S52 Z3M coupe or roadster mufflers. $50 for all 3.
These were originally tan, then spray painted black for an E30 coupe. $25 for all.
This is a wheel, tire, rotor, brake pad, caliper combo from an E92 M3.
The tire isn't usable, nor is the rim. This combo isn't for use. It's for decoration only. It's most likely very unsafe and I don't recommend using it on your car.
I pieced it together to make as a table (it just needs the glass and a stand). I have lost motivation and it would be nice to clear out the garage a little bit. The rotor has been glazed so if it was exposed to the elements, it wouldn't rust.
$400.
245/40R18 93Y Bridgestone Potenza RE050A
$100
275/35R18 95Y Bridgestone Potenza RE050A
$150
Please shoot me a PM for discussion.
I'd be interested in items for my S52 Z3 M Roadster as trades as well.
i3 & Z3 M Coupe
100$ for one tire? ...
what diameter is the inlet on those mufflers?
Bump. Open to decent low balling.
The muffler at the bottom of the stack is no longer available. One (1) left side, one (1) right side available.
i3 & Z3 M Coupe
Bump.
i3 & Z3 M Coupe
Bump. All three of the mufflers are still available and same with the door cards.
i3 & Z3 M Coupe
