Control arm bushings, at 100k your transmission might act up but you can just do a transmission service on your own and it'll drive like new. Windshield washer coolant leak is a common problem. And there was a recall on the mirrors because the motors that would allow them to go in with the push of the button would break, but i dont think the 06's had that problem. Not really any other major issues with these cars othe than the already mentioned stuff, like the air ride. But I haven't had issues with mine yet. Just look around. These require as much maintanence as any high performance bmw would. These are honestly great trucks. If your going to mod it, I recommend your first thing should be removing the center resonator and installing an x-pipe. It'll really let you hear that alpina V8! Good luck, hope to see some pictures!
Oil wise it says to use high performance bmw synthetic, but really any synthetic will work. 5w-30 or 10w-30 should be fine. These trucks do tend to eat oil, so do not be surprised if your oil light occasionally comes on.
Also the tire pressure monitors sometimes go bad and even the spare can cause the light to go on. If none of your tires are actually low, then just hold down the tpm button and if will go away.
When you get it, I recommend taking it to your mechanic so they can plug in a scanner unit and reset the adaptations on the car. This way, the car will learn your driving pattern as if it were new out of the factory.
-'12 X5 35d Deleted/Tuned
-'02 M5 LMB/LMB
PAST IN ORDER:
'03 530i/5, '98 540i/6, '98 540i/6, '99 M3/2/5, '98 540i/6, '03 330ci/5, '08 335xi/6 E92, '12 335xi/6 E92, '08 M5/6, '07 X5 4.8i, '03 X5 4.6is, '11 550xi, '10 X5 4.8i
