that's super awesome maybe if i ever decide to rebuild the transmission if it ever starts to go out on me, ill replace gaskets and what not and get everyything cleaned!
Updated
Last edited by TheLadiesMan; 07-12-2012 at 01:52 PM. Reason: Automerged Doublepost
- Sean
RIP Blitzkrieg
Any more info?
- Sean
RIP Blitzkrieg
Anybody got anything else to add?
Tyler?
Ill be working with Kirt Koeller soon to develop this more...
Its on my to do list.
Updated/bump.
- Sean
RIP Blitzkrieg
Look at the first post. Dates are listed there.Originally Posted by KiltedMan
2000 BMW 740iL | 225,XXX miles | VW MAF | Bavarian Auto Coils | Timing Chain and Guides DIY Complete | M60 Manifold | BDC Polished Throttle Body| Custom Tuned | Performance Gearing 3.46 LSD| Magnaflow mufflers |
|1997 ///M3/2/5 | 104,XXX miles | Boston Green Metallic|2006 X3 3.0 SAV|121,XXX miles| Silver|
I think there's more to update on substitutable fluids if im not mistaken... i just feel like we are missing a bunch..
If you find them, Post 'em up!
- Sean
RIP Blitzkrieg
AMSOIL Universal Synthetic ATF
Castrol Import MV ATF
Exxon Superflo ATF
Kendall VersaTransT ATF
Mobil 1 Synthetic ATF - Is not applicable as well.
Mobil Multi-Vehicle ATF - IS not for zf5hp24 transmissions, only for gm.
Quaker State/Pennzoil Multi-Vehicle ATF
Pentosin ATF 1
Puratech Multi-Vehicle Syn-Blend ATF
Redline D4 ATF
Shell ATF 3403 M115
Shell M1375.4
ZF Lifeguard fluid 5
Valvoline Maxlife DEX/MERC ATF
Do you have a source for that information?
- Sean
RIP Blitzkrieg
Red line D4 atf
Site Claimed
Esso LT71141
(BMW, 93 on 3, 5 and 7 series ZF 5HP transmissions)
(VW/Audi automatic from 1993)
Shell LA2634
(BMW Automatic 98-00 3 series, 94-95 5 series, 98-00 528, 94-00 7 and 8 series)
http://www.redlineoil.com/product.aspx?pid=51&pcid=9
ZF OEM Replacement fluid for 5hp24 and 5hp30'S!
http://www.tsgparts.net/index.php?p=...parent=70&pg=1
Claims for 5hp18 and 5hp30 5hp24,
Note, claim for LT71141 5hp24 & 5hp19 but not for LA2634 for the 5hp30
See char
http://www.nordiques.com/pieces/imag...huiletrans.pdf
Site Claims for LA2634 for 5hp30 and LT71141 5hp24
No claims are made on the bottle its self!!!
Ps I used this fluid on my 5hp30 unit, works just fine and its made by shell also the maker of LA2634
http://www.pennzoil.com/other-car-pr...mission-fluid/
http://www.epc.shell.com/Docs/GPCDOC...10624110_2.pdf
Application chart
http://www.castrol.com/liveassets/bp...s_ImportMV.pdf
Printed back of the bottle
Updated/bump Thanks Actros!
- Sean
RIP Blitzkrieg
Updated once more
- Sean
RIP Blitzkrieg
Is there a way to mark special threads, like this one, or to print them out for reference?
You can copy and paste the post into MS Word, copy the pictures, and save the pdfs. Then put all the files in one folder.
- Sean
RIP Blitzkrieg
Or print each relevant page to pdf, which should be easier
The World is ruled by Kings and Queens that blind your eyes and steal your dreams.
When answering my questions please use a qualifier if you are not sure.
The more I work on this car the less I respect German engineering.
When you speak in Absolutes you are always wrong!
Semper Fi
can we please also add the proper steps how to actually perform the transmission fluid procedure, dropping the pan, ( servicing under the correct temperature) engine without load, A/C on, amount of quarts of fluid youll be using ect, ect...
It's there. I just added a 'How to check fluid' section. More info is in a few of the pdfs
- Sean
RIP Blitzkrieg
Good lord...
You know I just copied the old post to the DIY right?
Thats why I let them percolate...
My bad.
P.S Could you rename it so it says 'Info/Resource'
Last edited by TheLadiesMan; 08-27-2012 at 09:51 PM. Reason: Automerged Doublepost
- Sean
RIP Blitzkrieg
if your going to drop your transmission here is a list of parts you should replace while the unit is out:
Input Shaft Seal - 24311422671
Rear Main Seal - 11141710247
Transmission Mounts (2) - 22316771130
Main Seal Flange Gasket - 11141736521
Output Shaft Seal - 24131422667
Rear cover gasket - 11141729836
new filtran filter with O-ring and oil pan gasket
transmission fluid
might as well change the diff fluid as well
correct me if im wrong or if im missing stuff
5hp30 Valve Body rebuild links, The Valve Body Kit aka (VBK) mainly address the check ball shrinking problems that ONLY AFFECTS THE 5hp30! IF YOU HAVE A 5hp24 UNIT dont WORRY the problems has been rectified. The Kit also updates a few components like the the shift selector plunger, changes in length and strength on several springs for the shift pistons, new paper gaskets, new and improved Rubber O-rings for the shift solenoid, new TCM plug Rubber seals and New orifices. Below are links to VB rebuild!
Very detailed commentary with pics
http://www.e38.org/e32/e32%20transmission%20valve.pdf
A Straight forward guide, step by step with instructions and lots of pictures written by Jeff Chia
https://docs.google.com/viewer?a=v&q...dSyAerQb0UhI2w
We need to reorganize this, its getting too wild with fragmented info
Updated. Added cameroguy's rebuild thread, and a video by ECS tuning.
- Sean
RIP Blitzkrieg
