2003 X5 4.6is - for sale
2006 X5 L83 5.3 6l80 swapped in progress - for sale
1999 528i 5.7L 4l60e swapped w/ 31 spline 8.8 cobra diff - for sale
2007 ZX-10r - sold
1987 R-10 SWB L83 5.3L 6L80e swapped
www.87chevy.com
Man too bad about the hood clearance....but I am reminded by the parish turbo fairmont (600hp turbo 5.3 lm7) .... a nicely trimmed hole in a hood is not necessarily a bad thing.
not sure if you have figured out the headers but these look mighty fine.
http://ls1tech.com/forums/forced-ind...o-headers.html
I am planning on a LSx swap into my 97 528 sooner or later, I would love to be able to check yours out sometime. I'm up near Charlottesville so I'm not too far away from Richmond.
At this point is there anybody that does not have an e39 ls swap?
Rob
Prior projects:
1998 540i with 6.6 LS2/T56 Chevy Power
- pictures and details
1992 325i with 6.6 LS2/T56 Chevy power - pictures and details
1995 M3 with 6.6 LS2/T56 Chevy power - pictures and details
'99 BMW 540i6 L33 5.3, PRC Heads, E-force supercharged
http://forums.bimmerforums.com/forum....php?t=1674320
Swap looks like its coming right along! Do you have plans on selling that custom made supercharger?
Went and looked at this one with intentions on a LSx swap but he wouldn't take my $3500 offer.... Blah
http://detroit.craigslist.org/okl/cto/3302480619.html
E53 LSX Swap Coming Soon!
^PM sent
Waiting on some parts I ordered to come in, so not much progress. I have been throwing around manifold designs for weeks. I think I have finally set a plan.
I think I will make a set similar to these. Would be a pile easier that making tubular manifolds and would be less likely to crack I think.
May not flow as well as a nice tubular setup, but the F body guys are using truck manifold with great results, I doubt these would be any worse than those.
Input?
For anything under 1000+hp those should work just fine
If you are going to daily drive the car make sure you use fairly heavy gauge tubing and that the welding is rock solid.
Rob
Prior projects:
It will be a daily driver, and on the welding side, I have no concerns. That said, I have never used stainless for exhaust, any input on "grade" and gauge would be appreciated.
Schedule 40, don't make the primaries or the log huge. It will be a lot easier, and cheaper, to use mild steel, but I understand the desire to use stainless.
Rob
Prior projects:
I was thinking 1 5/8 primary's and 2 1/4 or 1/2 tube. I know steel is way easier, but this time I'm going for it. =)
That sounds good. Stainless is a PITA, but it is worth it
Rob
Prior projects:
I'd say schedule 20 304 would be plenty. I think if you go schedule 40 your welds will crack instead of the pipe. 304 will take a LOT of heat, but if its ever going to get to the point of glowing red, I'd go with 321 just for extra security.. Super expensive tho.
Nothing wrong with log manifolds. Simple, compact and flow well. Check out onlinemetals.com for material. Schedule 40 pipe will be hard to work with in larger sizes: 2.0 is 2.38OD with .154 wall. Half that wall thickness would be ok.
E30-LS1 Swap Guide and Kits, email us at e30ls1@gmail.com !!! or check our website e30ls1.wordpress.com
Am I completely insane for wanting to pull my perfecting good ESS S/Ced 60k mile S62 and do this?!?
Rob
Prior projects:
I remember, that was my point
Rob
Prior projects:
Nice build so far!
Doug
'97 M3/4
My new paper weight made it in today.
Did I need it yet, no... but its so fun to look at =)
You should walk around the shop blowing through it like a trumpet. The funnier you walk while doing so, the better.
Ha! Nice paper weight!
Doug
'97 M3/4
Thats some heavy paper weight... What are the specs on it?
