Page 3 of 15 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 375
Thread: Live mapping 850CSi
  1. #51
    Jun 2012
    Uk
    1994 850csi rhd
    Yes I will try a few different tunes including the original file.
  2. #52
    May 2010
    klepp, Norway
    2 x 850csi , E93 320ia
    Exiting
    Hove much differens do you expect on a complete original CSi?
    I will gladly fund you a bit for a set of chips
    Regards
    Terje
  3. #53
    Jun 2012
    Uk
    1994 850csi rhd
    Yes it will be very interesting to see what the standard tune gives in comparison.
    Hard to tell for max HP but the area under the power curve must have increased a fair amount. It's really not about Max HP with a road car, the area under the power curve itself is more important IMO.
    My idea was not to make money, I should have hundreds of 256 Eproms on my bench....I'll burn you a couple for free if you pay the postage.
    I'm looking forward to figuring out the EML operation, with any luck I should see the K and S maps using adsdress hit trace on TunerPro.
  4. #54
    Oct 2008
    liverpool uk
    koenig ks8 /e31 850c
    @ omega man
    where are you in the UK?
    how about putting up a few pics of your CSi?
    Best of luck with the remap
  5. #55
    Jun 2012
    Uk
    1994 850csi rhd
    Hi, I'm near Bath. Thanks .
  6. #56
    Jan 2005
    Laurel, MD
    I miss my E31!!!!!!!!!!
  7. #57
    Iceland
    BMW 850
    This car is just badass. What is the profile on the rear tires?
  8. #58
    Jun 2012
    Uk
    1994 850csi rhd
    The interior is all black
    Quote Originally Posted by Fatandre View Post
    I'm not sure, 285/35/18 I think
    Last edited by Omega man 1969; 09-11-2012 at 03:34 PM. Reason: Automerged Doublepost
  9. #59
    Oct 2008
    liverpool uk
    OUTSTANDING
    what hp do you hope for? NA
  10. #60
    Jan 2005
    Laurel, MD
    Quote Originally Posted by Omega man 1969 View Post
    Hmm!!! From this picture it looked like Green middle with black edge. But very nice regardless.
  11. #61
    Jun 2012
    Uk
    1994 850csi rhd
    Quote Originally Posted by Ahmed303 View Post
    Maybe because the rear sun blind was up.
    Quote Originally Posted by koenig d View Post
    OUTSTANDING
    I don't think 425 is out of the question but we will see, to be honest its everywhere else in the rev range that has improved the most.
    The mid range has changed drastically. I need to sort out the high part throttle fuel as its still a little on the lean side.
    Last edited by Omega man 1969; 09-11-2012 at 03:41 PM. Reason: Automerged Doublepost
  12. #62
    May 2010
    klepp, Norway
    looking forward to see the results ,and it would be cool testing on my own I must admit that
    Regards
    Terje
  13. #63
    Ireland
    X5M E70 and E28 525i
    I'll drop you a pm to help with testing once I get back travelling.
  14. #64
    May 2005
    USA,MD
    30e,30e,31V8,46M
    Great- I lie under the car for a few sessions and miss all this.. Awesome progress!
    Same 'ol story here.. people at work sense I have time to take-a-breath and now I have twice as much to do. I hope to take a step soon but on a good note my exhaust is almost done. Free-flow cats and 2.5" (all welded) from the cats back and !resonator. I even opened up the inlet ports of the muffs from 2" to 2.5". The tips all float 1/8" below the bumper plastic Need a chip mod fo-sho!
    On the Knock sensor.. of course you can do plug-cuts to see what's happening but thinking about an aftermarket knock-sensor.. the issue (again, way back when) was that the sensor itself is MATCHED to the frequency of the "sound" sensed at the block mounting location for a specific setup. Setup means sensor location, block, piston material and everything else that muffles or echoes sound through the mass. Essentially in order to detect knock electronically.. you had to PRODUCE IT and capture the results with expensive equipment.. so you can select (or spec the manufacture of) a sensor. Bottom line.. buying an aftermarket knock-indicator would reliably get you a device that alerted you at the same time your ear picked up audible knock. The lesson was.. if you "tune to audible knock" and get it to go away, the inaudible knock.. which is very bad.. might still be there.
