- Battery Dies
Battery Dies
I installed a Fosgate 200 Watt Amp with built in crossover to a 10 inch woofer in box. I took the + straight from the battery and used the + of stock Amp for the remote to the amp. I have a fuse between battery and amp +. Now the amp bumps really nice when the car but occassioanly when I try to start the car in the morning the battery will be dead. I have to get a jump start. I figured with the switch between the battery and amp + that if I turned it off the Amp would not suck in juice from the battery. What am I doing wrong? I disconnected my set up and all is fine now, no dead battery. I've tried this several diferent times and it's always the same thing, battery dead the next morning....The Amp doesn't have a problem in my other car, 300zx.?
Any advice?
Thanks gang!
- You may not post replies
- You may not edit your posts
Forum Rules
