Page 4 of 14 FirstFirst 12345678910111213 ... LastLast
Results 76 to 100 of 342
Thread: E34 540i/6 Turbo Build - The game is on.
  1. #76
    Newark 2 Nashville
    82 320i/4, 89 535i/5
    Talk to me about the rear... diff lock increased? Axles?
    E34 535i/5 (Dirty D)
    RIP E21 320i/4 (Hammerhead)
  2. #77
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by 5senses View Post
    Want to get a 3.15LSD, that's the only thing needed for the rear. That's only to have better traction hook up. I think everything else in the rear end will hold up just fine. I will replace the rear subframe bushings though, due to wear they have right now.
    There's lots of medium case/driveshaft E34s out there putting down nice power without many driveline issues. I'm sure the larger driveshaft/diff/axles are more stout than their medium brothers.
    Quote Originally Posted by xkaharianx View Post
    No fan on the radiator side? Might have a cooling issue there. With the front end stacked any room for one between the engine and radiator?
    Should be ok, with 2 12" in the front. Our weather climate here is weak. We don't have many hot days, and mostly cloudy/rainy days. If there is a cooling issue, I'll get another much larger fan behind the radiator, since it seems like I'll have some extra space right there.
    Intercooler won't restrict much airflow, plus I removed the AC condenser, so there was a factory installed air restriction to begin with.
    Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
    Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
  3. #78
    Baudette Mn
    18 Cummins 3500 00 330t
    I believe the 3.15 is only a 15% lockup. Does fine for stock power but I am not sure about FI.
    Kris,
    Does your 3.15 still let you put 11's on the road or are you stuck with a one wheel tire fire?
    Edit: thinking back His car hooked up pretty good. I don't see an issues with the driveline. As you said there are a ton of e36 with medium case drive lines putting down big power.
  4. #79
    VA
    E63AMG/Z31/Tacoma/F31
    My 3.23 is 25% IIRC and I still leave twin marks when I break traction with turbo.
  5. #80
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Bought a brand new miller syncrowave 200 this week and my DTA S80 has finally arrived (it seems like DHL uses snails to deliver their packages.) I'm getting pretty motivated right now to jump back into the build and build the manifolds.
    The E32 750il 3.15LSD also arrived and is ready for the install.
    I'm planning on ordering either 60 or 72lb ev14 injectors in a next week or two.
    No more updates other than this for now.
  6. #81
    Denver, CO, USA
    93 M5 88 M3 14 i3
    Looking good man can't wait for more updates!
  7. #82
    Aug 2009
    Bay Area
    E34 MSport
    I would replace the mounting bracket on that diff before you put it in... Mine snapped, leaving the diff supported mostly by the driveshaft in front. Ended up having to replace the entire rear subframe.
    +1 for when the updates arrive!
  8. #83
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by BruinBimmer View Post
    Replace it with what? New or something out there that can handle more abuse?
    This car will be abused, so I might just reinforce it.
  9. #84
    Aug 2009
    Bay Area
    E34 MSport
    I don't know the condition of yours, but I ripped mine off from an E32 at the junkyard, replaced all the seals, fed it new oil, cleaned up the outside, and popped it in.
    Yeah, I would reinforce it. Seems to be a weak point. I broke it doing some hard shifting, not launching it or anything.
  10. #85
    Feb 2009
    allows me to use 6th gear
    s52 turbo e30M3 FREAK!!!
    Quote Originally Posted by RVAE34
    Same here with my 3.23lsd lays down beautiful twin strips on the pavement
  11. #86
    Saint Charles, MO
    Way too many
    Quote Originally Posted by DUDMD View Post
    The E32 Large Case uses an IRON bracket.
    The E34 Large case uses an Aluminum one.
    I have the Iron one from the diff you bought from me, if you want it.
    2 E34s. 1 E36. 3 Mx-6, 2 626, 06 Trailblazer SS, '73 Vette, 5VZ 4runner, and one insanely screwed up property tax bill each year.
  12. #87
    Aug 2009
    Bay Area
    E34 MSport
    Sorry, I forgot to clarify that the bracket that broke on mine was the one on the side that mounts on the input flange side. Just wanted to warn you.
    Thanks for the input MazDuh, but I think most e34 guys will have that bracket on their car already. I'm still using the same one on my car after switching diffs.
  13. #88
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Thanks guys, I'll probably stick with the one I have now. I do have a spare open case diff for parts with a bracket. If I somehow break one, I'll reinforce my other one and put it in. This is not my daily driver and can it have some down time in an event of a breakdown.
