Hey Fellas,
I am trying to have my stage 2 turbo upgraded to the T60-1 hybrid unit...
I need to know what size compressor wheel is used in it...
Thanks for your help, also, can anybody reco a place to have the upgrade done? I will most likely have turbonetics do it, but if anybody has any suggestions, please, let me know...
Thanks again!
Rich T.
"For A Second I Wish The Tide, Would Swallow Every Inch Of This City....."
Hmm,
Matt, will that work with my AA manifold and wastegate and what not??
If so, let me know where to find it
Rich
Cool,
Matt, I have the external wastegate already done, I am only running 8psi as high boost until mid summer when I can get my LC HG on the car, I also already have the 47lb injectors, and I intend on having my fuel pump upgraded as well...however, the fuel pump should be able to wait until I up the boost right?
Let me know what I have to do for 8psi, I have the tuning lined up as well so no worries there...
Rich
Sounds good,
Do you know where I can get that turbo through?
Turbonetics?
Let me know bud....
and how much do they run for?
Rich T.
Whos doing the tuning for you rich?
www.cheapturbos.com is one place that has it for $650
Let me know what you do with the 20g, i might want it.
-Dan | '99 911 C2 | '02 M3 | '91 318i
Matt are you saying if you were to buy a T3/T60-1 it would bolt up to the AA exhaust manifold and all you would need is the right engine mount changed.
I see cheapturbo listing it for $650.00 is this for the complete new turbo.
AA wants $900.00 for this upgrade and that using my old one.
Rich let me know what you end up doing I would not mind going with the T60 and run it on my stock compression.
AA Stage 1 Gen III, BMP head gasket, Bored Throttle Body, 3.0"DnPipe & Custom exhaust with AA Gen 2, Aquamist 1s water/methanol injection,
Last dynojet Aug 02 248c SAE 369whp/354ft-lbs at 10.5psi, 1/4mile 12.6@116mph
New Sept 02 Head work and exhaust porting, April 04:UUC Pulleys, Turbo to intercooler pipe 2.5" Aug 04 3.5"HFM,11.5psi
Yes $650 is for a complete new turbo. I got my T3/60-1 HiFi from there. Great service there too. I had to rebuild my turbo and wanted to get it heat coated too. And he sends it back to me with a polished compressor for no charge.
Newbie question:
Whats the difference from the T/3's and the T/4's?
[QUOTE]Originally posted by M3TurboCa
[B]
Yeah that's 900.00 for the upgrade plus another 300-350 for rebuilt and labor.
96 M3, GT4094R, Arrow Rods, CP Pistons, Elring HG, cutring 87mm, 10 mm ARP studs,MS3pro, EMC Intercooler, n54 6 speed with Motiv twin disk, ZT-2 wideband, Zionsville Radiator, X-brace, H&R springs with bilstien shocks, QTP electronic cutout, Line Locks, stock exhaust 455rwtq, 453rwhp at 14 psi 91 octane.......684rwtq, 681rwhp at 24 psi running flex fuel E60 at time of dyno tune.
Sounds like a plan...Dan I'll let you know where my 20G ends up in the plan, it's all yours if I go with the T60-1, thanks for the help guys!
Rich
can anyone help me out?Originally posted by CeeP
Newbie question:
T3 vs T4 is mainly size with the T 4 having the larger size flange and larger turbines housing wheels etc...
1995 M3 Custom Turbo, Turbonetics T66 BB,72lb injectors, Sias Tuning PnP Tec 3, IBM T30,PLX M250 wideband O2 sensor,Blitz SBC-iD Built low CR 8.5:1 motor CP Pistons,ARP head & main studs,Metric Mechanic HP Valve springs,walbro 255hp,BMP FPR,Modified fuel rail # 6 SS feed line,3in ss custom magnaflow exhaust,Lower level turbo intake,AA six puck disc, Spec Stage IV PP ,AA differential bracket,AA strut tower brace,UUC UD Pullies,UUC short shifter,UUC tranny mounts,UUC clutch stop,Fluidyne HP radiator.M3 LTW wheels Est..1001 rwhp!
Http://members.cardomain.com/bassmasterM3
(DIY custom turbo)
as far as I know AA doesnt use T3/60-1, they use a 60-1 mated to a tdo6h mitsubishi turbo.
I got mine at www.turborepair.com
If you do get the T3/60-1, save up for a scavenging oil pump coz you might have some oil drainage issues.
a .82 AR t3 is alot bigger turbine than the td06 and with that t3 you will still spool the 60-1 up...farily quick and still have alot of topend that the td06 housing would be a big restriction to.
I'll be using the .82 AR t3 on my 2.8 auctually.
I don't think the oil pump is nessary on a t3, eric doesn't use one i know. But if you want, it can be picked up for $200.
Which is a better setup? The T3/60-1 or the T3/60-1 HiFi? Will the HiFi fit w/o changing the motor mount? What is the difference in power production? Anyone know what kind of power at 8psi with stock compression and no race gas I could expect?
Lotus Elise: A pure sport car. A true enthusiasts car. It's no muscle car nor grand tourer. Purely a featherweight with no unnecessary driver aids that take away from the driving experience. No dynamic stability management. No active yaw control. No magnetic self adjusting dampers. No electronic brake distribution. No traction control. No throttle by wire. No all wheel drive. No sequential paddle shifters. No power steering. No power mirrors. No heated 8-way power seats. No sound deadening materials. No cruise control. No cup holders. Sure, it's small, loud and impractical. If you want quiet, buy a Lexus. If you need to haul a lot of stuff, get a minivan. If you need to stretch out, rent a limo. But if you want to go fast, seriously fast, sit down, strap in, shut up and hang on.
1995 Technique Tuned Turbo M3
2005 Lotus Elise
The HiFi, you wont have to change your motor mount. Its a 3in induction.
FYI, the 60-1 "Stage3" setup AA uses is the regular TD06 20G Mistu rear end mated to a Garrett T04E housing with a 60-1 compressor wheel in it. That's it and that's what I'm running right now, except my turbine wheel is clipped ~ 10 degrees for better top end flow.
I'm going the oil scavenging route as well, along with reducing some of the oil pressure that gets to the turbo---too freakin' high.
What are or is the main(s) difference(s) of a Fully T4 vs. T60-1 ??
I bought a fully T4 and I will upgrade my current T3/T4...
Thanks!
Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
T3 vs T4 main difference is the size of the turbine and wheel options. Just as a guess....a .58 O trim T4 (small) is probably about the size of an T3 .84 or >stage III wheel.(larger T3) If using a 60-1 compressor wheel? It will remain the same size in both application.
My turbo. Turbonetics T4 60-1 Hifi .70AR "O" trim wheel.
(DIY custom turbo)
