Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 133
Thread: Ultra Light 2.2L m10 Turbo Build
  1. #101
    Ohio
    E21 320i, e39 540i/6
    I'm attempting to pick up some momentum on this very long running project. The head is back from the machine shop, ported/polished with 3 angle valve job and TEP SS valves and dual valve springs. The chamber's CC'd at 63cc and pistons come above deck .020", with a .060" Cometic head gasket I'll have .040" squish and 8.8:1 compression! I expected slightly smaller chambers as the head has been decked from 129mm to 128.8mm.
    I'm talking to an engine builder named Russ at Steve's Machine in Azusa, CA who seems to be pretty knowleable with m10 performance builds (thanks to Milotrain for the tip). I was looking at a high lift 280 cam they ground for Milotrain, but Russ thinks I'll need more cam for this build (I like where his head is at). I'll update when I have more info on a cam.
    I also purchased MS3X for full sequential ignition (and possibly injection too but not sure there's as much benefit there), so I'm going all out now...
    Kinda crazy, I just noticed that this is my machine shop, posted several years before I even found them or realized they were local to me. They did great work on my head on my head and block.
    '81 320i turbo | t25, 931 CIS, 240hp, 13.92@100mph | 2.2L m10 Turbo Build | My E21 Videos |
  2. #102
    Corona California
    79 320/6 81320i 65malibu
    Looking forward to more updates JR.
    Glad to see you are back at it.
    Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
  3. #103
    Aug 2001
    NC
    E30M3,318is,318i,E21320
    Quote Originally Posted by jrcook320 View Post
    Whoah just saw this thread resurrected. Huge potential powerplant here man. I remember that exact knife Castillo's crank. May need some serious wheel/rubber for that combo. Can't wait to see how you come out JR. Get to it!!!
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
  4. #104
    Ohio
    Here are a few pics of the cylinder head as it currently sits. I'm trying google photo, we'll see if they work for everyone else - they still display for me after logging out of my google account.
  5. #105
    Ohio
    Alright gents, for those that have blazed the EFI/Megasquirt trail before me, can anyone give me some recommendations?
    - I want to size my injectors to be able to handle up to 350 horsepower. This means at 43.5 PSI I need 71 lb injectors. At 60 PSI I would need 60lb injectors. I'm not yet finding a lot of options in a Bosch ev1 sized injector with this kind of flow rate that aren't ridiculously expensive, I'm wondering if there are any OE applications that can support this kind of power. Currently, it doesn't look like it.
    - What types of adjustable pressure regulators are out there that are compatible with the 318i fuel rail? Layne mentioned barb fitting adapter to allow use of an aftermarket adjustable regulator, but I have yet to find one.
  6. #106
    Aug 2001
    NC
    If keeping EV1 without adapters, then look or call RC engineering. I'm running RC 370cc on the M3 @50psi (3.5bar).
    Bosch volvo turbo injectors (greens) are about 330cc and probably borderline replacements for what your wanting. Use RC or some aftermarket if can find them.
    edit: not sure if fits the 318i rail, but the M3 rail looks similar; A pcar 3.5bar regulator plugs right in part number 0280160263 (Porsche 944-S, 2.5L DOCH 16V). There's also a 4bar version I've also from the Pcar's but the fitting is not plug and play.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
  7. #107
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Hi Josh, I cannot see the google pics from here. The urls are incredibly long, and maybe temporary. You may be able to find a shorter/embedable url in there somewhere?
    This is an incredible project you have!
    Tbd
  8. #108
    Jul 2010
    San Jose, California
    E21 320i, E30 325i
    Are you tied to the 318i fuel rail in some way? There are other options: http://shop.nukeperformance.com/fuel...bmw/fuel-rail-
    '81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
  9. #109
    Ohio
    I was planning on staying EV1 without adapters, but if I found an OE application that could supply the juice I'd consider adapters. I'll need injectors in the 600 to 700 cc range - not common in an ev1 OE application from what I'm seeing.
    It looks like long EV6 injectors could also be a direct fit which means newer higher hp OE applications (like the VW 1.8t? still trying to figure out oe length on this application) could work without adapters. I get good pricing on OE
    At one point I was considering EV21 or EV14 injectors in the stock CIS injector location (such as e60 m5 injectors) and running the stock e21 manifold, but then I'd have to modify the fuel rail due to pressure regulator interference. This would be similar to what bassboy did in his build to keep his BAE intake manifold - https://www.bimmerforums.com/forum/s...t-thread/page4
  10. #110
    Ohio
    Quote Originally Posted by amarino View Post
    Not necessarily other than the fact I already bought a 318i manifold and fuel rail and planned to plug the old CIS injector holes. If I went that route, I'd consider a long nose EV14 injector in the CIS injector location (the pressure regulator mount on the 318i fuel rail interferes with the head in this configuration), and keeping my old e21 intake manifold which is already set up with a 65mm m30 throttle body. Hmmm, good food for thought, time to make a check list. All I'd have to do is fab up fuel rail mounts, TPS adapter, and my own idle control valve adapter (rather than the 02again jeep adapter). I put a lot of work in to smoothing and removing all casting lines and defects from my old manifold. I could skip all that work again. I wouldn't need to find another throttle body, adapt a new throttle cable, blast/clean/smooth/paint the new mani, or figure out an adapter for a fuel pressure regulator,
  11. #111
    Ohio
    Autox, thanks for the tip on the porsche pressure regulators. That sent me down a path for some other options as well. As these regulators are all on turbo cars, I would assume they have a 1:1 vacuum/boost pressure rate, meaning if 0 is at 55psi (3.8bar), then they should raise pressure to 85psi at 20lbs of boost.
