What is the production date of mattsimis' CSi vs yours? We should try to get a copy of his EML so we can perform a HexDiff against yours. Would be very curious/telling if they were identical, no? If that were the case, it would probably point us back to something input related - - which doesn't leave much as there aren't that many inputs to the EML. Here is an excerpt from the ETM that contains EML pin assignments:
ETM92_EML_Pin_Assignments.pdf
http://www.itsystems.net/PersonalPic...ssignments.pdf
Very interesting theory re: constant for the WOT pedal value somewhere in the code. Does your analysis of the code suggest this or you just going on a hunch?
Rgds...
I'm not sure of the year, mine is a 94. Thanks for the link John....interesting the Traction uses a 100hz square wave signal to reduce throttle angle.....that could be handy for you......fit some knock sensors and trigger a simple circuit to inject 100HZ into the EML...fool proof protection :-)
Re the WOT value.....As the manual and Auto expect different voltages as WOT but have the same pedal/rpm map layout there must be another map somewhere holding that value. I did find a 9 x 1 map that was active in sport mode....all its cells have the value 182.....I'm beginning to think this may be the one. I will change the values and see if the WOT switch angle changes with it. Basically the 9 cells related to engine RPM and I think the value of that cell may tell the EML what value to accept as WOT.
Could be onto something here, a shot of my CSi 9 x1 map that I mentioned.
Now a shot of the same map that I found in the 850 auto file you gave me. It was a different location but I found it searching the descriptor.
I reckon that is why you can't get WOT until 4200 RPM.
Note...I haven't filled in the RPM values on those charts but 4200RPM is where the auto map hits 182 :-)
John the second file you sent was also an Auto EML file.
If I can help out in anyway just shout me ( PM ) in South Yorkshire UK 850CSI 1993 CC88004.
Regards
Chadderz
A copy of your EML file would be most helpful, thanks for the offer.
I plan on sticking together a 3 chip package for the CSi, 1 tweaked pedal response EML chip and 2 x tuned DME chips.......really just the price of the chips and a couple of pounds to cover the cost of the kit I've used.....Probably around the £50 for the set sounds fair.
Omega. It sounds good.
Your presence here to the community is amazing and just this thread has opened my eyes.
I'm still working on this but I'm having problems with the checksum. If anyone reading this knows how to increase the checksum value if all the free space is filled with "FFFFFFFF"'s then please chime in. It's easy to reduce the value of the blank space if the table values are increased but if I want to set a table to all zeros the I can't see a way to increase the free space to keep the checksum the same.
If all else fails I will have to find the checksum routine in the code and remove it. I'm thinking that DIS will report a bad checksum and give an error code.....if I can find that error code within the EProm then it may point me in the right direction.
Right, the sun is out and time to get back to sorting the car for the summer. Thanks to 8tech for supplying me with a complete set of air ducting I can now fit the new CSi nose. I'll post some pictures once completed.
Finally. I have been waiting all winter :-P
Well this was usally done simple as an adress n + (n+1) sum. However, when you pass sum FFFFFFFF the counter will overflow and set n+1 to the rest value of the integer sum. If you max a counter to FF and add 1 the result will be 1,0000,0000.
ok, i'll try. a 2 bit register could have 00,01,10,11 ->0,1,2,3. a binary addition with (01+11)=00 beqause the result is 100,(4). the 1 will be an overflow bit outside the register. Convert all your hex into binary and add them together. Don't add the register with the checksum. The checksum could be 1,2 or 4 registers, depending on the hardware.
Sorry can't be more precise unless i have the hardware in front of me. Maybe a photo could help. Not into ripping my own out.
// Freddy
Could you clarify this please.
On a side note, Chadderz2010 read his EML Eprom for me and surprisingly it was identical to my EML, I was expecting it to at least have its own serial number like the DME's have.
One freshly painted CSi spoiler .
This one is going to look spanking on your car. Put it on and I demand a photo session!!
- Grush
E31 850 CSi "Chimbica" Thread
E34 M5 3.8 "Charanga" Thread
Workshop Site (in portuguese):
AvantGarde Serviços Automotivos
Yes I ordered it from BMW UK. Cost was around £550 including VAT. To have it Painted was another £130
Thats more like it.
Yeah. Looks good now. We need more.
From the sides and so on
Looks ace Omega!!
Thanks....It wasn't easy putting it all back together. The most difficult part was sliding the bumper back on and not having the rubber seals on the side of the front wings move out of position, luckily the Earl was home to give me a hand. The parts 8tech supplied cleaned up like new, I fitted the underside tray back on as well just to make sure it was back to how it should be.
So since you got that sorted whats the plan?
Dont know if you dont need the OEM side skirts
