i want to install 2005 X5 4.8IS on 2004 X5 4.4 (both N62 Engines)
can you advise the steps and compatibility issues (which functions will work)
thanks in advance
Try theese settings with NCS Expert on IKE:
OFFSET_GESAMTWEGSTRECKE grundcode_var ODOMETER OFFSET
DZM_OFFSET benziner TACHOMETER (RPM) OFFSET maybe m5 ?
ANZEIGE_M5 motorsport FUEL CONSUMPTION GAUGE / OIL TEMPERATURE GAUGE [SERIE_AG: FUEL CONSUMPTION, MOTORSPORT: OIL TEMPERATURE]
DZM_SKALA_ENDWERT 8000_u/min TACHOMETER (RPM) MAXIMUM VALUE
TACHO_OFFSET 300_km/h_m5 SPEEDOMETER OFFSET
TACHO_SKALA_ENDWERT 300_km/h_m5 Speedometer scale end value
TANK_ANZEIGEWINKEL kennlinie_02 FUEL GAUGE ANGLE
TACHO_OFFSET_KOMPL 300_km/h_m5 SPEEDOMETER OFFSET (COMPLEMENTARY)
TACHO_SKALA_ENDWERT_KOMPL 300_km/h_m5 SPEEDOMETER OFFSET (COMPLEMENTARY)
KUEHLMITTELTEMP_ANZEIGEWI kennlinie_01 Coolant temperature
SCALE_INFO_TACHO km SPEEDOMETER SCALE INFORMATION
hi guys
i want to put M5 cluster on my 2001 530 ms43
so i asked darren smith who has already done it. his page https://sites.google.com/a/netmgr.co...e39-m5-cluster
his answer was:
"The LEDs aren't really possible without considerable effort and external circuits but to get the oil temperature working just update your engine ecu to the latest firmware, the latest sends the temperature on the canbus. As you have an m43 ecu this will work fine, using winkfp, be careful though you can easily brick it."
For those who have the DSC light that comes up after a few miles, please note that since I have upgraded my OEM wheels from 17" to 18" I no longer get this.
It seems there is some setting maybe in the cluster or the DSC/ASC module related to wheels revolution and since the M5 never came up with 17" that might explain why this is working now.
So everything works now but the oil temperature still
Yeah I have been riding along with a flat tyre daily since the last 14 months. Like.
I have coded another car with 18" wheels and the guy never had the issue. I could not understand why. While many others have the issue. Now I know why. It is the wheel setup/coding for 17" if at all possible, somewhere that I need to figure out.
It's not the wheel size as much as the overall diameter of the tires. They need to be within a few percent of the stock tire diameter, first. Then within 3% +/- of each other. If your tires (tyres) are too small from stock or too large (diameter not width) then it too sets off the DSC light. I've seen E38's with wheels as small as 15" and as large as 22" but the tire size was very close to stock diameter and no DSC light. I've also seen the same wheel sizes with incorrect tire diameters throw the DSC light.
I know the system uses a revolutions calculation, but I am not sure if that calculation is able to be changed.
Yeah everything was 100% oem with the 17" wheels.
The issue probably has to do with the tyres as you are saying since the m5 never came with them, 255x45x17 on rear etc. So far I can't find anything related to diametdr, wheel size, revolution, distance etc for tyres/wheels in those modules
Cheers
E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
PANAMA, CIUDAD DE PANAMA
255x?? Here is where you can have your issue. Lets say you stuck with the stock 235 45 17 in front with a radius of 321.6 mm, diameter of 643.3 mm, circumference of 2021 mm that does 796 revolutions per mile. While you add 255 45 17 in the rear that has a radius of 330.6 mm, diameter of 661.3 mm, circumference of 2077.5 mm that does 775 revolutions per mile. This would cause your DSC to light up as you are outside of the +/-3% value.
A good place o keep up with front/rear values is a tire size calculator. I use http://www.miata.net/garage/tirecalc.html and yes it's a miata page but they did a great job on the java application for both graphical and written reference.
+100 740iSport303. the tire calcs pages (Miata or otherwise) are invaluable. not only for total diameter, but also for doing offset / ET checks with spacers and different wheel swaps.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
But what profile on the 235 and 255? Were they both 45 or one of them 40 or 35? The rim width (8J or 9J doesn't) make the difference. The entire tyre size provides us with the diameter, circumference, radius and revolutions per mile. Please replace the following ?? marks.
