Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 131
Thread: The Official E38 Transmission Info Thread
  1. #101
    Mar 2012
    Blakeslee, PA USA
    1995 bmw 740IL
    Quote Originally Posted by Slimm View Post
    why is this not stickied?!
    Nobody knows lol
    "There can never be peace without war"
  2. #102
    Orlando, FL
    Two '01 740iLs
    It's in the DIY sub forum...
    - Sean
    RIP Blitzkrieg
  3. #103
    Feb 2012
    Bottom of a Bottle
    96 740il, XJS & CBR1000F
    Adding Lubegaurd with filter and fluid change @ 225000 miles. I don't know if there has been a previous change but I doubt it from the mud that came out when I topped it off. Have had some slippage/shudder at highway speeds. Waiting on stealership to tell me if I need valve body rebuild (check ball issue on early 5HP30).
    Correspondence with them is as follows.
    I am changing the filter and fluid and would like to make sure your products are compatible as well as know which one you recommend to add at this time and in what amount. Vehicle is a 1996 740IL
    Thank You
    Thank you for contacting us!
    Lubegard Platinum Universal ATF Protectant is the recommended product for a 1996 740IL. Use one, 10 ounce bottle.
    Please let me know if I can do anything else.
    Best regards,
    Elise Haviland
    206-762-5343 x 14
    206-762-7989 fax
    Also have bought Dipstick and will see about modding it in.
    http://www.amazon.com/Lokar-TD-3727F.../dp/B000COMNPO
    The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
    When answering my questions please use a qualifier if you are not sure.
    The more I work on this car the less I respect German engineering.
    When you speak in Absolutes you are always wrong!
    Semper Fi
  4. #104
    Arizona
    2015 328i M Sport
    Quote Originally Posted by Hueristic View Post
    I have that lubeguard additive it Definately smoothed my shifts out. Seems to run more optimal when hotter outside since the additive disperses the heat throughout the transmission and helps keep it cooler. About 27k since I first serviced it. Still doing pretty well at 296k.
  5. #105
    Feb 2012
    Bottom of a Bottle
    Quote Originally Posted by M I C H A E L View Post
    Good to know.
    Semper Fi
  6. #106
    Feb 2012
    Bottom of a Bottle
    I can confirm that the FEBI filter is fine on the 5hp30. There were 2 O-rings included. It looks to me like they added the larger diameter O-ring to the kit. The thinner ring was in a plastic bag as the Larger diameter O-ring was placed on the filter. I checked the diameter of the thicker one (one on the filter) and it matched the original I removed. I tossed the thin one. I have no clue why they didn't toss it themselves as it caused some confusion and was not mentioned at all in the docs. I want to thank Shogun for his extensive research into this and the PM's he answered for me. Once again The FEBI is fine and as long as you use the correct diameter O-ring you will not get the whine which in fact is the sound of sucking getting past the smaller o-ring. BTW I used the Maxlife and added Lubegaurd PLATINUM Universal Automatic Transmission Fluid (ATF) Protectant and Permatex Automatic Transmission RTV Gasket Maker on both sides of the included gasket. 2 weeks with no issues and smooth shifts. I will post in this thread if there are any failures.
    I communicated with both Lubegaurd and Permatex engineers to assure compatibility during my research before I made my decision on what products to use and combine for the change.
    Links:
    http://www.amazon.com/Castrol-03521-.../dp/B008MISBQW
    http://www.lubegard.com/~/C-113/LUBE...ATF+Protectant
    http://www.permatex.com/products-2/p...t-maker-detail
    Semper Fi
  7. #107
    Surrey, BC
    Canada
    great thread.
  8. #108
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Wasn't this thread in the Parked Threads section?
  9. #109
    Feb 2015
    Provo, Utah
    1998 BMW 740il
    I don't have time to read through everything. Does I have a 97 740i that has a supposed bad tranny. Sometimes reverse and will try to move forward if the car is already moving forward. What are my chances that the tranny is alright, but my torque converter is fried or I have a bad sensor? Also. Could someone let me know all the sockets/tool sizes I need for removal and installation of the 5hp24. Thanks
  10. #110
    Dec 2011
    Lancaster CA
    Quote Originally Posted by GWalker View Post
    This is a big job. You need a lift and a stand to do it safely and you need to remove the exhaust. There are several threads in exhaust and trans removal so search those. You can also go to e38.org to search.
  11. #111
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Quote Originally Posted by kouks View Post
    It's in the DIY section. The original is left in the main forum for discussion.
  12. #112
    Feb 2015
    Provo, Utah
    1998 BMW 740il
    I know what I'm doing for the most part. I used to work at a performance shop. So i know most. I've just never done bimmer tranny work
  13. #113
    Feb 2012
    Bottom of a Bottle
    All I can add is that I will never do another Guibo bolt on jack stands!
