Page 19 of 28 FirstFirst ... 910111213141516171819202122232425262728 LastLast
Results 451 to 475 of 699
Thread: My e39 LSx swap
  1. #451
    Jun 2008
    colton, ny, usa
    95 M3 turbo V8, GSXR 600
    Quote Originally Posted by M5Hunter View Post
    I had a little leak on one of the vband clamps and I think it was due to everything not being 100% mated up together. the flex joint allowed enough flex in the pipe to make sure everything was flat and lined up properly.
    Just wanted to let you know I took your advice and added in the flex pipe. Take a look at my build. By the way I love your build and you might just be over 550whp at 12lbs.
    1995 E36 turbo v8
  2. #452
    M5Hunter is offline Still has a E39 Supporting Vendor
    Nov 2009
    Hanover, VA
    E39
    The Mammoth is tagged and insured again. Ran it up the street yesterday to put some fresh gas in it. The new wastegate setup looks very promising. I was able to hold 8-9psi on the 9psi spring at 3/4 throttle in 3rd gear. Feels like a turd compared to before when I was running 15psi with more compression. I went with the 9psi spring on the advice of my tuner. He says with my setup and 9psi I should be good for 550whp after the tune. Time to put some miles on it and get the motor loosened up some(not too much I hope) then get it on the dyno!
  3. #453
    Nov 2009
    Hanover, VA
    E39
    Got some miles on the car, so far so good. New wastegate location is working perfectly, no creep all the way to redline. While on the topic of wastegate.... one thing is for sure, this open gate has gotta go. I hate it. Just when the turbo starts spooling and sounding good, BBBBWWWWWWWWWWWWWWWAAAAAAAAAAAAAAAAAAH!!!!!!!!!!!! !!!!!!!! I want to hear turbo noises. I have stuck with the open w/g due to an inadequate exhaust system. I have a full 3" system and dumping the w/g back into that just seems like a dumb idea. I guess the next step will be a new exhaust system. Thinking 3" downpipe into oval 4" with a w/g merge there, then into a muffler with dual 3" outlets and run dual 3" to the back.
    Other observations, the 3.15 gear has got to go. I'm very happy I swapped to the M5 diff for strength, but that gear ratio is garbage with the t56 in my opinion. I have put hundreds of miles on it and havent even used 6th gear yet, including highway driving of 75mph. Hope to swap over to the 3.6x gear set soon along with a bimmerdiffs clutch upgrade.
    Lastly, 8psi is a joke. Tuner said 550whp is possible around that 8-9spi mark. I'm not disagreeing, but man, what a difference between 8psi and the 15 I ran before. The car is completely boring to me as it is. Keep in mind, its seeing 10:1 AFR in boost, so there is alot left on the table in the tuning department. I have a tuning appointment for Monday the 2nd. I foresee an eBoost controller installed before the tuning session... just in case.
    Assuming the motor survives the tuning experience, that Friday(6th) I'm planning a trip to MIR dragstrip to see if the car is up for some 1/4 mile passes. A fellow forum member and turbo BMW owner(also owner of Bimmerdiffs) Jonathan has challenged me to side by side breakdowns on the track.
  4. #454
    May 2010
    Salem, OR
    2000 BMW 528
    I've heard nothing but garbage reviews about the eboost, boost leash is supposed to be the ticket.... But I have no experience, just going off what I read on the interwebz.
  5. #455
    Buffalo, NY
    2001 BMW 540i/6
    I hear you about the rear end ratio. I have the 3.62 now, and even as it is, it's still too tall. I'm considering going to the next ratio up next winter (4.10? What else is compatible with the M5 rear)
    2001 BMW 560i 6.0 LSx/T56 SOLD
    2000 Corvette Hardtop FRC
  6. #456
    VA
    E63AMG/Z31/Tacoma/F31
    I think the 3.62 is perfect.
    Glad you want to ditch the open wastegate. I have always hated that sound.
  7. #457
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    Quote Originally Posted by RVAE34 View Post
    I think the 3.62 is perfect. Glad you want to ditch the open wastegate. I have always hated that sound.
    I did 3.64 on my turbo LS1. It's a ton better than 3.15 was. A 3.73 or 3.64/ 3.62 will work wonders!
  8. #458
    Feb 2008
    Upstate
    2 Boosted,1 more left to
    Quote Originally Posted by unnatrl View Post
    I just did a 3.73 for my build which was hard to find from a e34 m5. Glad to hear that this build is coming along the way you want it
    E39 LSX SWAP PARTS FORSALE
  9. #459
    May 2001
    Plymouth, MI 48170
    1999LSxSwapped 557i & X5
    3:91 LSD out of a e34 m5 or other e34 535's. Puts it right at like 1900-2000 Rpms at 70. I love mine.
    E53 LSX Swap Coming Soon!
  10. #460
    Apr 2014
    Greece
    M3 e36
    This is looking very very nice.
  11. #461
    Nov 2009
    Hanover, VA
    E39
    The eBoost street came in yesterday. Installed it today and changed the oil. Went out and messed with the controller some. It's amazing how much of a difference there is between 8 and 12psi. Still don't like the 3.15 all around, but man does it help keep the tires planted! Of coarse I was still able to do rolling 3rd gear burnouts, but they held on pretty well with some peddling. Still seeing 10:1 AFR's even at 12psi, excited to hit the rollers on Monday!