Front 235 ?? 17 on 8j
Rear 255 ?? 17 on 9j
By the way, I am in awe of you getting the M5 speedo to install and fully function and hope to do it myself. But I'm sure I'll need help before I screw up the electronics.
Found this while poking around with NCS Expert in the FSW_PSW.TRC
OELST_SENS_DEF
nicht_melden
OELST_SENS_DEF_WARNUNG
nicht_aktiv
OELSTAND_MOTOR_CAN
nicht_aktiv
OELSTAND_MOTOR_CAN has something to do with the oil level sensor and it looks like that setting, if it were active, would transmit the signal over CAN. I just need to figure out how to edit and apply the setting
Found this too a little further up... not sure what to make of it:
OELTEMPERATUR_ADC_WERT
nicht_aktiv
OELTEMPERATUR_FEHLER_1
untergrenze
OELTEMPERATUR_FEHLER_2
obergrenze
OELTEMPERATUR_SKALA
nicht_aktiv
SKALA means scale i beleive,.. and the untergrenze and obergrenze has something to do with the coolant temp, and being that the oil temp reading is an average of the oil temp + coolant temp, these must be an under and over reading
Stancing is for drivers trapped in an abusive relationship of their own lives.
Hey GSXRliterbikz,
I sent out my cluster for pixel repair (BTW it is a e53 X5 4.6 cluster).
Should be back by Saturday or Monday.
Perhaps with your assistance it can get programed?
P.S. I installed the seats and I gotta say... I... F&#~*ng... LOVE them (sry for the expletive), lol!
Check them out here (better pictures coming soon!):
http://forums.bimmerforums.com/forum...7#post27462967
2003 540iA///MSportMods:
///M5 Automatic Folding Mirrors,
///M5 Rear view Mirror(Thanks to LaLaRay),
///M-Tech 1 Dual stage steering wheel (Thanks to tmvE39E53Z32TT),
Old Style "Wolf Whistle" Alarm Siren,
E38 18-Way Contour Seats (Thanks to GSXRliterbikz),
E53 x5 4.6 Sport Cluster (Thanks to GSXRliterbikz),
E38 center armrest with iPhone 4 craddle (Thanks to GSXRliterbikz),
Slotted & Drilled Rotors with Stainless Steel Brake Lines,
19" M Parallel wheels (Thanks to DennisCooper),
Brushed Titanium Trim Vynil Wrap
Got this bad-boy installed a few weeks back!
Major thanks to GSXRliterbikz for the install and programming!
2003 M3CicM6 TiAg
Former:
Yeah... ummm.... what he said... lol!
But I've trying to educate myself to better understand the subject.
I've concluded that I need to get myself a computer
that can do all the programing on my e39 (like your GSXRliterbikz).
All in due time I guess. In the meantime, the cluster works great.
Aaah. OK. I thought you meant all that was sorted. Gotcha. I'd be up to try the 4.6 flash if that's the key but I got a tune now so would lose that. And I don't want to do the cluster swap unless EVERYTHING works right.
How did you guys do the VIN match - did you virginize the old cluster, or didja clone / swap chips from yours?
We should get together suntime. I know we tossed it out there a while back but never closed the loop - are you still in my neckadawoodz?
2003 M3CicM6 TiAg
Former:
The VIN and chassis number were copied from the IKE and loaded onto the new cluster.
GSXRliterbikz knows more about it then I do.
I just let him do his thing and stood out of his way.
I can't stress enough what a cool guy he is!
To get the tach and oil temp to work is a bit harder.
From what what I have read in this thread:
1. You need to save save (back-up) the 540i tuning maps
2. Flash the X5 4.6i with winfp to the ECU
3. Start the car with ^ said mapping installed
4. And then flash back the 540i tuning map over the newly flashed X5 4.6
I have yet to try this. Again, GSXRliterbikz is the one who installed my cluster and he know more than I.
He is aware of the instructions I wrote above and is looking into how to do it exactly as it is a little vague.
If this gets done, then all that would be left is to get the correct mileage in the cluster.
Summer is nearly here. I live in the Methuen/Lawrence area and work in Andover.
Let me know the when and where.