    {edit} Well I went out and just got to it.. I have the .bin and it lines up well with the (scant, yet appreciated) TP xdf found on the TP site for the M60B30 404.. and compares closely to 0261200404-1267357689.bin found there too.
    Really need a "definite known stock" bin from a real e31 840 to compare to.. I'm sure mine has been messed with. There's a couple close-ish 840's in a local group round here.. I met them only once but unless one of you fine folks wants to mail me a stock chip to read.. it's my only way to see what crazyness someone threw into this car. I call it that because I highly doubt it was a o2 dyno tune based on some of the schtuff I've uncovered the PO did. It looks like 4th-tier mail-order or forum-tune.
    cheers and thanks for this thread! First step complete! Next.. find my Ostrich!
    _________
    (RIP)
  15. #65
    Jun 2012
    Uk
    1994 850csi rhd
    Dyno session cancelled. One of my AHK hoses burst yesterday evening. They had corroded where they exit the wheel well.
    A new set of 4 hoses is £500 from BMW, special order from Germany.
    A 5 day wait now oh well it could have been a lot worse.
  16. #66
    Sunny Cali,
    6.5 second 69 Camaro
    Have them rebuilt at a Hydraulic hose repair shop, Less than half the price, They don't care what it's for as long as it has fittings and a hose on it, They can fix it.
  17. #67
    Oct 2008
    liverpool uk
    +1 with 8eights
    had the same thing on my 850ci
  18. #68
    Jun 2012
    Uk
    1994 850csi rhd
    I tried a local Hydraulic hose company..Pirtek....they said it would cost the same if not more and were concerned as to why one hose had a larger diameter rubber section but similar metal diameter size, maybe some kind of dampening? who knows. I'm guessing high pressure is large one and low pressure the smaller one.
    The parts have been ordered now with BM along with 4 litres of CFH11s, Glad it was a pretty straight forward fix.
    Big shame I'm going to miss the Dyno session, I was really looking forward to taking a video for you guys.
  19. #69
    Iceland
    BMW 850
    Well. Get the car fixed and take then the vid
  20. #70
    Ireland
    +1 with 8eights
    Had the same problem on mine too, though went with the BMW hoses (got them at a good price).
  21. #71
    Jun 2012
    Uk
    1994 850csi rhd
    Guys, any tips on removing the propshaft, I noticed the input seal on the diff is leaking.
    So far I've removed the exhausts and the prop centre bearing support. I've unbolted the prop from the diff but it needs about another 5mm Clearance to drop out f the way. Looking at the diagrams, even if I unbolt at the gearbox end there is a section that sits inside the fitting.
  22. #72
    Apr 2008
    UK
    BMW 850CSi, E53 X5 4.8iS
    If you rotate the prop, there will be a couple of positions the flange will drop down if the centre bearing is down. Also make sure the splined centre section is free to slide so the joint will slide together.
    8Tech.
  23. #73
    May 2010
    klepp, Norway
    It is possible to bend it out , I did it myself a few years ago
    But it,s as you say if it was 5mm shorter it would be alot easier.
    I also later heard that it's really important to toque up the centerbolt in the diff with correct toque as to much can destroy the diff.
    I will lok for DYI i had :-)
    Regards
    Terje
    Found the link
    http://forum.roadfly.com/threads/105...al+Prop+Gaiter
  24. #74
    Jun 2012
    Uk
    1994 850csi rhd
    Thanks 8tech, mine has a universal joint in the centre section but no splines that I can see. The diff end has a boot and splines though. I've tried turning it to various positions but no joy. Looks like I will have to remove the front section of exhaust, remove the heat shield so that the prop can bend downwards.
    How about removing the 2 22mm bolts on the front diff support ? Would it drop forwards enough for the prop to clear? The AHK system is in the way of the rear bolts.
    Terje, thanks for the tip. Yes I will mark the nut so that it's tightened back to the same position. I rebuilt my Datsun LSD so I'm aware of preload issues
  25. #75
    May 2010
    klepp, Norway
    I remember removing the heat shields to get enough space .
    Regards
    Terje