  12. #462
    Jun 2008
    colton, ny, usa
    cant wait to see it. make sure you take lots of videos!
    1995 E36 turbo v8
  13. #463
    Nov 2009
    Hanover, VA
    E39
    Well, it survived!! Tuning session went very well. Got to a nice stopping point of 586hp and 608lb/ft at around 13.5psi. Concerns for the clutch kept me from wanting to push it any further today. I surpassed my goals which I can honestly say has never happened before. It made 495 and 497 on the spring alone at 8psi. I had completely decided to leave it around 11.5psi for normal driving, but you can bet it didnt get turned down on the way home.
    Forgot to get a copy of the graph when I left, tuner is supposed to email me one. As soon as I get it, I will post it.
  14. #464
    Jun 2008
    colton, ny, usa
    Did is you get any videos?
    1995 E36 turbo v8
  15. #465
    Nov 2009
    Hanover, VA
    E39
    yes, I will get it up in a bit
    http://youtu.be/aQK5rI6BBS4
  16. #466
    Naperville, IL
    1998 540i
    Great results
    Rob
    Prior projects:
    1998 540i with 6.6 LS2/T56 Chevy Power
    - pictures and details
    1992 325i with 6.6 LS2/T56 Chevy power - pictures and details
    1995 M3 with 6.6 LS2/T56 Chevy power - pictures and details
  17. #467
    Nov 2009
    Hanover, VA
    E39
    Thanks Rob! It's been a fun ride getting to this point.
    Here is the graph. One pull at 13.5psi and one pull on the wastegate spring only which was 8psi.
  18. #468
    Feb 2008
    Upstate
    Wow thats great and the torque holds up. Congrats on exceeding your goals!!!!!!!!!!
  19. #469
    Oct 2008
    West coast
    Awesome #'s! What are the turbo specs? I tried to find it in your thread, but wasn't able to.
  20. #470
    Del a Where?
    LSx M3 & 2017 Touareg
    Nice work Clay and great numbers, glad you got that tq up I was worried lol
  21. #471
    Nov 2009
    Hanover, VA
    E39
    I also wanted to note. The tuner mentioned to me that in his 12 years of tuning, he has never had a LS swapped car with a turbo come in, get tuned and leave with no issues at all. Made me feel pretty good knowing I built a pretty solid car.
  22. #472
    Nov 2008
    New York, NY
    2001 BMW M5, 2005 BMW M3
    That is one HELL of a torque curve! Hits early, too. Great result. Would love to check out your beast when I am back in RVA later this month, Clay.
    --Peter
  23. #473
    VA
    Great to know, Clay. If only it had been that smooth getting to that point lol.
  24. #474
    Dec 2004
    Mill Creek, WA
    98 740iL, 01 Suzuki TL10
    Quote Originally Posted by nsogiba View Post
    If that 3.62 can be installed into an E38, I'd be interested in taking it off your hands.
    650hp 10 X5///M5
    PERFORMANCE:JB4 w/ meth, stage 2 tune, wrapped downpipes, custom intake
    INTERIOR:AVIN 10.25" screen, Blackvue 550 dashcam, 7" tablet for JB4 logging
    EXTERIOR:Niche staggered 20's or AC Forged staggered 22's, H&R 2" suspension, LED AE, CF front splitter
    325hp 98 BMW 740iL6
    PERFORMANCE:///M5 6spd swap, iron sleeves, L/W Teflon coated & silicone impregnated pistons, Sealed Power rings, 3 angle valvejob, P&P head, perf cams, electric fan, CF intake tube w/aluminium heatshield/wrapped MAF tubing, Magnaflow 14816'd, Eaton M112 in-work
    INTERIOR:Android Dynavin, hardwired V1 above rearview, 12" RE Audio DVC sub, MTX 81000D monoblock, CF silver trim, 5% tint
    EXTERIOR:///MPar staggered 19's, H&R Stage 2/Bilstein HD, custom notched bumper, Shadowline trim, 750iL brakes w/ Axxis pads
    190hp 97 328ci
    PERFORMANCE:Single mass flywheel, ///M3 clutch
    EXTERIOR:Z4///M staggered 18's, rolled fenders, tinted markers
  25. #475
    Nov 2009
    Hanover, VA
    E39
    What a day today. Went to a dragstrip rental today and beat the car to death for 7 hours. I made no less than 30 passes and the car performed perfectly. I did break the accelerator pedal, pushing it to the floor as hard as possible but nothing a tie strap couldn't fix. No amount of tie straps could repair the clutch that gave its life at the end of the day. I will not complain at all about it, it held on way longer than I ever thought it would.
    Getting this turd out the hole with the 3.15 rear and a 275 street tire turned out to be quite a challenge. Right off the trailer on 8psi it clicked off a 11.95 which was very inspiring. Up went the boost and down came the E.T.s! After running a whole afternoon of mid 11's I was finally able to knock out a 11.2@129. Backed it up with a handful of 11.3's and 11.4's. That being said, as far as I can find documented, my car is the quickest and fastest 1/4 mile E39 in the world. I was able to beat out the previous holder with a s/c'd M5 on drag radails by 4 tenths of a second.
    I'm car #9
