Very detailed build! It will definitely pay off in the end.
You, picky about the M5?? No......... lol.
This time let's keep the GoPro video instead of magically deleting it....
And I'm not looking forward to seeing how much work I have to do to the old 5.0 to make it keep up with the M5, lol. I can see the $1200 credit card bill for aluminum heads in my near future
Don't complain, our cams are $2000 lol
Nice build!!!
e30 84 340i m6x powered.
e34 89 535i 5speed - current DD
e24 89 635csi - maybe a DD?
e34 93 525i (m50tu) - gone
e39 540i 6spd m-sport - gone
e53 x5 4.4l - gone
e30 89 325i (m20) - gone
Glad to hear it is sitting on it's own wheel again.
Thanks, hope so.
You need to post pics of the Mustangs and get some ideas for the older 5.0 I still say bolt on the twin screw . . . . Its the easiest and cheapest power gain.
Thats depressing . . .
Thanks!
Not a chance lol, still lots to do.
Well here are some updates on whats been done last week and a little over the weekend. Replaced the brake reservoir and grommets. Old.
New parts.
Installed.
Got around to pulling the throttle bodies so I can replace the gaskets and orings and then do a throttle balance. Plenum off.
Throttles pulled.
Ports look good and clean.
Since I'm deleting the secondary air injection system I cleaned up a few of the vacuum lines and pulled the old EM valve and cleaned the head and block up. The rest of the lines are around a year old and everything was still nice and soft. Before.
New vacuum parts.
Hrm, forgot to take a pic of the finished product lol.
Anyways, I also pulled the fuel injectors and Im sending them off today to Witch Hunter Performance to get cleaned and rebuilt, http://www.witchhunter.com/injectorserv1.php4 . Injectors.
Cleaned up and replaced the hardware, gasket, sensors, and oil filter kit for the filter housing.
Cleaned the motor mount arm and installed with new hardware.
Motor mount arm and filter housing installed on cleaned block.
Finally I installed the rear subframe mount with new hardware.
Installed.
Overall its moving along well, being picky is pricey mainly in time. For example I'm waiting on a new bolt for the steering box so I can stuff the front subframe back up with all the suspension. I also ordered some Mercedes citric acid cleaner and picked up some Shout to descale and degrease the cooling system along with all new hoses and hose clamps. Water pump and thermostat are around a year old and I think Im going to leave them alone for the time being since I plan on upgrading the cooling system with a different water pump and thermostat design along with a new radiator after Bfest. I need to pickup one of the vacuum tools you showed Jon, thats a nice setup. I should have more updates later this week where it will start looking more like a car and finally be off its jack stand home.
"You may all go to Hell, and I will go to Texas."
Davy Crockett
www.Angry-Ass.com
My Build Thread Part 1, Part 2
DIY E31 X-Brace Mod and Install
DIY Rear Seat Backrest Modification for E32 Armrest
Greg, hehe. Just so you know, and I did the same exact thing... the diff mount is backwards!
The side that has metal extend off of it goes toward the front of the car. If you don't flip it around the bolt hole is about 1/2" off. Very frustrating to remedy when jacking the subframe back in.
You mean the frame rail plugs? I replaced them
Davy Crockett
www.Angry-Ass.com
I know I went by the drawing too and then I was like OOOOOOOOMG my subframe is bent! And then I realized the mount was turned around.
Yeah man check those little plastic plugs on the frame rails I don't even remember how I got the PN# for those lol.
Davy Crockett
www.Angry-Ass.com
Mainly I didn't see any room for dramatic improvement performance wise by going to poly, the M5 units are already a sealed rotary style bearing with rubber isolation which is about as good as it gets. But I do see anything poly being a source for NVH especially with rotation being introduced mainly squeaking at low speeds on rough pavement (Parking lots, residential etc) which would piss me off to no end. Since I'm really just trying to modernize the M5 while at the same time make it as durable as possible I couldnt see going to the AKG pieces. The cost is cheaper than OEM and installation is easier but I dont think I'll need to do this for another 10-15 years so .
BTW Jon is the Stewart water pump able to be disassembled easily?
Davy Crockett
www.Angry-Ass.com
Nice - yeah the bearing type must be nicer. The stock E34 stuff is the "torque while in position" crap and while not worn out, I would never want to go back in there after having it apart - the AKGs are nice in that they can be removed on t he car with a dead blow hammer and a pry bar.
I haven't actually had the opportunity to take a stewart apart yet - I run them in both my daily and my turbo car. I will say, the machine work and the bearing tolerances and all are very nice and they're supposedly rebuild able.
Dude, your lady turns wrenches with you? You win.
Guys guys guys....let us keep the compliments to a minimum. You gotta space the compliments or it gets to his head.
I kid I kid.
Jamie is a pretty awesome women.... I remember the days when she could drink me under the table.
Davy Crockett
www.Angry-Ass.com
Oops.......
Game on haha. I think I feel the hangover coming already, I hope the cop doesn't bust me skinny dipping. What are the chances I would get off the hook twice?
Davy Crockett
www.Angry-Ass.com
Bump for some needed input.
Got any pics of the dowels you are speaking of?
Sneezy, lets just say it is a good thing Jamie isn't coming on our roadtrip because I am not sure you guys have enough to drink for both of us.