    Here are a few other regulator options that should be direct drop on on the 318i fuel rail (and other '80's Bosch fuel systems)
    Bosch 280160263 (Porsche 2.5L turbo) - 3.5 bar
    Bosch 280160287 - 3.8 bar
    Bosch 280160260 (Dodge 2.2L turbo) - 3.8 bar
  12. #112
    Nov 2005
    Mills River, NC
    '82 E21 320i
    BTW, Josh, links above aren't working (for me anyways)
    Recent method I've used from photos.google.com is to right-click the image and select 'Copy Image address' (only works from Chrome, IE gives me bogus links.)
    This should give you a url that starts with 'https://lh3.googleusercontent.com/'
    and ends with '-no'
    Insert it into the "Insert image from URL" dialogue adding '?.jpg' to the link.
    HTH
    Eric P.
  13. #113
    Ohio
    That's basically what I did except I used '-tmp.jpg' instead of '?.jpg'. Neither seem to work now.
    Sent from my SM-G920V using Tapatalk
  14. #114
    Aug 2001
    NC
    RC can do any cc rate with just about any connector and they definitely can do EV1 in a 750-1200 range for turbo cars. But these are all low impedance and if can would be best to use EV14 with high impedance setups that typically use high imp. Some systems require a injector driver box and some don't. Factory turbo cars from our era used low imp injectors and most will never flow that kinda fuel requirement without additional injector stages.
    So EV1 RC's or move to EV14/16 is my vote.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
  15. #115
    Aug 2001
    NC
    BTW if can use this new Pcar 4.0bar regulator PM me. part # 0 280 160 287
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
  16. #116
    australia
    E21 320i 2.0ltr "79"
    Im using RC 1000 CC injectors, American brand. good injectors for the price. never had any problems with them, smooth idle, and a crap load of fuel when time to get on boost
    I bought a Turbo Smart "FPR 800" fuel presure regulator, and brazed welded the bmw fuel rail to seal up were the FPR goes
    45PSI is what they run at
  17. #117
    australia
    and u need EFI,, forget about rising rate FPR's. it's all a outdated way of doing things,, MAP ECU is what u need if you can afford it and have the patients
  18. #118
    Sep 2011
    Chandler, AZ
    E28, '07 Duramax LBZ
    That head is really pretty. It would almost be a shame to use it and get it all dirty/greasy.
    advise / advice ...there / they're / their ...then / than ...two / too / to ...bass / base ...bare / bear ...brake / break...braid / brayed ...you're / your ...do / due / dew ...patients / patience ...wait / weight ...affect / effect ...know / no ...sell / cell ...sale / sail ...whole / hole ...reign / rain ...moot / mute ...pore / pour / poor ...buy / bye / by / bi ...lose / loose ...here / hear ...bore / boar / boor ...waist / waste ...were / we're ...and / an ...mourning / morning ...shelve / shelf ...well / we'll / will ...one / won / Juan ...who's / whose ...through / threw ...for / fore / 4 / four ...bored / board ...steel / steal / still ...scene / seen ....road / rode ...sight / site / cite ...mat / matte ...ascent / ascend ...tear / tare ...tier / tear ...vice / vise ...further / farther ...meat / meet / mete ...paid / payed ...red / read ...reed / read ...wreck / wreak ...thorough / Thoreau ...check / cheque / Czech ...cue / q / queue ...Tom / Thom ...learn the difference
  19. #119
    Nov 2005
    Mills River, NC
    '82 E21 320i
    Quote Originally Posted by BastardE38 View Post
    I know, right!? They look like "food grade" heads.
    Eric P.
  20. #120
    Ohio
    Quote Originally Posted by MelbourneE21 View Post
    The stock 318i FPR operates at 43.5 psi. What did you gain by using an aftermarket adjustable regulator set at 45psi?
    Megasquirt (MS3X) is EFI - map based with full sequential fuel and spark. A rising rate FPR is not used for tuning and is not outdated, it is used to maintain a constant pressure ratio across the fuel injector as manifold pressure lowers (idle) or rises (boost). This is how a proper EFI system should operate, stock style pressure regulators are designed to do this. Even your turbosmart FPR 800 references manifold pressure for this reason.
  21. #121
    Ohio
    I've made a little progress on my ECU. Ready to find a stim for testing before final assembly:
  22. #122
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    Looking forward to see this build also.
    Randy
  23. #123
    May 2013
    Chicago
    1983 e21, 2018 440i
    How is the progress?
    Have you thought about gearbox/diff combo to support that monster that you are building?
    Getrag 265 and e28 rear end swap?
    If you have e85 available then you will eventually end up going this route and i would recommend sizing injectors to support e85.
    I run volvo green tops from s60r they are 42lb/min. and support my 1.8@15psi with room to go. They would probably max out (90%duty cycle) at around 270-280whp)
  24. #124
    Colorado
    '81 320i
    So long time out of the game, wondering about the outcome of this project and if Josh is still around? Hope we didn't lose him, he was the Maestro of pushing the CIS envelope on E21's.
    Sure hope this project is not RIP
    -Lou-
    '81 320i, 5spd
    Kaschmir-metallic
    Sunroof, turbine wheels and factory fog lights.
  25. #125
    Seven Hills, OH
    98 740i 01 330Ci MKII TD
    As long as gasoline is available, Josh will not give up on this project. Once fuel is gone, he will be working on building his own refinery.
    Quote Originally Posted by 02inTheRockies View Post
