I'm installing what I think is an F1 Racing Stage 2 clutch on a Stock E36 M3 (S52) flywheel. When I mounted the clutch with the flywheel sticker towards the flywheel it looked like the springs sticking out (the fat side) would contact the flywheel bolts. I flipped it and it seemed like everything bolted up smoothly. I'm going to call Griptech tomorrow, but what you said makes sense. I'm going to test it by putting it in 5th gear and turning the engine over, then seeing if the clutch will disengage. There were no instructions, where did you find this? Thanks.
Cloudbase,
I learned the hard way, and had to remove the transmission all over again, you have to be careful; i have heard of a few cases where people have installed this clutch the wrong way and it welds itself to the pressure plate.
It has been almost a year since my install, so i had to reread my post. I uploaded a PDF document detailing how to install a Stage 2 F1 Clutch w/ F1 Chromoly Flywheel & supplied SACHS pressure plate. I talked to gripforce and the technician said to install it with the fat(sprung) side of the clutch facing the flywheel, which is what it shows on my document.
I have not had any issues with it installed this way, and it has been driving great after my 750 mile break in period. Good luck!!
<-----------He is correct! Thanks for your quick reply Taylor.With the stock Dual Mass flywheel you would install the clutch with the fat side facing towards the pressure plate and most of the times with a LightWeight Flywheel/sprung clutch combo you install the clutch with the fat side facing towards the flywheel.
-Taylor
"That Hood scoops gotta be worth at least 5 horsepower!"
"Theres the right way, the wrong way and the way we are going to do it".
-My dad.
Thanks guys. Installing it with the fat side towards the pressure plate made sense when I put the pieces together.
I talked to Grip Force today and tech I talked to said you couldn't use a sprung clutch with a stock flywheel. Obviously you can, as has been stated in this thread. BUT - this car will be up for sale soon, and I don't want to take any chances and burn the new owner or my reputation. I'm going to pull the F1 clutch and pressure plate and install a stock unsprung disk and pressure plate. I can ditch that crappy F1 throw out bearing too. Not stoked to pull it all apart, but it wasn't completely buttoned up yet either. The piece of mine will be worth it.
Cloudbase,
I totally missed the part in your first post about you using a stock flywheel with an F1 sprung clutch. I just assumed you were installing the kit, sorry if i sounded like a broken record on my response. I am glad you have a game plan though for your soon to be sold car, it is always a gamble sometimes mixing aftermarket with stock, so i think you are making a wise decision going full stock to sell the car. then you can let the new owner make that decision. Stadrift11 was right on target.
-My dad.
Ya I learned the hard way too. First tranny wouldn't go in all the way I thought it was just tight and shoved it in . Was missing like 2 mm for tranny to go in all the way but shoved it in. 1st started the car and whining noise then disappeared after 3 min. I thought I didn't properly oil some oring anyway. Clutch in all the way would grind so installed clutch stop. Long story short drove 15 -20 miles went back to my garage and ripped everything apart in one night. 3 glasses of Scotch later and about 6 hrs of labor i found that the pilots bearing sleeve tip was bent cracke and torn to pieces as it was grinding against clutch as the clutch was in the WRONG FKN WAY! INSTRUCTIONS GIVE YOU WRONG FKN WAY + what throws you off is instructions say follow FKN Service Manual WTF! OK so glad it dindn't do any more damage so will be putting it in again tonight FAT SIDE FACING LIGHT WEIGHT FLYWHEEL TOWARDS THE ENGINE PEOPLE! Or you will end up breaking something and doing the job twice! My car is e46 m3 and I bought Grip force stage 2 clutch and steel light weight flywheel not aluminum. 14-15 pounds. Almost half weight of stock or so. GripForce is good stuff they sent me SACHS pressure plate clutch is SACHs too, and I think the only thing they make is the flywheel. Also got Pilot bearing and throwout bearing with the kit for 6 bills off ebay. Same shit sells in a store for over 1 K. So if you read somewhere that this is shit product it's probably installed BACKWARDS hence it failed! INSTALL CORRECT THE FIRST TIME ==============ENGINE<-FLYWHEEL-<-FAT-SITDE of CLUTCH-<-Pressure plate. DONE.
Labedra,
Glad to hear you got it all back together! Those transmissions are not fun when your trying to get the driveshaft pin in place without damaging anything. Which is where the scotch comes in handy, thats why i want to build a nice mini bar in my garage. Someday i guess.
Also, I agree; the gripforce kit is a nice kit for the $$, i was impressed by the flywheel, happy they included a sachs pressure plate and completely unimpressed by their instructions. When i actually called the first time to ask the orientation, they guys tells me "well, theres a sticker on the outside of the bag on the side you should install toward the flywheel". In which i responded "How the hell am i supposed to know that! Who pays attention to an unmarked orange sticker on the outside of the bag? Especially when the instructions do not mention it?" That's when they sent me to a tech, and i got all the answers i needed.
-My dad.
Yeah Alex. It feels like it is riding on the flywheel bolts. Made me nervous but all was well on both the vehicles I swapped.
I used the M5 friction discs though, due to track activity.
m
I will be doing a clutch replacement on a 1998 318ti I just bought and am thinking about going this way. Any new upudates on this thread? I was hoping to put in a lighter flywheel and a sportier clutch. I'm seeing the kit for about $430 from grip force. Is there anything I should be cautious of when i do this?
Hi guys
Anymore updates it opinions on these clutch kits?
I'm looking at replacing the clutch in my 1.9 supercharged z3. The f1 seems great value but I'm nervous To good to be true?
Also running this kit on my S52. Works great, 1500 miles on it so far. Dont use the pilot or throwout bearings that come with the kit.
