Since we are going that way, does anyone know if standard 850 ECU can be programed to the CSI one to the EML button could be used?
I know the DMEs can
E30 1992 335 Cabriolet - Transplant nearly finished
E31 1992 850ci - Hartge H8 6.0 conversion
E34 1995 540A - Stock, low mileage, hi spec and soon to FI'd
E36 1994 M3 - GM LS3 Transplant
E38 2001 735 - Daily driver
E46 2002 330 Cab - Stock
M62B46 with TTV flywheel, dual plate clutch and 6 speed box sitting in a corner waiting for me to decide where to put it.
What cam and lens are you using. Love how your pics are so sharp
Just an old nokia phone :-)
Seriously though I'm not sure, it's belongs to my old mate the Earl of Wanstrow.
More progress today.
I created an EML XDF for Tunerpro and started to define the maps one by one. As each map was created I used data hit tracing in tuner pro to look for activity from pressing the throttle pedal. I found 3 tables for pedal response....1 for limp home, 1 for Komfort and 1 for sport mode. They are RPM based x Pedal movement.
On the CSi it appears you can achieve full throttle opening in sport mode at any RPM..... in Komfort you can't open the throttle fully until 4000 ish RPM( yet to convert the hex into RPM values).
Current Cars:
1994 BMW 850 CiA (2017 km). My black on black Wokke'd 5.4l V12 autobahnmuncher
1992 Donkervoort S8AT (105k km). The mad dutch "Super 7." 300hp/ton of turbo power!
2013 VW Caravelle 4Motion (57k km). A dark wine red 180PS/400Nm 2.0 BiTDI rocketvan
2007 SMC F-Kart 50. 88cc of street legal go-kart hilarity, and a 1968 Cadillac Coupé DeVille Convertible 472.
"The best way to go broke-by-german-car is to buy an 8 series bmw with a v12" - Perc
"Torque is like pron. You can't really define it, but you will recognize it." - ElToro
Are you talking EML pedal map or DME fuel/ignition map? on the CSi its the EML map is selected by sport/Komfort switch by the gearchange. On the Auto I would imagine the Sport switch also changes which map is used. Its very easy to change the values to make the pedal act as if its connected by a cable.....just make all columns the same value so that it acts the same regardless of RPM.
The DME doesn't have selectable maps......it uses the ones it's been setup for (fuel rating/country)
Somewhere I read – I can’t remember where it was – that the maximum opening angel of the throttle was also road speed related.
They don't appear to be road speed related. I have about 30 different maps defined now but only 9 or so seem likely to be pedal related.........I will edit the maps tomorrow........I think the safest way to test that theory will be to replace the existing high opening values with Zero's, then see if the car stalls at the same throttle angle/rpm regardless of road speed.
Here is a shot of the Komfort and Sport pedal map. You can see clearly the different rates.
I have also found what I think is the VMAX speed limiter, Its a 2byte value which converts to 252kmh. I will try dropping this to around 40Kmh and see if the cars hits that limit.
I didn't have time to try a new map on the car today, should have time tomorrow. I have altered the Sport mode map to act more like a cable in its response.....like this:
Fascinating! I bet the Wokke EML map is a bit steeper at the bottom!
My BMW Repair YouTube Channel
I know i shouldn't question you, but are you sure? Egil had a problem where his car read the wrong (US-spec) map iirc, as this was the market the supercharger kit (and their chips) were made for. Ran into issues when the car read a stock EU-spec map which had not been altered.
Current Cars:
Ha it's ok. When I said the maps aren't selectable in the DME I meant they aren't selectable by the driver. You can edit an area of the Eprom called the Variant switch, this will allow you to select country/leaded/unleaded/manual or auto gearbox/purge valve on or off ETC. So yes you can select a different set of fuel and ignition tables based but you would need to edit the code of the eprom then correct the checksum and install it back in the car.
So the pedal map will actually make the car "feel" faster and more responsive, but all you are doing is altering the ratio between foot input and throttle position output.
Will this not make it difficult to control throttle opening at part throttle?
My 4.8iS X5 has this mod from a remap and it feels great when driving hard but is a nightmare at all other times and is dangerous for someone driving the car and not expecting it.
8Tech.
Just for interest - the V8's throttle pedal produces a similar throttle valve curve, but achieved with metal linkages!
A kind forum member let me have a copy of their Alpina EML file to compare. Here is the Alpina sport mode map.
....So at 55% throttle-pedal travel, the Alpina fully opens the throttle once the revs gets to 5000 RPM - I bet that feels fast!
Indeed Tim, I uploaded the Alpina file into my EML and it runs fine and feels more responsive. I also tried my modified map and the EML light came on right away.....Checksum I thought, so I edited the blank area of the file so that the calculated sum was the same as the original. The car started and ran fine, throttle response was noticeably sharper but after 3 mins the EML light came back on. I'm guessing the numbers in the map are compared to some other values in the file so I need to look at the Alpina file in more detail......promising though.
Its funny how this thread has given me insight into many things on the e31.
Thank you so much for that Omega
