Page 1 of 12 1234567891011 ... LastLast
Results 1 to 25 of 281
Thread: secondary air pump simulator (SAP sim), plug & play, *no wire splicing*
    Northern CA
    1998 M3/4/5
    $170 shipped via USPS Priority Mail
    I'm now offering the best e36 secondary air pump simulator in a plug & play version that installs in 10 minutes with no wire cutting/splicing and no permanent modifications to your engine harness or O2 wiring!
    Just unplug the secondary air pump, connect the SAP sim to its power connector then unplug both pre-cat O2 sensors and connect the SAP sim connectors to the O2 sensors connectors and engine harness O2 connectors.
    These are higher quality than the other SAP sims out there:
    -electronics sealed in epoxy for protection against moisture/vibration
    -high-temperature, color-coded GXL wire cut to correct length and covered in wire loom
    -mounting tab for installation
    -individually tested
    -money back guarantee: if you install properly on a m52 and have any issues you can return it for a full refund within 2 weeks of purchase
    Also available without the o2 connectors (requires splicing) for $70 shipped - http://forums.bimmerforums.com/forum....php?t=1864267
    Northern CA
    1998 M3/4/5
    bump
    Mar 2011
    USA
    96 M3 5MT
    Sorry I am a noob, what would deleting this air pump imporove or make easier/better? Does this have to do with the m50 manifold swap etc?
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by redbull713 View Post
    If you install headers that do not have secondary air injection ports you will get a check engine light. The SAP sim will eliminate the CEL.
    Jul 2012
    San Clemente, CA
    1999 BMW M3
    Hi g. I would like to know how to get a hold of one. Also what do you do with return valve on the header?
    How do I PM you?
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by thomas1bmw View Post
    How do I PM you?
    Sending email with ordering info, looks like I can't PM you.
    If you still have stock headers you can remove the vacuum line to the valve and plug it on both sides.
    Jul 2012
    San Clemente, CA
    1999 BMW M3
    How can I get you my email. My sap went out this last week and it is driving nuts. Kput, Kput Kput. I just installed all 4 O2 sensors last weekend
    Northern CA
    1998 M3/4/5
    More info and email address available at http://e36-electronic.com/.
    Jul 2012
    San Clemente, CA
    1999 BMW M3
    G, I guess since I am new I need 7 posts in order to PM
    Thanks G. I will go the http link.
    Compactive's Avatar
    Compactive is offline Helpful. BMW CCA Member
    Moderator
    DMV
    3x 318ti
    Work for M52?
    RIP Ted.
    Want a custom signature? Post requests here, or PM me here | My Flickr
    Northern CA
    1998 M3/4/5
    Yes, all m52.
    Northern CA
    1998 M3/4/5
    Only 1 more plug & play ready to ship, may be 2 weeks before I have more.
    Mar 2003
    Winnipeg, Manitoba
    1997 BMW M3
    This is getting tempting. I need a place to put my catch can.
    97 BMW M3 (s52b32) - VF-Supercharger kit ( Vortech V2-SQ supercharger, 32 pound injectors, VF tuning ), VDO/LeatherZ Gauge Kit (Oil Temp, Oil Pressure, and Boost), UUC Motorwerks RSC36 Exhaust, Stainless Steel 6-2 Exhaust Headers, Bilstein Sports, Rear Adjustable Camber bushings, Wheel Spacers 10mm in front 25mm in back, Uprated Clutch, UUC Shift Knob, Short Shifter and Clutch Stop, Cross Brace, Mason Engineering front strut bar, Contour Wheels, Euro Ellipsoid (Angel Eyes) HID Headlights, braided steel brake lines, aluminum thermostat housing, mishimoto aluminum radiator and silicone hoses and a partridge in a pear tree
    Northern CA
    1998 M3/4/5
    I also have a handful of the cheaper ($95) non-plug & play ready to ship as well. Those are pretty much always ready to go.
    Sep 2009
    Cupertino/San Jose, CA
    1998 BMW M-Roadster
    Thanks for the quick response Garry...can't wait to install this!
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by quicsylver15 View Post
    No problem, thank you!
    -Garry
    Northern CA
    1998 M3/4/5
    Just got more connectors and have a few more plug & play sims ready to ship.
    Also available without the o2 connectors (requires splicing) for $95 shipped - http://forums.bimmerforums.com/forum....php?t=1864267
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
    Northern CA
    1998 M3/4/5
    Instruction manual for plug & play SAP sim is now available, check out http://e36-electronic.com/Documents/...ionPNPV1.1.pdf to see how easy installation is.
    Northern CA
    1998 M3/4/5
    Here are before & after installation pictures of the O2 connectors. Nice & clean, even though it gets hidden by the fuel rail cover. (vehicle shown has M50 manifold)
    Mar 2003
    Winnipeg, Manitoba
    1997 BMW M3
    Very tidy.
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by RobertFontaine View Post
    Very tidy.
    Thanks! I try to make very clean & easy to install.
    May 2012
    King George, Va
    95 M3/2/A - swap coming
    Quick question, with this installed and cats deleted with o2 sensor simulators post cat, does that mean that there will be no o2 sensors in the exhaust at all ? or does this go in addition to the pre cat o2 sensors ?
    2002 325i Silver Metallic Sedan/Manual - Modding Every Day
    - Street Stars Motorsports -
    - Bimmerworld Dealer
    - UUC Dealer
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Worstenemy453
    Pre-cat sensors stay, this just sends a different signal to the DME during cold start when the SAP should be running.
    May 2012
    King George, Va
    OK. I believe i PMed you.
    - UUC Dealer
    Northern CA
    1998 M3/4/5
    Don't see a pm from you...
