I was wondering how much I can tow with my car, it's an S50 powered Ti with M3 front brakes and 6 cylinder springs. I have already towed around 1300lbs, and I want to know if that's the limit, or if I can tow more weight. The car doesn't struggle at all.
The Euro 318ti owner's manual say a 165 lb. tounge weight and a 1,366 lb. unbraked trailer. Braked trailers are just a tad over 3,000 lbs.
+1 for checking the owners manual. Its amazing what info is in there. If you don't have one then do a google search for e36 owners manual pdf.
What hitch do you have installed on your car currently? I know there was an OEM BMW brand hitch that was available in Europe but it is very communion over here in the US; thus I am assuming you have an aftermarket Curt or DeLan trunk pan mounted hitch. If this is the case you may not be able to accurately or safely follow the BMW specs in regards towing capacity. I know that my aftermarket hitch says max 2500 lbs and I am confident that the real limitation is tongue weight for what ever that is worth.
tmaxx445
2001 740i / S62 Swap / 6 Speed Swap / Titanium Silver Metallic / Grey Montana Leather / M Sport / Convenience Pkg / Heated Seats / PDC / MKIV Navigation / DSP / Bluetooth TCU / Dice Mediabridge / Vavona Trim / Illuminated ZHP Shift Knob / Short Shifter / Cat Delete / SAI Delete / Euro Tune / Koni Singles / H&R II Springs / Custom 3.15 25% Limited Slip Diff / Staggered OE M Parallels / 275 & 245 Firehawks / Euro City Lights / Celis Tail Lights / SunTek 70% CXP Tint
2005 M3 Coupe / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium Pkg / Cold Weather Pkg / Bi Xenons / Adjustable Bolsters / MKIV Navigation / Harman Kardon / Bluetooth / Sirius XM / Aux In / Carbon Trim / ZHP Shift Knob / Short Shifter / StreamLine Intake / SS Headers / AR20 Resonator / Exhaust Bypass Valve / P0lar Tune / Koni Yellows / Eibach Springs / Staggered OE CSLs / 275 & 245 595 Evos / Angel Eyes / CF CSL Splitters / SunTek 38% Carbon Tint
2003 4.6is X5 / Stock /
Why in the hell would you tow something with these cars, buy a truck.
1989 325is new DD
1996 328i slushbox (daily driver)sold
1984 320i euro (project/build, build thread below)
http://forums.bimmerforums.com/forum...5#post27290455
I could only imagine the wear and tear you are putting on it towing half of the weight if not more than the car weighs.
I have towed with both my M3 and my 318ti. I remember that 1300 wasn't a problem with the car (the ti was slow), but more weight than that definitely had more effect on the feel of the car.
