine production the price could be reduced drastically. A set for 2 triangle shades as shown in this pic consisting of totally 6 parts (not the part on top of the pic, that is an example how the wire is glued in) including shipping by airmail non registered $25.
    Limited qty available. Sample pic https://www.directupload.net/file/d/...jnw39z_jpg.htm
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    I just went to PM you to see if you still had any of these and found this new post! I'll take a set! In fact, can you PM me your PayPal and I'll pay you
    Jan 2005
    Japan
    thanks, all available ex stock, will send you a PM for Paypal details and I need by PM the shipping address.
    Jul 2011
    Austin, TX
    Quote Originally Posted by shogun View Post
    PM sent, money sent. Thanks - I'll post pics for everyone when I get these together!
    Jul 2011
    Austin, TX
    OK, so I've never actually seen one of these clips - every 5er or 7er I've ever been in had them already broken and gone.
    Could you send me a couple close up pictures of them assembled from a couple difference angles?
    So, I thought there was just one wire, but after looking at these pictures more closely it looks like there are 2 wires, right? One for the handle that is straight and one that is shaped like the drawing to clip into the holder? Hmm, maybe a small thin nail clipped on both ends would be a good pin for the handle.
    Jan 2005
    Japan
    see my post 1 where I posted assembled ones, 1 wire holds the handle and that is straight, the other rectangular wire is the one which holds the sunshade in the bracket when closed.
    Jul 2011
    Austin, TX
    I'm going to try this again - I got done and then lost it the first time.
    So first, the hardware.
    I bought a pair of RC10 T3 trucks for my son and I a couple years ago. The guy was getting out of the hobby and gave me two tool boxes, and both the original boxes the trucks came in full of spare parts. There was literally enough stuff to build a third complete truck.
    So I dug through this box and found some flat head screws that were short enough, and I also found that the standard nuts were exactly the right size for the countersunk nut cutouts in the tabs.
    I did have to cut a little material from the cutout on one of the holes, but the rest fit snugly when I used the screws to pull the nut down into the recess:
    These paperclips were the exact right size and I thought the gold would look a little more OEM than a normal chrome paper clip.
    Anyway, the 3D printing residue in the wire channels needed to be cut out.
    Also, I needed to clean out the residue from the holes for the hanger wire (you can see the difference in the two holes in the above image.
    I used my drill - but just to hold the drill bit. The 3D printing plastic is so soft I knew I couldn't actually use the drill, so I just turned it slowly by hand and kept checking it until it was the right depth.
    Jul 2011
    Austin, TX
    Once that was done, it was time to cut and bend the wires.
    Attachment 665619
    And this is how it should look when it's ready to bolt together on the shade:
    Attachment 665620
    I rolled the shade until it was making enough tension to pull itself back firmly, but not too tight when it was extended, and then I taped it to the housing and figured out where I wanted the tabs to clamp on the shade itself.
    I marked it and used pressure and a small allen wrench to make holes, and then I took the top plate of the tab (the one without the wire cutouts in it) and put the little screws through the top plate and the shade.
    I also trimmed the shade here instead of waiting until it was all together.
    Attachment 665621
    The pull tab should be on the inside of the car:
    Attachment 665622
    We're close - one more post...
    Finished:
    Attachment 665623
    Here are a couple more (navigating the 5 pic limit here)...
    The very last thing I did was take a sharpie and color the nuts black.
    That's it!
    I also replaced both a laptop screen and a phone screen that same night - talk about a productive night!
    I can't make the pictures work - I give up. At least they're not photobucket - you can click on them and look at them.
    Jan 2005
    Japan
    @Denis: 8 clip repair sets for 4 E32 shipped to Muelheim, Germany
    Jan 2005
    Japan
    @malakush: 2 clip repair sets for rear triangle shades shipped to Copenhagen, Denmark for E34
    Oct 2020
    Copenhagen Denmark
    1991 BMW e34 520i 24v
    Just installed my new handles made by Shogun himself! I am super happy someone made a repair kit for these fragile old blinds. Worked perfectly, and a fun and easy DIY project.
    Jan 2005
    Japan
    @Jason: 2 sets triangle clip repair sets are on the way to Claymont, DE
    Jan 2005
    Japan
    @erachner: 2 clip repair sets for your E32 will be shipped to Seattle, WA
  1. Rear Quarter Window Shade Fix
    By ComaInferno in forum 1995 - 2001 (E38)
    Last Post: 08-24-2017, 05:36 PM
  2. WTB E38 Right Rear Passenger Quarter Window Shade
    By jojos740 in forum BMW Parts Wanted
    Last Post: 10-06-2010, 10:02 PM
  3. E38 WTB: Drivers side rear quarter window shade.
    By JaxMustang50 in forum BMW Parts Wanted
    Last Post: 10-04-2010, 05:06 PM
  4. Wanted: rear quarter window shade, driver side
    By vida10 in forum 1996 - 2003 (E39)
    Last Post: 11-22-2009, 05:46 PM
  5. WTB: e39 Quarter window Shade
    By peakay in forum BMW Parts Wanted
    Last Post: 08-15-2008, 05:44 PM
