Page 36 of 36 FirstFirst ... 112627282930313233343536
Results 876 to 878 of 878
Thread: E46 Can bus project.
  1. #876
    Nov 2005
    Dublin, VA
    E46, E53, E90, GSXR, MR2
    Quote Originally Posted by Leinad78 View Post
    So, according to the Driver Information Internet pdf file, the cluster gets VIN data by the steering angle sensor. So the VIN is already on shared on the bus, does it get read from the DME?
    Yes the VIN is transmitted on the CAN bus. But not over and over. I believe it will be seen in ARBID 0x610. Was this mentioned before? I'm not sure. Anyway I looked at my notes and found this statement
    "Appears that there is a 0x610 request from the ABS in a remote frame (RTR bit set). Response from the IKE Contains VIN." Or in other words I observed a remote frame request from the ABS computer and the IKE sent a 0x610 response containing the vin. If memory serves I sent the remote frame from one of my devices and the IKE also responded with the VIN. It could be that other modules could send a remote frame request and perhaps other modules would answer. Not sure. Didn't see the need to chase that. But I don't think the DME asks for the VIN.
    Hope that helps.
  2. #877
    Philadelphia, PA
    2005 M3 & 2004 330i
    As far as I can tell, the DME doesn't broadcast its VIN over the CAN-bus.
  3. #878
    Jul 2011
    Ger
    2002 325Ci
    Quote Originally Posted by TerraPhantm View Post
    Indeed, it does not broadcast it. Just looking for a way to read it into the DME if itīs already available.
