Anyone have the torque figures for the subframe mount studs/nut and rear subframe mount torque?
Bentley doesn't seem to cover.
Thanks guys!
Isnt it considered the "connecting link to rear axle subframe"? 94 ft lbs?
I didn't see that, lemme check again.
I see that now, but not sure. And, what of the rear subframe mount bolt torque?
I was talking about the big bolt that comes through the subframe. Which other ones are you talking about?
The subframers themselves and the big bolt (definitively).
Use a 1/2 impact and tighten them. No problems. Thats what we used on all the subframes at the dealer.
I tightened to 110ft lb on both the e34 and the e21. No issues here
Gimme a minuite and I'll try to look it up. PDF is loading
Looks like it's not gonna load, I can get it tomorrow if you don't get it by then.
I'm guessing in the neighborhood of 90n-m
Edit again:
Google gave this:
http://tech.bentleypublishers.com/th...threadID=36394
It's in the PDF, looks to be 120 n-m but like I said, I can double check at work tomorrow.
e46 m3, some 740 sport shorts, F30h, LR3 and a 540it
Yeah its not clear - I don't see 120 nm i see 127 mentioned twice though
1/2" impact is a measurement? lol
Not like is an aluminum bolt or a head bolt. Just so its tight is all that counts. Believe me I was all about torquing everything to spec, even brake caliper mounts,etc.When I started the top master techs would look at me like are you seriously looking up torque specs for everything, you must be new. After 4yrs working at a bmw dealer you learn what needs to be torqued properly and what can be tightened by hand or impact.
Yeah, I don't torque subframe bolts with a wrench. I use my torque sticks and a 1/2" impact. I've verified it with a torque wrench to be within 5nm.
Some people want to do it by the book, you can't fault them for that.
By "connecting link to rear axle subframe" is it referring to the dogbones (pitman arms) or the actual rear subframe mount points to the chassis? Kinda confusing..
I went through this a while back. Here's what I found back then:
Rear mount to body - 33 lb-ft
Subframe to rear mount - 57 lb-ft
I used this resource: http://www.bmwtechinfo.com/repair/main/
Drivertain: Getrag 260/6, E34 M5 clutch, 15 lb FW, E36 M3 shifter, Portland Driveline driveshaft
Suspension: Eibach springs, Koni adjustable shocks/struts, M5 antiroll bars front/rear, M5 thrust arm bushings, fully rebuilt suspension/steering
Engine: Rebuilt top end and resealed. Turner Motorsport ECU chip.
Lighting: Euro smilies w/ 5500k HID lights, clear front corner lights
That sounds like too little!
Ahhhhhhhh
Yes but I mean as fasteners go, the subframes are like M12 or M14... 57 ft lb sounds too little.
If you can't find the right torque, BMW gives you a handy dandy chart with fastener sizes and thread types with suggested torques in their manual. That should get you close to what it should be. Nothing on my car has fallen off yet from the torques I used
I am not stalling for tq measurements. I am waiting on orders of fasteners to come in. Its not air pressure that dictates torque. The gun and and the line size do too. There are some torque wrenches that are 400 ft lbs at 125 psi..
I will measure the bolts and look up the torque specs equiv based on material type
These are M14x1.5 bolts, probably grade 8.8.
Here is the page that says that the proper torque spec. is 140 Nm (line 3AZ below):
Here is the torque table:
