Ill take one, email sent.
Will those connectors fit right in an M50 swapped S52? The stock connectors near the fuel rail are pretty jammed in there. If it's a good fit, I'm definitely in for this very clean solution.
S54 swap DME flashing - $100
S54 swap CAN interface board (for proper A/C & check engine light) - $275
e36 SAP sim/secondary air pump simulator: $75 - standard or $170 - plug & play
e36 post-cat O2 sims: $115 shipped, plug & play
Just sent you PM, not sure if you'll receive it since I'm very active on other forum but not here. Anyway, I need cheaper SAP simulator version for 97 BMW 528i (M52, single vanos, 04/97). I believe you said the wires need to bit little bit longer since the o2 sensors connectors sit next to firewall. If for some reason you can't contact me through here, I'm the one who asked this same question through ebay. Thanks.
2010 BMW M6 SMG Coupe * Black Saphire Metallic * Full Leather Merino Black
2019 BMW X3 M40i * Alpine White * Mocha Leather
Former:
1997 BMW 532M (528i with 3.2 S52 engine from E36 M3 / 5 speed manual)
1998 BMW 540i 6 Speed
2003 BMW M5
Will have more ready to ship on Wednesday the 15th.
This was a delightful mod. Installed today, worked great. Here's those P/N you will need to block off the valve.
11727514860 – Control Valve Gasket
11121438086 – Block off Plate
You'll also need a small vacuum cap. I used 3/16" I believe. I capped it at the end of the metal line, closest to the old valve, rather than up by the solenoid. Seemed easiest.
bump
Bump
Love it! looks very clean and easy. One question: Will you ship this to Canada??
I need the plug and play for both Secondary Air Pump and Rear Oxygen Sensors. PM me your email and a total so I can PayPal. Thank you!
bump
bump
bump
bump
bump
bump
bump
bump
bump
bump
