Results 1 to 5 of 5
Thread: M50/M52 into E46?
    Mar 2010
    Toronto, Ontario, Canada
    E46,E30,BNR32,AE86,EF,EK
    M50/M52 into E46?
    Hi Bimmer Forums, I'm slowly piecing together parts for an M52 turbo setup and have a few simple questions:
    -Does the M50/M52 share the same engine mounting positions as the M52TU/M54?
    -Are the E36 M50/M52 and E46 M52TU/M54 engine mounts interchangeable?
    I'm trying to figure out how difficult it would be to get an M50/M52 into an E46. And also if I can use the TRM turbo engine mount in an M50/M52 swapped E46.
    Thanks,
    Carthik
    Jul 2006
    335ti 360ti x5-6.0tt
    minneapolis
    tite
    i think he might be talking about the actual motor mount bracket from the block to the chassis mount, and i think there is only a couple people that know the answer to this question, one of them told me the e36 block and mounts hold the engine back a couple inches to much, and the hole in the subframe needs to be elongated.. i just finished making custom mounts and will be able to confirm in a few days when i get around to fitting the engine in the car
    UK
    328 Convertible
    hiya
    I don't suppose theres any updates on this is there?
    Nov 2018
    Syracuse, UT
    E46 330 coupe m50b30
    I’m in the same boat. Trying to figure out how to make my m50b30 turbo 5 speed fit into my e46 coupe. I used e36 engine brackets and it sets the trans brace about a half inch too far back from where it needs to be. E46 non m brackets won’t bolt to the block correctly, but 2 out of 4 on each side will. Still searching for info on this as well
