Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 133
Thread: Ultra Light 2.2L m10 Turbo Build
  1. #26
    Ohio
    E21 320i, e39 540i/6
    Thanks for the input guys. I didn't know the s14 used a balancer. That option is out for me as this is actually a welded up 2.0 crank. Hdx, I assume the stroke is still 84.00 mm?
    I am going with a larger turbo, and rest assured it will be well matched for the combination. The cis was very well matched for my old combo and I love it for the period correctness, the reaction when you tell people it's mechanical, and the frankenstien combination that works better than it should.
    I'm currently researching ms or megajolt as the new motor/ turbo will be severely limited by the fuel system.
    I can either run lower boost with the same peak power as before (and a lot more midrange torque), or spend more to go ms and start shredding drivetrain parts.
    '81 320i turbo | t25, 931 CIS, 240hp, 13.92@100mph | 2.2L m10 Turbo Build | My E21 Videos |
  2. #27
    Oct 2005
    Canberra, ACT, Straya
    82' E21 318i, 92 MB-180E
    Quote Originally Posted by jrcook320 View Post
    I should run lower boost with the same peak power as before (and a lot more midrange torque).
    Fixed.
    "The most important thing is balance." - KT
  3. #28
    Ohio
    Quote Originally Posted by waferman View Post
    So you had failing rod bearings also..if possible, can you post a picture of those for reference/learning material? I take it that you had a knock from those? Also, I'd like to see a pic of the glazing on the walls.
    I rebuilt my 1.8 completely in 2006 and while she's still running strong, I keep kicking around the idea of going with the 2.0L crank and custom JE's to match the crank & head combo. It would be helpful to look at my bearings/cylinders and check the conditions. In my case, when I started the project, there was a huge knock, and ALL bearings showed copper, so that was an easy smoking gun...
    I've never seen bearing failure quite like this. It was almost like delamination of the babbit material from the substrate. Not sure why or when it happened, it was only on 2 rod bearings. There was no rod knock and the crank was perfect. cell phone pics:
    Here's a pic of the cylinder walls. When I rebuilt this motor in '99, my local machinist told me the block was OK to just re-hone so that I didn't have to buy new pistons (which was out of my budget at the time). It really wasn't OK. There was a slight ridge and some scoring back then that didn't come out with the hone job. He said it would be fine, and I didn't know any better at the time. Now they're just worn more, and ring gaps were over double what they should be (ring gaps were in spec at the bottom of the bore, over double the max at the top).
  4. #29
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Probably from that detonation you mentioned.
    Your build is going to be exciting, for me too
    Tbd
  5. #30
    Ohio
    It was on the cap side, so more likely due to the mechanical overrev..
  6. #31
    Oct 2005
    I was just thinking that. Possibly a brief lapse in oil pressure due to pump cavitation? Or can a crankshaft flex in that situation?
  7. #32
    Jul 2010
    downingtown,pa
    1978 320i
    all in all, kind of surprised how well this engine hung together knowing the small details.
  8. #33
    Jan 2012
    Woodfin, NC
    (2) '83 320iS, '97 528i
    Contact the bearing manufacturer & see if they can tell you what caused that. I too noticed it was on the cap side.
    "The water was not fit to drink. To make it palatable, we had to add whisky. By dilligent effort, I learnt to like it." Sir Winston Churchill
  9. #34
    monterey, ca.
    e21, e30 m3. e46 330ci
    I don't think an overev would even faze the crank's rotating mass, valve float would occur at an rpm long before the limit of the crank.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
  10. #35
    Sep 2011
    Chandler, AZ
    E28, '07 Duramax LBZ
    Quote Originally Posted by Tom D View Post
  11. #36
    winston,nc,usa
    320i
  12. #37
    monterey, ca.
    ^ that's a great site, thanks.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
  13. #38
    Hillsboro, OR
    83 320iS, 83 533i, 90E34
    Thanks for the pix- sorry to hear that the machinest's advice didn't pan out. I was curious about weather or not that moneyshift from a few years ago had anything to do with this as I remember that you thought that it ran differently afterwards, but it doesn't look like it from the pix.
    The information on the hone job was a good lesson- double check the machine shops work! Plastigauge the crank and check end gaps of rings. All in all though, it seems to have lasted quite a long time, especially considering how hard you flogged it!
