Results 1 to 12 of 12
Thread: FS: Poly bush repair kit for LAD shocks
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Some might remember that the bushes at the bottom of the LAD shocks made of rubber are vulcanized onto the inner metal tube. No spare for these available, it is also not possible to separate the metal bush and the rubber.
    Now here comes the new version, especially made. We are testing soon some sets on 750iL with LAD. These bushes fit on LAD shocks, (maybe not on EDC and normal shocks, not tested).
    before
    http://www.abload.de/img/img183ubkpk.jpg
    old defective bushing removed
    http://www.abload.de/img/img184igjzr.jpg
    new bushing set
    http://www.abload.de/img/img193xykwm.jpg
    http://www.abload.de/img/img1854dkra.jpg
    http://www.abload.de/img/img186wxj15.jpg
    http://www.abload.de/img/img18791kgl.jpg
    http://www.abload.de/img/img188kdj82.jpg
    http://www.abload.de/img/img189o4kko.jpg
    http://www.abload.de/img/img190ffjd9.jpg
    http://www.abload.de/img/img192piktu.jpg
    Material Polyurethane PUR Shore 80. The production is not that easy. Poly needs to be cooled with liquid nitrogen before it can be machined on a lathe. The steel bushes are made of special, high resistant steel used for example also for injectors in large scale diesel engines and can stand several thousands of bar.
    The new bushings are 2-piece, which are an easy fitment, do not need to be pressed in. Yes, the only really difficult part is removing the old bushings.
    Jan 2012
    Dumont,NJ
    1992 BMW 735iL
    will these work on a 735iL , most likely yes but i have to ask, and also how do i obtain them?
    Mar 2014
    Victoria, Australia
    1993 E32 740iL
    Shogun, do these fit on early and late model struts. Been told my 740 uses a different strut than the pre '92 models, and don't know if this affects the size of the bushes or not. I am interested if they do, as one of mine is shot!
    Jan 2005
    Japan
    they will work on E34 and E32 LAD/SLS shocks. Maybe not fitting to EDC shocks (not yet tested/measured). These have been made in 2 batches now, 2012 and 2014. Now another batch has been made. Size for the lower hex bolt is always the same over all production years, M14X1,5X85
    http://www.bimmerboard.com/members/r.../E34shock2.jpg
    http://www.bimmerboard.com/members/r.../E34shock1.jpg
    http://www.bimmerboard.com/members/r.../E34shock3.jpg
    http://www.bimmerboard.com/members/r.../E34shock4.jpg
    http://www.bimmerboard.com/members/r...al/accubad.jpg
    http://www.bimmerboard.com/members/r...l/accugood.jpg
    explanations from here http://www.bimmerboard.com/forums/posts/1261417/
    Ordered several new sets at my risk for stock. 1 set = for 2 LAD/SLS rear shocks for E32 and E34 = 1 car. Price per set shipped by air small package $110. Send me a PM, Even if your bushes are still o.k. now, one day you will need a repair kit.
    Some sets (set = for 2 SLS/LAD rear shocks = 1 car) left on stock. Shipping can be made immy. some more pics http://e32b12.blogspot.jp/2013/04/rearstrutbush.html
    Jan 2005
    Japan
    Here pics, ready installed. Important is that the original metal shell in the bottom eye remains, so only remove the rubber and the center sleeve
    Jan 2005
    Japan
    Got new stock, a few sets only
    http://3.bp.blogspot.com/-rpo5wobepH...uA/s1600/3.jpg
    http://1.bp.blogspot.com/-xPqy5V1IpN...7k/s1600/2.jpg
    http://3.bp.blogspot.com/-wq-pQfciwy...-U/s1600/1.jpg
    @eddycooper: 1 set = for 2 LAD rear shocks for your E34T shipped to Calgary
    Jan 2005
    Japan
    @barry964: 1 set for your E34 525 Touring shipped to Liverpool, UK
    moroza's Avatar
    BFE
    E34T
    Jan 2005
    Japan
    The thread started in 2012, then we did not know this.
    Aug 2009
    UK
    BMW 525i SE Touring
    All received here. I'm impressed, that's a quality piece of work! Thanks a million, Barry
    Oct 2016
    Toronto
    1989 735iL, 1985 635CSI,
    Hi Shogun, sent you a reply regarding these! Thank you
    Apr 2017
    California
    1989 BMW 535i, 1993 740i
    What is the price shipped to 91411? Danke
    O o
    ____________________________ ______________
    | BLAAAAAAAAAAAAAAAAAAAHHHHHHHH! !!!!
    \_ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
  1. E30 Subframe, IE poly bushings,Sway kit, m50 swap
    By rbelton in forum Race Cars & Track Parts
    Last Post: 09-25-2010, 11:32 AM
  2. E39 FS: Vanos Seals Repair Kit
    By astigracing in forum Engines, Performance Parts & Software
    Last Post: 08-09-2010, 01:02 AM
  3. FS: e36 Sunroof Repair Kit
    By BMWMPow3r in forum Exterior Lighting & Body Parts
    Last Post: 09-29-2008, 04:13 PM
  4. Caliper guide bushing repair kits
    By dwvcfii in forum 1991 - 1999 (E36)
    Last Post: 09-03-2008, 09:35 PM