    Semper Fi
  14. #114
    Feb 2015
    Provo, Utah
    1998 BMW 740il
    Tranny is swapped. I Never Want To Do That On Jack Stands Again LOL
  15. #115
    Feb 2012
    Bottom of a Bottle
    Hahahaha, I think all that have done it will agree on that!!!!!!!!!!!!!!
    Semper Fi
  16. #116
    Jul 2015
    SoCal
    '00 740iL
    So, after hundreds of thousands of miles, do we have the final verdict for Maxlife? Use it or avoid it or at your own risk?
  17. #117
    Feb 2015
    Provo, Utah
    1998 BMW 740il
    Quote Originally Posted by plokiu View Post
    <img src="http://www.bimmerforums.com/forum/attachment.php?attachmentid=557872"/>
    When you can. Royal purple. And I ALWAYS add a full bottle of lucas full synthetic oil additive
  18. #118
    Jun 2016
    Coolidge, Arizona
    1999 BMW 750iL
    Hello. I have a 1999 750iL. 89,500 mi. I am going to change fluid and filter. Any suggestions as to which brand I should use? I live in Arizona,USA. Temps in summer reach a daily average of 110-115 degrees. At present time my tranny makes a loud "whining" noise when shifting from first to second gear. Any advice would be greatly appreciated.
  19. #119
    Feb 2012
    Bottom of a Bottle
    Links:
    2 year update, All is well.
    Semper Fi
  20. #120
    Jun 2016
    Coolidge, Arizona
    1999 BMW 750iL
    I bought fluid , gasket & filtran filter. I paid $16 for filter. seems like it should cost more. Any thoughts ?
  21. #121
    Dec 2011
    Lancaster CA
    Quote Originally Posted by pegasus19642000 View Post
    I have one I'll sell you for $100, free shipping. No, the $16 price is about right.
    I am a purist and only use either Pentosin ATF1 (direct fluid supplier to ZF) or the Lifegaurd 5 OE fluid. The Valvoline MaxLife seems to work for most everyone without issue so you can use that too, but still its not OE. If you do use MaxLife, you will have to do a complete flush, since the OE oil and MaxLife are completely different blends and it is specifically written on all trans maintenance manuals to NEVER mix different fluids in the trans.
  22. #122
    Dec 2013
    Uppa US
    2003 325xi Wgn+Suburbans
    Lots to read!
  23. #123
    Long Beach, CA
    '01 M-Sport/'01 986
    About to do this job, does the Lubegard ATF protectant work for the late model 5hp24 units? I have a 2001 740i.
    If so, is it the Lubegard 60902?
    Join the SoCal E38 owners group on Facebook http://facebook.com/groups/officialdistrict7
    ... and on Instagram
    @district7_socal
    Subscribe to my YouTube for E38 content-->
    https://www.youtube.com/c/ARPerez
  24. #124
    Feb 2012
    Bottom of a Bottle
    I can confirm that the FEBI filter is fine on the 5hp30. There were 2 O-rings included. It looks to me like they added the larger diameter O-ring to the kit. The thinner ring was in a plastic bag as the Larger diameter O-ring was placed on the filter. I checked the diameter of the thicker one (one on the filter) and it matched the original I removed. I tossed the thin one. I have no clue why they didn't toss it themselves as it caused some confusion and was not mentioned at all in the docs. I want to thank Shogun for his extensive research into this and the PM's he answered for me. Once again The FEBI is fine and as long as you use the correct diameter O-ring you will not get the whine which in fact is the sound of sucking getting past the smaller o-ring. BTW I used the Maxlife and added Lubegaurd PLATINUM Universal Automatic Transmission Fluid (ATF) Protectant and Permatex Automatic Transmission RTV Gasket Maker on both sides of the included gasket. 2 weeks with no issues and smooth shifts. I will post in this thread if there are any failures. I communicated with both Lubegaurd and Permatex engineers to assure compatibility during my research before I made my decision on what products to use and combine for the change. Links: http://www.amazon.com/Castrol-03521-.../dp/B008MISBQW http://www.lubegard.com/~/C-113/LUBE...ATF+Protectant http://www.permatex.com/products-2/p...t-maker-detail
    3.5 years and still shifts perfectly.
    Semper Fi
  25. #125
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    Since this thread was bumped...
    I just recently had to drain and flush my transmission again. The Valvoline Maxlife was causing the car to fall out of gear after long drives when hot outside. Got the correct ZF Lifeguard 5 fluid and it has been working great and shifting great again. Skipped the Lubeguard this time. *Knock on wood* it keeps on running!
