Noob here but I'm completely stumped. I just installed a new head unit-Sony BT 3000p. When I turn the head unit on the stock speakers sound horrible. Im not sure if Im missing something with the stock amp not being powered on, or if the power from the head unit is not reaching the speakers?
hahahahha E36 M3 does sound like crap....
Its because the higher wattage from your new deck is being amplified by your amp. The stock deck has no where near the same power output.
In order to get any kind of good audio from the E36 you need to bypass the stock amp and at the very least match the impeadance of the OE speakers, but it's probably better to replace them completely.
-'98 M3 Coupe
-'03 M3 Coupe
-'83 911 Coupe
-'05 911 Coupe
I went through my stock amp with my x794 and it went fine...
Question for you. Does you M3 have the HK system upgrade? Or is it just the normal amped one that comes with the M3?? If you have the HK system go buy this harness with the RCA's on it. Made by Metra 70-8591 This will help with your problem.
Hmmm... do you have the wire for the AMP turn on wired up right?
If the receiver signal isn't being sent to the amp, your sound will be pretty bad.
BMW CCA Member 186373 - Golden Gate Chapter
Former (e)Bombe Magazine Editor, "The Toy Box" product review writer | Current member of Team Jesus
Gone: 1995 E36 M3 Arctik Silber, 1996 E36 M3 Cosmos, 1991 E30 318is Cosmos
How do you bypass the stock amp?
[quote=SpeedDemon4x4;25083511]Question for you. Does you M3 have the HK system upgrade? Or is it just the normal amped one that comes with the M3?? If you have the HK system go buy this harness with the RCA's on it. Made by Metra 70-8591 This will help with your problem.
No I C33 setup, which is Alpine?
I think that may be the problem. How can I check to see if the wire for the AMP turn on is wired up? I had a hole in the wall stereo shop install in, never again.
+1Originally Posted by LuxoM3
Sorry I don't have the solution, I did what your trying to do but it's been awhile. Lol
What I'd suggest is pulling the deck and rewiring it yourself, that way you know what goes where. It's pretty simple with the right harness.
The previous owner hacked off the plug, so basically the stereo shop had to wire it without the plug. Do you know where I can find the diagram that labels each wire coming out of the car? There are a couple wires that aren't being used, maybe those could be the wire that powers the amp?
Do you happen to know where the amp fuse is located? I checked the ones on the car and they are fine, but I know there is one on the amp but cant find it.
I don't have the diagram offhand, but if you type e36 stereo diagram in Google images you'll find one. I've used it several times.
The previous owner hacked off the harness so I can't identify anything without that. Thanks for the help everyone. I still can't figure it out. I took it to another stereo shop and had a different stereo installed, same thing. Still sounds like the speakers are not getting enough power, or not plugged up right.
Are you 100% positive the speakers are in-phase? If the previous owner hacked the harness, it's pretty easy to switch the + & - on one or more speaker leads. If you pressed the "LOUD" button, or whatever the hell they call it these days, and turned the treble/bass up to +10 - that'll make a $1000 speaker set sound like hell.
So I guess my last resort is to bypass the factory amp? Any suggestions on how to bypass the factory amp and connect the rears directly to the aftermarket head unit?
Thanks for the info.
