Page 12 of 13 FirstFirst ... 2345678910111213 LastLast
Results 276 to 300 of 302
Thread: secondary air pump simulator (SAP sim), plug & play, *no wire splicing*
  1. #276
    Northern CA
    1998 M3/4/5
    bump
  2. #277
    Northern CA
    1998 M3/4/5
    bump
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  3. #278
    Mar 2010
    Charlotte, NC
    e24 e31 e46
    SAP wiring issue
    Gary,
    Gary,
    I was wondering if I can ask you a question relating to the SAP system on a 1996 328i Convertible. The entire SAP system on the car was shot and I have replaced the valve and pump. but now I have a situation where I get no ground signal at the brown/green wire that goes to the SAP relay. I can't find a diagram, but from what I could find online, it may go to the DME. Do you have an idea of how to proceed? Thank you,
    Eric
  4. #279
    Northern CA
    1998 M3/4/5
    bump
  5. #280
    Northern CA
    1998 M3/4/5
    bump
  6. #281
    Northern CA
    1998 M3/4/5
    bump
  7. #282
    Oct 2018
    San Diego
    1998 M3 Sedan
    Hi Gary,
    Sorry if i missed the answer to this question while skimming the thread, but if I SAP delete while running OEM headers, will I be able to get rid of the Check Engine Light by installing just the SAP signal simulator and not messing with the existing O2 sensors at all? Or are the SAP signal simulator and O2 signal simulator codependent on each other?
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Juliulio View Post
    Hi Gary,
    The SAP sim is for eliminating the SAP. It manipulates the pre-cat O2 signals during a cold start. The pre-cat sensors remain in place and function normally.
    The O2 sim is for eliminating cats. It replaces the post-cat O2 sensors.
  9. #284
    Apr 2019
    Las cruces, nm
    Z3
    Just purchased a 2000 Z3 (m52, maybe m52tu depending on the vin decoder I use) with a failed SAS. Which sim will work for me? How do I purchase your sim?
  10. #285
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Kmontoya View Post
    Most likely M52...
    What is last seven of your VIN?
    www.realoem.com is a pretty good place to start.
  11. #286
    Apr 2019
    Las cruces, nm
    Z3
    The last 7 are LF83878.
    Thanks for the tip on realoem. It says I have the m52 engine.
  12. #287
    Northern CA
    1998 M3/4/5
    It says that but I'm pretty sure it is a tu. Can you post a pic of the engine to verify?
    I can make a sim that works for the tu as well.
  13. #288
    Apr 2019
    Las cruces, nm
    Z3
  14. #289
    Northern CA
    1998 M3/4/5
    That is a M52tu.
  15. #290
    Apr 2019
    Las cruces, nm
    Z3
    Great. How could your tell? How can I place the order for the sim for the m52tu?
  16. #291
    Northern CA
    1998 M3/4/5
    The intake manifold is the most noticeable difference.
    Sending PM.
  17. #292
    Dec 2019
    Rhode Island
    '03 525i
    Will this sim work on a 525i E39 M54?? Already $500 in and the CEL keeps coming back 🙁 PM or email please @gpeterson
    Bumps
    Quote Originally Posted by gpeterson View Post
    bump
  18. #293
    Grand Rapids MI
    2001 740i M-Sport
    @gpeterson, are you still making these? I'm interested in a SAP sim for an M62tu for my 2001 740i
  19. #294
    Alexandria VA
    99 M3iC 98 M3/4 88M3
    you still selling these kits?
    I need one for my 98 M3/4 and my 99 M3 convertible
  20. #295
    Northern CA
    1998 M3/4/5
    Yes, still available.
  21. #296
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    I recently put this on my M62TU. Works great. Glad to have the SAP gone.
    One suggestion for the M62TU users: Get the version with the plugs. Our O2 sensors are in a tough place to get to, and splicing the wires myself was pretty difficult. Part way through I was wishing I'd paid the extra price to have it done more easily and securely.
  22. #297
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by R Shaffner View Post
    I've actually started work on a design for M62, S54, M54, M52tu that installs inside the e-box and requires simple re-pinning of the DME connectors. No ETA on a finalized design yet.
  23. #298
    May 2021
    Sorrento, FL
    2003 BMW M5
    Good morning @gpeterson. I am interested in purchasing the e36 sim/SAP simulator plug & play version for my '03 S62 M5. Please ping me (I do not have the capability to PM yet) with details or at PeteEnglish11@gmail.com to begin the process.
    Thank you
  24. #299
    May 2021
    Sorrento, FL
    2003 BMW M5
    Thank you
  25. #300
    Jul 2021
    Chicago, IL
    2001 BMW 540i
    Good Evening @gpeterson. Do you still make these SAP delete simulators? I would be interested in purchasing one for my 2001 BMW 540i . Please email me back at wstrzelczyk22@gmail.com. Thank you.