  14. #89
    1995 BMW 530i, 1969 Camaro Z28/RS
    Nice work, can't wait to see the turbo installed and all.
    Jon
    '07 BMW 550i Titanium Silver Sport 6-Speed M-Sport Bumpers
    '15 Electric Mercedes
    '69 Camaro Z28/RS Hugger Orange/Black, 400hp, 4 speed manual
    Previous:
    '07 BMW X3 Arctic Silver Premium/Cold Weather Package Adaptive Bi-Xenon
    '95 BMW 540i M-Sport Hellrot 6-Speed Dinan Engine/Diff Goodies Moonroof
    '98 BMW 740i Biarritzblau stock
  15. #90
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by camaroguy
    Thanks Jon. I was just waiting to buy a new tig and finish a few things on my e38 and my other 540i before I start building the manifolds.
  16. #91
    Aug 2009
    Bay Area
    E34 MSport
    Forget the other cars, I wanna see these manifolds! And consider buying them from you lol. I don't have a garage to weld in...
  17. #92
    Dec 2008
    birmingham, al
    M42,M60,M62,M62TU
    I am excited about seeing these manifolds and fitment
    e34 540i/6 :: e30
    M62/6 :: e30 318is :: c5 Z06
  18. #93
    Saudi Arabia
    e34 540i
    Nicebuild..
    i`m waiting for the turbo installed ..
    Good Luck ..
  19. #94
    Nov 2005
    Saratoga NY
    95 540/6, WK2 Eco Diesel
    DUDMD, nice looking build. I look forward to seeing the progress.
    Have you ever thought of the possibility of doing a rear mounted turbo on an e34 540?
    BMW Man
  20. #95
    Villa Rica, GA
    E34 525it, e30 318is
    Quote Originally Posted by Antrieb View Post
    Back from the dead!
    E34 525it/5 S52
    E30 318is slicktop M50T
    F15 X5 50i M Sport
  21. #96
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    That how I was going to do it originally, but then scrapped that and am doing it properly.
    Thanks guys, I can't wait to get some more time to work on it now. Both of my other cars are now aside for a little bit. I started repositioning the intercooler on Monday, trying to finish that this week and get the old b30 motor up on an engine stand to use as a mock up/welding jig for the manifolds.
    I'm attempting to have the radiator sit back in it's original location, with the intercooler taking the ac condenser space.
    Placing an order on some 80lb/850cc ev14 Bosch injectors tomorrow. Should be enough fuel with the twin walbro's for a lot more than the motor can handle. It will also have enough fuel deliver to run E85 up to 700whp. I'm thinking of getting a 30 gallon barrel to use it for obtaining E85. Closest E85 station is at least 20-30 miles from me, so the car will have to be tuned for 92 pump and e85. E85 will only be used during the hot season/summer.
  22. #97
    Aug 2012
    Philly PA USA
    95 540i/6sp M-sport
    Sick build, I've always leaned towards s/c setups for my next build bc of the tight d-side bank..but seems you will have many of these issues worked out in due time!
    Rear mounted wouldn't be a bad idea, Corvettes have been running that way for almost a decade with great results...but I know, this isn't a Chevy right?
    Unbelievable, can't wait to see those mad science manifolds bro! Gd luck with one of your many toys
  23. #98
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by slidesidewayz View Post
    Thanks.
    The only good thing about a rear mounted turbo is you have a turbo on your car and it's able to produce boost somewhat. The vettes also have almost twice as much displacement, that can spool up their turbo(s) back there.
    I'm not a fan or 20 ft of oil lines, and a 15 foot charge pipe.
    Since we have the space under the hood for ONE turbo, I think it's best to utilize that space and run the turbo in a way it's meant to be run. Nice and HOT.
  24. #99
    Baudette Mn
    Agree'd
    Might as well do it right, or as close to right as possible. I am excited to see the manifold and routing.
  25. #100
    Aug 2009
    Greeley, CO
    540i6, 540iA, RX7, RdBlk
    ... I think it's best to utilize that space and run the turbo in a way it's meant to be run. Nice and HOT.
    ^^ This. Obviously the best solution would be twin turbo's, one for each bank, but we simply don't have the real estate under the hood for that. Dud's approach is the next best solution - single turbo as close to the engine as possible. This should be wicked once it's done, if a little cramped and hot.
    BTW - you'll want to take an idea from Jon and use that heat shielding everywhere around that turbo - there's not going to be a lot of room left for cooling airflow, I suspect.
    Fox (gold foil is cool...especially when it's used properly)
