is there a thread discussing how to revive the rubber? it sweats under the sun and gets tacky
Id like to know as well
Gummipfledge.
White is Right, Steel Grey is OK, but Estoril is the only color that truly matters.
I like Coupes.
Is that a cleaner? A dye?
Its a miracle.
If you can find any.
I like Coupes.
Well, the vinyl which these airbag covers are made of is a polypropylene which does off-gas forever leaving an oily residue and that might be the reason it seems sticky. The more these are exposed to UV only aids to this stickiness.
Grab a wet rag, heat it in the microwave for 3 minutes. Wipe the airbag off. Do this several times. Allow to dry between wipes.
But dont burn yourself while pulling the wet rag out of the microwave. I'm not responsible if you do.
This same thing works for your sticky steering wheel too.
