ok but I'm not the only one without computer powered up. "Dark Abyss" has same problem. checked connection twice and everything is correct.
I dont think that the lights are burned because it worked fine installed in car about a week ago.
what about Kline? Is it needed for computer?
The K line is for data communications. It isn't needed for checking that the cluster functions, and running the display test. You can hook it up to a diagnostic system (e.g. K+DCAN cable and INPA) if you want to verify specific lights work or set the gauge motors to a specific position for calibration.
I recently helped a local board member with the same problem. His cluster wouldn't power up. The first fault was a broken circuit board power trace where the screwdriver had slipped when releasing it from the black plastic back. Only after everything was finished did we find there was a second broken trace for the CAN bus communications.
thanks for you help until this point!
I doubt that something is broken like in your example because the computer worked fine when the cluster was installed to car. Ok the pixels were faulty but basicly the computer worked. So what i have done was just remove the cluster from the car to test it on bench before i will replace the LCD.
Plus i cant install the cluster back to the car the next months. So thats why i want to do it all on bench.
What I'm gonna do now?
Sorry Double Post.
Here is a pic. Checked connection twice...
OK, that's useful info. The LEDs are lighting up, but only the incandescent backlight behind the odometer is lighting.
Try test mode by pressing the right button for 10 seconds. If you don't see anything, use a bright light to see if the LCD changes.
Test the lamps to see if they all work. They should read 10-50 ohms resistance. Swap them to different locations.
There we go
Thanks a lot mate!
This is what ive got when i press 10sec the right button. But what about the upper info?
Your bulbs has gone. Usually when you take out the cluster from the car and shake it around while removing it, the small fragile 20 year old filamen inside it breaks.
New bulbs should fix it. Backlighting problem.
problem.
What kind of bulbs are this?
62111391260 12V 1.5W beige/tan base lamp
Don't use a 1.2W black base lamp. Those are dimmer, and are used for indicators on pre-LED instrument clusters.
It's useful to keep a spare around since the filament becomes brittle with age, making it vulnerable to shock during removal.
Thanks a lot! Found some on eBay.
There's also 2W versions. I haven't used them in the E39 but I have in Audis before. You have to check if the brighter ones are going to work for you... You'd think "oh brighter is better and I can just dial it down w the dimmer" but since the dimmer dims other stuuff in the car, there's a 'balance' issue... and if you dim the bright bulbs you may find some of the other illumination - say the climate control - inside the car is too dim. Depends on the car and your preferences. On the old Audis 2W worked because the factory bulbs were already really too dim in proportion, but not sure if that'd be the case w/ the E39... they might be too bright.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
Already bought oems. Works fine
But I have an other question. I want to change some LEDs. What is the pinout for checking the background lights?
All instrument cluster lighting is software controlled. Note the timeout on the Service Interval backlight, and that the check control backlights are only on when information is displayed.
Which LEDs are you going to change? How are you planning on changing the LEDs? With a forked soldering iron tip? A knife tip? Hot air rework with kapton tape protecting the surrounding area?
So i have no chance to check on bench?
I want to change the ambed lights from all scales to white.
I ve thought about a forked iron but in my opinion the risk of damaging the smds is to high. I will try to desolder with hot air and solder back with a normal iron.
You just need to provide power to the illumination wire on the cluster and the backlight LEDs will light up. I think all you need is the illumination wire and at least one of the grounds if you don't want to bother powering up the whole cluster. Can be done with just the black connector.
Also, I use hot air to replace the backlight LEDs to white and it works fine. I even use it to solder them back on, but I heat the solder pads first, then drop the LED down onto them, then use an iron with a needle tip to add new solder after they are stuck down.
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
Thanks mate!
Could you tell me the pins for that or did i get it wrong?
I believe the illumination wire is pin 8 on the black connector (high cluster) and ground is pin 1.
-Paul
I will test and report!
Works, thanks mate!!!!
-Paul
Thats the result:
But the LEDs are slightly too bright. Didnt expect that
-Paul
johnate, is it hard to virginize a cluster? Do you have a link to specific guide that gives step by step info on the software?
