Results 1 to 6 of 6
Thread: Overhauled the M70 throttle bodies
    Aug 2012
    Orange Park FL
    92 750iL 88 M6
    So I overhauled the throttle bodies today and wow big diference in throttle response!
    Still getting the TRANS PROGRAM error though
    Next up is a filter and trans fluid change, i know I should have done this off the bat. Thinking of replacing the speed sensor while I am in there but I have has no issue with the speedo.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    also clean the plug which is between TCU and the transmission, on the side of the transmission. Often this plug is filled with trans fluid, as the plastic is brittle around the pins in the trans plug and that causes contact problems. Can be cleaned with brake cleaner.
    When the trans pan is off and you change the filter: I would then also open up the valve body and clean it, remove every solenoid, clean the passages, test the solenoids and reinstall them. Also check for broken pressure springs in valve body.
    Lot of info here
    http://www.europeantransmissions.com...MWtechinfo.htm
    http://akpp-city.ru/pdf/4HP24_22.pdf
    http://www.bmwmotorsports.org/BMW_docs/transfund1.pdf
    http://www.transdetail.ru/assets/sit...ch%20Guide.pdf
    EDIT:
    Have just added new/updated DK cleaning info with lots of pics on the shogun site, see on the left on the site under new and updated
    Aug 2012
    Orange Park FL
    92 750iL 88 M6
    yup was gonna look at that plug when i get under the car.
    Sep 2012
    North Hollywood, CA, USA
    1992 735i (E32)
    If you have a chance, would you please post up some pictures? This is something I have on my to do list and want to get a good look at it before I jump in.
    Aug 2012
    Orange Park FL
    92 750iL 88 M6
    Shogun just updated the proccess on his webpage best to check it out there. I did not take pictures. I actually bought an extra set of DMKs to play with in case I really meesed it up but it was a very simple.
    http://twrite.org/shogunnew/topmenu.html
    there is soooo much useful info on his site!!!
    Jan 2005
    Japan
    Some more info on DK cleaning https://www.bimmerforums.com/forum/s...8#post30258578
    see page 1 item 6 DK throttle body rebuild and test http://www.km5tz.com/BMW%20850i.htm
  1. '91 M70 Throttle Bodies - Value?
    By BobieM in forum 8 Series (E31)
    Last Post: 08-18-2015, 11:14 AM
  2. E31 M70 Throttle Body $200
    By jcs1966 in forum Parts for Sale
    Last Post: 04-21-2015, 12:13 AM
  3. M70 Throttle Bodies
    By mrsharp in forum Engines, Performance Parts & Software
    Last Post: 04-13-2010, 10:40 AM
  4. I have m70 throttle bodies for sale
    By mrsharp in forum Parts for Sale
    Last Post: 04-07-2009, 11:00 AM
  5. I have m70 throttle bodies for sale!
    Last Post: 04-05-2009, 05:49 PM