  14. #39
    Sep 2011
    Santa Barbara
    United States
    cant wait to see how this thing turns out..
  15. #40
    Ohio
    Before I pull the plug and buy the parts, I want to decide on rings. This appears to be an uncommon ring size. Rings only come with the Wiseco pistons if purchased in a full set of 8. Obviously, I'll buy 4 individual pistons and I don't see Wiseco rings for sale anywhere separately. The only options I've found so far are the JE and Total seal rings (see first post).
    The rings are 1x1.2x2.8 mm. This is a REALLY thin ring set to run on the street, particularly for boost. The thinner ring causes less drag and helps the top ring seal better at high rpm, however it also makes the ring weaker. From what I've read, rings this thin on a boost application are ideally made from steel rather than ductile iron for strength.
    Most common top rings are made from a moly coated ductile iron. Moly can flake under the heat associated with boost, and ductile iron is less than ideal for boost, particularly on a ring this thin. The JE top ring is gas-nitrided (hardened) steel top ring (perfect), while the Total seal appears to be a basic ductile iron (not good).
    While the idea of not needing to run larger ring gaps for the boost with a gapless top ring is appealing on a boosted motor, the T3583XX is a gapless 2nd ring set. This theory doesn't make sense to me. I think it would make the potential for pressure buildup between 1st and 2ng ring high, particularly on a turbo motor. This pressure buildup can cause top ring flutter and ring unseating at high RPM.
    I'd rather run a gapless top ring and standard second ring since the top ring typically does a majority of the sealing and current ring theory suggests that 80-90% of what the second ring does is oil control. Many engine builders and some ring manufacturers including Speed Pro now recommend running larger second ring gaps to prevent pressure buildup between the top and 2nd rings. This theory suggests a total seal top and standard 2nd ring is ideal, however I have concern about a ductile iron ring this thin for boost. I'd have to contact Total seal directly as I can't find this part number (M3583XX) available for sale anywhere currently.
    So, I'm currently leaning toward the JE, it's cheaper and made of higher quality, stronger materials and seems it will hold up to higher boost levels better.
  16. #41
    Jan 2012
    Woodfin, NC
    I've never built a turbo engine, but from an engineering standpoint the JE rings sound like the prudent choice because of the stronger material especially with the width you're talking about and given you're going to crank the boost up on this one.
    My only concern is how well they'll seat given that they're hardened and the kraut iron cylinder blocks seem to me to be harder than American. This I know from having done machining on both and having seen 150k+ mile m10 blocks that still have the original honing marks in the bores.
    I'd definitely check with JE for compatibility and if any special cylinder wall finish is recommended.
  17. #42
    Ohio
    It's time for an update. I only get a few hours a week to work on this thing, so progress has been slow.
    I decided to start with the head before spending any money on the bottom end. I tore the head down to to clean and inspect components and refresh anything worn, thinking it should be good to go. This was a "rebuilt" hi performance head from bavarian engine exchange, purchased 13 years ago, with only ~40,000 miles racked up since then. What I found was dissappointing.
    I made a cam removal tool out of 1 1/4" angle iron which happened to be a little too small for the job, but I made it work. 1 1/2" would have been ideal, I had to stack washers on the studs to get full rocker compression.
    Once everything was clean I began measuring and inspecting.
    Radial Valve Play:
    I put a dial indicator on the valves just off the seat to try to estimate guide clearance and measured .25mm on the intake and .3mm on the exhaust. Maximum radial play is .025-.055mm on the intake and .04 to .07mm on the exhaust, so my guides need replaced.
    Valve stem diameter:
    intake: spec: 8.0mm -.02 to -.04 (min. 7.96mm) - actual: 7.95mm
    exhaust: spec 8.0mm -.04 to -.055 (min 7.945mm) - actual: 7.945
    This is close enough to low limit I'm not going to bother running it, so I also need new valves.
    Rockers: All of the rockers have signs of wear on the cam follower pads, and the bushings were worn beyond maximum spec (old on left, new on right)
    Rocker shafts: You can one is much more worn than the other, indicating at least one was worn when the head was assembled. Both are worn below minimum spec.
