so what's the rack from, cause if we can't get one here, won't do us any good.
especially in terms of rebuilds etc.
subscribed
This is actually kind of exciting. I know its going to be a good product because of his detail to his other builds. Can't wait to hear the end results!
so the first pics of an installed rack, about the brackets of the shaft, similar thought as in the picture nr 2
so here goes, I haven't driven anything yet, this is just to get it fitted to understand what kind of modifications are recquired (with the v12 some have to be made
the tie rod is extended too far, I know, working to get round this, some parts will be machined soon
oil stains are from the steering liquid, sorry not clean
but here the conection can be seen, that connects the shaft with the rack, some more pics comming up
brackets are just in one line with the oil pan of v12 on e30 engine mounts
and here is the biggest problem with the v12 engine, not relevant to the six cylinder engines
no place for the inlet pipes, and the rack is slightly touching the exhaust header/pipe, but my engine has 10mm spacers between the pipe and the header, so not yet sure how it compares to the stock, but the good thing is that the silver part can be rotated to the other side and bolted down in the very same place, just with the inlet pipes facing opposite direction, where is plenty of room. the pipes in the picture must be modded.
the car on its wheels on the ground in the correct position.
view from the front
hard to see but here is the connection between the shaft and rack from the open hood view
if all goes well next week I could finally give it a try on the road. this is not the end result yet
sorry for the dirty and oily underside, lack of time to get it cleaned
Looking good!!! Still smile looking at the underside of an e34 with 4 downpipes...
"Big Red" 9/88 Build 535i/5: E.A.T. Chip, 24lb Bosch Design III, 3.46 LSD, 4x Clear corners, DINAN-style 750i muffler, Racing King Subframe Inserts, Koni/Vogtland suspension, E34 M5 swaybars, Brembo/Porterfield brakes, Turbodiesel grills, 16" Style 8 rims, Euro front plate, M5 rear filler plate.SaveSave
Lookin good
sign me up
I can't wait any longer.
Sounds expensive but yes I am interested
K&N Panel Filter/PIAA Super White Bulbs/Superblue ATE Brake & Clutch Fluid/Redline ATF fluid/Redline 75w-90 Diff Fluid/3.15 LSD/Understeer Short Shift Kit/ZHP Shift Knob/ TMS SS Brake Lines/UUC SS Clutch Line/Brembo Drilled Front Rotors/Brembo Blank Rears/ Hawk HPS F&R Pads/X-Brace/UUC F&R Sway Bars/H&R Sport Touring Cup Suspension Kit/Rear Shock Mount Reinforcement
I'll take one... How much?
Subscribed. I hate e34 steering.... and I have a 100% all new front end with Lemf/Meyle parts too. (minus the steering box and pump).
e30 84 340i m6x powered.
e34 89 535i 5speed - current DD
e24 89 635csi - maybe a DD?
e34 93 525i (m50tu) - gone
e39 540i 6spd m-sport - gone
e53 x5 4.4l - gone
e30 89 325i (m20) - gone
So still not going to let any of us know what the rack is off of?
"You may all go to Hell, and I will go to Texas."
Davy Crockett
www.Angry-Ass.com
My Build Thread Part 1, Part 2
DIY E31 X-Brace Mod and Install
DIY Rear Seat Backrest Modification for E32 Armrest
Man, this thread could sure use another update.....
No joke, Im pretty sure everyone in the sub-forum is just itching for an update and details.. I am.
Patience guys, I know everything has slowed down, but it is still going forward. some of the last brackets have been made and given to powdercoating + the polyurethane thing arrived just this morning. I can't wait to get it all tested myself, but the beemer is without the gearbox at the moment as well. + some unexpected mods for steering column are being performed just as I am typing this post and some other duties also stand in the way of devoting my complete time to the e34, need cash for all this you know
the rack is from a bmw ( by now that's it)
Sooo its a flipped RHD rack.... kinda looks like an e60 rack because of the removable steering shaft housing.
Have you checked to see that the rack has enough throw to get the same turning degrees of the box setup? The box and linkage has a TON of throw for what it is...
link to e30pickuptruck build thread
^driven coast to coast
Oh... so this is only for LHD?
def subscribed
Are there no LHD rear steer BMW racks?Originally Posted by mikeday1036
Ok. Guess that makes this swap harder for those of us with LHD cars. It would mean importing RHD racks.Originally Posted by mikeday1036
Just found out the e21 had power rear steer racks.Originally Posted by mikeday1036
Last edited by eightynine535; 07-27-2012 at 02:15 PM. Reason: Automerged Doublepost
so the long awaited updates have arrived
this is the next part of the set, the polyurethane flexible joint, I was also experimenting with the steel joint with the (driveshaft type connection) but there is not plenty enough room if we use the OEM parts + the oem parts don't fit directly in the end of the steering column.
the bracket is bit rough, but it is made of 4 mm thick steel bars/girders (whatever they are named correctly) + I made it using an old stock bracket for the steering column of e34, so no cutting/welding or modifying the stock parts, bolts on with 3 bolts, the shaft in the picter had to be shortened as well.
here is a crappy pic of all this in the place, the stock rubber boot was kept in its place
if you remember, the rack was touching the exhaust header, now it clears beautifully
this was achieved by lowering the axle carrier by 20mm
engine kept in the same position by swapping the e30 motor mounts to e34 24v ones
this also gave a bit better clearing to the tie rods
the tie rods recieved their 30mm extensions
the pipes atached...
here is the view of axle carrier lowered, engine lifted
and if you can spot some differences, here is a clue why this is taking so long
before
after
about the bent pipe on the rack I know, don't like it myself, but I got another rack of this type to improve this, but not to slow down the progress this will be done separately, however this pipe issue does in no way affect the R6 engines, not sure yet about the v8s 50/50 that it could clear.
the electrician is comming the following morning, and hopefully I will be able to try it out on friday ( the wiring of M73, is installed instead of m70)
cheers!
