Page 11 of 13 FirstFirst ... 2345678910111213 LastLast
Results 251 to 275 of 302
Thread: secondary air pump simulator (SAP sim), plug & play, *no wire splicing*
  1. #251
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by ozinger View Post
    Do you have a DME Flash for '99 M3? How much does it cost? Does it overwrite other tunes/configs?
    This in not software, but system simulating hardware.
  2. #252
    Northern CA
    1998 M3/4/5
    bump
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  3. #253
    Mar 2013
    NWI
    1997 328is
    Bump,
    are these still available?
    Do these simulate for upstream Sensor?
  4. #254
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by iStagl View Post
    Bump,
    Yes, they are still available. It does not replace the pre-cat sensors, it manipulates their signal during a cold start.
  5. #255
    Northern CA
    1998 M3/4/5
    bump
  6. #256
    Ellay, CA
    BMW Z3 3.0 VF SC'd
    You're still making the SAP sims? AWESOME!!! I'm gonna need some soon as the turbo set-up comes to completion!!!
    "You don't win silver....you lose gold."
  7. #257
    Apr 2018
    us
    2000 BMW 540i A m-sport
    I am interested in this for a 2000 BMW 540i. I have error codes P0491 and P0492 insufficient flow bank 1 and 2. Will this work for California emissions? Cannot pm you probably because im new today and this is my first post. I look forward to your response.
  8. #258
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by moodyjohn View Post
    I can make one for your 540, pricing is the same as E36 models. You can't legally pass smog with one but it will eliminate those codes.
  9. #259
    Apr 2018
    us
    i'm sorry if i'm misunderstanding. Does that mean that hypothetically it would pass but it would be illegal? Or it wouldn't pass because it's illegal? Sorry i still can't send private messages. What i'm saying is, if my uncle bob stops by the house with his ca state certified emissions testing equipment and starts poking around on my bmw, is he going to be aware that something is up during the coarse of testing?
  10. #260
    Northern CA
    1998 M3/4/5
    Hypothetically pass (as I'm sure many have), but not legally. The sim will make the SAP system appear fine as far as OBD2 is concerned.
  11. #261
    Northern CA
    1998 M3/4/5
    bump
  12. #262
    Seattle,Wa
    98 528i
    Hello, I a interested in purchasing the plug and play sap sim and the 02 sims. Can you please email me purchasing information?
  13. #263
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Skrill E39 View Post
    PM sent.
  14. #264
    Aug 2014
    New Orleans
    2002 Z3. 2.5i
    Can you make this work for M54?
  15. #265
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Sw4mpy View Post
    Yes, same price.
  16. #266
    Northern CA
    1998 M3/4/5
    bump
  17. #267
    Northern CA
    1998 M3/4/5
    I'm changing the design so that it gets power from the SAP vacuum solenoid. Who wants to try one with a $20 discount?
  18. #268
    Sep 2003
    Bolton
    98' Z3M, 02' 911 C4S
    Tried to email to you and it failed for some reason. Does your SAP delete work for M44's?
  19. #269
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by modifiede30 View Post
    Yes, M44 not a problem. I'd need some wire length measurements though.
  20. #270
    Sep 2003
    Bolton
    Quote Originally Posted by gpeterson View Post
    Let me know what measurements you need - I'll see if I can provide reasonable estimates.
  21. #271
    Northern CA
    1998 M3/4/5
    Check out the E36 M52/S52 manuals:
    standard: http://e36-electronic.com/Documents/...lationV1.2.pdf
    plug & play: http://e36-electronic.com/Documents/...ionPNPV1.1.pdf
    You would need to take a look at the mounting location and length to run wire to the pre-cat O2 sensor. If you want to go with the new style power connection to the SAP vacuum solenoid (recommended) I'd need that wire length as well.
  22. #272
    Sep 2003
    Bolton
    I'm assuming the location of the electronics near the power terminal is for convenience and cleanliness right? The pump on this car is on the opposite side of the engine, and the O2 connectors are closer to the exhaust than the 6 cylinders, so thinking it would be easier to mount the electronics near the airbox (left headlight), and to run both the O2 sensor wires to their current location, which would require 3-4 feet of lead wire (estimate). Might be easier for me to just take the standard package and spice in the lengths I need unless you think that splicing would introduce an issue?
  23. #273
    Northern CA
    1998 M3/4/5
    Yes, sounds like alternate mounting on the 4cyl car makes sense. Splicing isn't a problem. I'd prefer to make the wires extra long so you would have a single splice. I could also leave the wires un-terminated and could could crimp the pins yourself and insert into the connectors.
  24. #274
    Sep 2003
    Bolton
    Leaving the connectors un-terminated is a great option. Probably be good to provide 5 feet of wire to be safe since I'm not sure how to cleanly route the wiring yet. Given the SAP location, I'll probably wire it in the same loom as the O2 sensors which appear to lead into the connectors for the camshaft position sensor, under the intake manifold and throttle body. If you want I can measure the final wire lengths in case you need to make them in the future and take a few install pics.
  25. #275
    Northern CA
    1998 M3/4/5
    Sounds good, PM sent with other details.