    Camshaft: each lobe has some minor wear. Since I have to replace the rockers, I going to replace the cam anyway. On the rear bearing there are signs of previous damage and uneven wear.
    New Intervalves valves, Canyon guides, Febi rockers and eccentrics, and OEM rocker shafts:
    I removed the casting/parting lines on the rockers. I'll continue with polishing and may have the shot peened.
    I also went around the head cleaning up casting imperfections. No real reason, other than because it was fun.
    And, of course I'll clean up the port job. It's OK, but I'd like a better short side radius and smoother bowls. I also plan to clean up and smooth the chambers. I've only just begun in these photos.
    Next up, cam shaft selection...
  18. #43
    Jan 2003
    Mill Creekish WA
    97 M3/4/5 81 E21 72 Bav
    Go Josh Go
  19. #44
    Aug 2009
    san jose, ca
    80 320iS
    Why?
    Is there a "real reason" to do this? Or was it just for fun (like on the head)?
    Just curious...
    "Somewhere the zebra is dancing."
  20. #45
    Jun 2005
    Texas
    E21, E24, E34, E46
    Quote Originally Posted by 1980 320iS View Post
    Why?
    Just curious...
    It reduces the chance of developing a crack. Cracks always start from the sharpest edge or corner they can find.
  21. #46
    Oct 2007
    Elk Grove Ca
    77 320i 82 320is 93 f150
    Wish I still had that crank. I will be watching this build and coming to see you for a ride when its done.
  22. #47
    Huntsville, AL
    95 M3
    Are you planning on welding up the water jacket on the head?
    WOT
  23. #48
    Ohio
    Quote Originally Posted by hsvturbo View Post
    Explain??
    I wasn't planning on replacing the cam since I've been satisfied with it (both NA and turbo). Long ago I was able to get specs from bavarian engine exchange on the cam, I've long since lost them, and they've told me years ago their engine builder from that time is gone. It was 280 cam with about 9.2mm valve lift (IIRC, I'll be measuring to be sure). Once I have a baseline for lobe separation and lift from my current cam, I'll be able to make a better selection.
    I think anything over 280 advertised will be a little too much for my combination, but I'm listing the 284's out of curiosity anyway. I want to go for max lift with a wider lobe separation angle. I often felt that I was blowing through the motor at full boost between 3000 and 3500 rpm where it would get wild.
    Schrick lists the rocker ratio at 1.3, Elgin at 1.25, and Schneider at 1.26. I'll assume the correct ratio is 1.3, and valve lift info is calculated below with that assumption. I'll fill these in as I gather more data:
    Stock Cam
    Cam Lift | Valve Lift | duration | LSA | IO-IC-EO-EC
    6.96 | 9.05 | 264 | 114 | 18-66-66-18 (note - these numbers are listed in the factory service manual with a 236 @ .020" lift and 4-52-52-4 valve timing. The valve timing is calculated based on the advertised 264 duration. The 114 deg LSA is calculated based on the valve timing specs, and conflicts with what cam grinders suggest the stock cam spec is)
    Shrick 284 (VAC sells genuine, Ireland sells a copy)
    Cam Lift | duration | LSA | IO-IC-EO-EC
    7.2 | 284 | 110 | 32-72-72-72
    7.6 | 292 | 110 | 36-76-76-36
    Schneider Cams
    7.25 | 272 | 108 | ?
    7.25 | 284 | 108 | ?
    turbo grind listed as available... emailed.
    Elgin Cams
    7.31 | 278 | ? | ?
    8.23 | 284 | ? | ?
    Turbo cam?
    TEP - turbo grind
    7.69/7.69 | 274/278 | 110 | 27-69-67-29
    Any other options out there?
    Quote Originally Posted by bmac320i View Post
    Any time... That would be awesome.
  24. #49
    Huntsville, AL
    95 M3
    Best example, Look at post #27 of the following,
    http://www.e30tech.com/forum/showthr...t=22030&page=3
    The m10 combustion chamber is unsupported at the water jacket location, just like the m20. If I had to do it all again for high hp, I would weld the jackets, o-ring the block and run a stock HG.
    WOT
  25. #50
    Jun 2005
    Texas
    E21, E24, E34, E46
    Interesting. Never heard of that on an M10. Must not be totally necessary, as I've seen many high HP builds without it.
