Some might remember that the bushes at the bottom of the LAD shocks made of rubber are vulcanized onto the inner metal tube. No spare for these available, it is also not possible to separate the metal bush and the rubber.
Now here comes the new version, especially made. We are testing soon some sets on 750iL with LAD. These bushes fit on LAD shocks, (maybe not on EDC and normal shocks, not tested).
before
http://www.abload.de/img/img183ubkpk.jpg
old defective bushing removed
http://www.abload.de/img/img184igjzr.jpg
new bushing set
http://www.abload.de/img/img193xykwm.jpg
http://www.abload.de/img/img1854dkra.jpg
http://www.abload.de/img/img186wxj15.jpg
http://www.abload.de/img/img18791kgl.jpg
http://www.abload.de/img/img188kdj82.jpg
http://www.abload.de/img/img189o4kko.jpg
http://www.abload.de/img/img190ffjd9.jpg
http://www.abload.de/img/img192piktu.jpg
Material Polyurethane PUR Shore 80. The production is not that easy. Poly needs to be cooled with liquid nitrogen before it can be machined on a lathe. The steel bushes are made of special, high resistant steel used for example also for injectors in large scale diesel engines and can stand several thousands of bar.
The new bushings are 2-piece, which are an easy fitment, do not need to be pressed in. Yes, the only really difficult part is removing the old bushings.
will these work on a 735iL , most likely yes but i have to ask, and also how do i obtain them?
Shogun, do these fit on early and late model struts. Been told my 740 uses a different strut than the pre '92 models, and don't know if this affects the size of the bushes or not. I am interested if they do, as one of mine is shot!
they will work on E34 and E32 LAD/SLS shocks. Maybe not fitting to EDC shocks (not yet tested/measured). These have been made in 2 batches now, 2012 and 2014. Now another batch has been made. Size for the lower hex bolt is always the same over all production years, M14X1,5X85
http://www.bimmerboard.com/members/r.../E34shock2.jpg
http://www.bimmerboard.com/members/r.../E34shock1.jpg
http://www.bimmerboard.com/members/r.../E34shock3.jpg
http://www.bimmerboard.com/members/r.../E34shock4.jpg
http://www.bimmerboard.com/members/r...al/accubad.jpg
http://www.bimmerboard.com/members/r...l/accugood.jpg
explanations from here http://www.bimmerboard.com/forums/posts/1261417/
Ordered several new sets at my risk for stock. 1 set = for 2 LAD/SLS rear shocks for E32 and E34 = 1 car. Price per set shipped by air small package $110. Send me a PM, Even if your bushes are still o.k. now, one day you will need a repair kit.
Some sets (set = for 2 SLS/LAD rear shocks = 1 car) left on stock. Shipping can be made immy. some more pics http://e32b12.blogspot.jp/2013/04/rearstrutbush.html
Here pics, ready installed. Important is that the original metal shell in the bottom eye remains, so only remove the rubber and the center sleeve
Got new stock, a few sets only
http://3.bp.blogspot.com/-rpo5wobepH...uA/s1600/3.jpg
http://1.bp.blogspot.com/-xPqy5V1IpN...7k/s1600/2.jpg
http://3.bp.blogspot.com/-wq-pQfciwy...-U/s1600/1.jpg
@eddycooper: 1 set = for 2 LAD rear shocks for your E34T shipped to Calgary
@barry964: 1 set for your E34 525 Touring shipped to Liverpool, UK
Didn't we determine that the bushings for SLS/LAD, EDC, and normal shocks are all the same?
The thread started in 2012, then we did not know this.
All received here. I'm impressed, that's a quality piece of work! Thanks a million, Barry
Hi Shogun, sent you a reply regarding these! Thank you
What is the price shipped to 91411? Danke
O o
/Ż____________________________ ______________
| BLAAAAAAAAAAAAAAAAAAAHHHHHHHH! !!!!
\_ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
