Page 14 of 14 FirstFirst ... 4567891011121314
Results 326 to 342 of 342
Thread: E34 540i/6 Turbo Build - The game is on.
  1. #326
    Mar 2012
    Baltimore, Maryland
    2016 640i, 1990 535iM
    Niiiice!
    That's awesome
    2016 640i Coupe'
    1990 Bmw 535i Turbo 600whp
    1999 740iL: Sold
    1997 740i: Crashed and Parted
    1988 535i: Crashed and Parted
    1988 528e: Crashed and parted
    IG- @Rogetta_Stone
  2. #327
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    That looks like a nice fat powerband!
    Quote Originally Posted by DUDMD View Post
    I haven't dynod an M60 on this dyno yet, but a M62B44TU 6 speed makes 218WHP here. M60 I figure will be very close, so about a 150-160WHP gains on this dyno. 386WHP on this dyno is at 500hp crank.
    Was it a healthy one? Those usually do around 260-270whp from what I've seen. My M62B44NV (with your chip that works just fine BTW) put down 264whp and 296wtq, not on a Dynojet...
  3. #328
    Mar 2010
    Marin, CA
    1989 535i Manual
    What an amazing build. Congrats on that power figure and for a great execution in general. Excited to see more!
    "Big Red" 9/88 Build 535i/5: E.A.T. Chip, 24lb Bosch Design III, 3.46 LSD, 4x Clear corners, DINAN-style 750i muffler, Racing King Subframe Inserts, Koni/Vogtland suspension, E34 M5 swaybars, Brembo/Porterfield brakes, Turbodiesel grills, 16" Style 8 rims, Euro front plate, M5 rear filler plate.
    Save
    Save
  4. #329
    Denver, CO, USA
    93 M5 88 M3 14 i3
    Looking good man! Are you planning on draining the Provent to the pan or is it just capped at the moment? Looking forward to seeing what you come up with, working on another setup right now for a supercharged car.
    -Greg
  5. #330
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by 93FIM5 View Post
    Looking good man! Are you planning on draining the Provent to the pan or is it just capped at the moment? Looking forward to seeing what you come up with, working on another setup right now for a supercharged car. -Greg
    Currently have a smaller can to collect oil inside the bumper
    But am thinking of just draining back to the oil pan and forget it.
    But will still change to valve cover as the new source of crankcase vent
    Sent from my iPhone using BF.com
    Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
    Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
  6. #331
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    I have the same oil/air seperator on my supercharged 540i/6. The dipstick was too hard to adapt a bung to so I tapped it directly to the sump using a 1/2" bsp thread. Used a 3 stage thread kit and used a 19mm drill. Easiest spot is on the side of the sump near the front on the RHS. You have enough room there to use a cordless drill to drill the initial hole. The good thing about te m60 is u only need to drop the lower part of the sump. The good bit is you get to check the oil pump bolts and chain tension. My pump bolts were pretty loose and the chain was very sloppy.
    Just started mine up yesterday (see the supercharger thread check in here). Runs really nice with the maf on the pressure side and the FMIC but I run into a hard stop at about 5500 instead of the 7000cutout on the ecu. If it runs out of maf range does it just stop?
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
  7. #332
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by GazM3 View Post
    Maxed out maf may throw a fault code, but will usually just lean out. The DME no longer sees more airflow, and starts injecting the same amount of fuel for the rest of the rpm. That is bad with a blower, since you have more boost the higher your rev it up.
  8. #333
    Dec 2005
    E24, E34 x2, E36
    I don't think it's the maf. We tried a few and with a new oem one it still does it. By the seat of the pants it doesn't feel lean or no pinging.
    Its like a hard cut almost like a electronic rev limiter. We swapped the ecu for another Bosch 404 and same occurred. We are going to replace the harmonic balancer as this could get a bad reading. I have a new crank angle sensor. It's consistantly about 5500. The ess chip is redlined to 7000. Could even be a currupted chip.
    The good side is power up to this point is orsome. Way stronger than before up to the low cutout. And with the air/air intercooler power is consistent. I'm going to plumb in a wideband with air fuel gauge and a boost gauge to see what's happening also.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
  9. #334
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Bad cam/crank sensor can be at fault.
    I highly recommend a wideband AFR kit and Boost gauge on any boosted car, especially an older car or one that is converted from N/A to FI.
  10. #335
    Dec 2005
    E24, E34 x2, E36
    Wideband , a/f gauge, boost gauge and mechanical fuel pressure gauge will go in next day or so. The ecu change made a slight difference to the cutout so we think it's now the maf running out of range. Pulled the fuel controller out of the e24 as it's laid up so we should be able to tune the fuel and the mechanic has a few tricks to sort the maf side. Have a Porsche 803 maf I can use if need be.
    Up to where the power falls out it goes as hard as hell compared to what it did before. Even with the air to air intercooler the pipework has more logical paths and we probably have more boost than we thought we would have. It's going to be orsome.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
  11. #336
    Sep 2017
    Bosque Farms, NM
    86 325e
    What transmission did you use?
  12. #337
    Jun 2017
    Chicago
    1995 540i & 1996 328i
    What kind of bsfc numbers are you seeing at Max torque?
    Or possibly air mass flow rates at peak horse power?
    Also what kind kind of charge temps are you seeing pre and post IC?
  13. #338
    Sep 2016
    Latvia, Sigulda
    1994 BMW E34 Sedan
    Sorry for bringing topic from dead, but wanted to know if there is any1 info about car, how the project ended? Just planing same process
    Sent from my SM-G950F using Tapatalk
  14. #339
    Aug 2018
    Miami
    2001 BMW 750il
    Any new updates bro?
  15. #340
    Dec 2005
    E24, E34 x2, E36
    Not sure what happened to it in the end. It seemed to make good power. Not sure if dudmd sold it off. The m60 is a resilient engine. Not sure what the limits of the standard engine are. Pity this wasn’t delveloped a little more.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
  16. #341
    Aug 2018
    Miami
    2001 BMW 750il
    Yeah I post a few comment on his Youtube channel to see what’s up with it but nothing. It seems his Sl65 didn’t put up good numbers like he wanted but it sound super nasty
  17. #342
    Dec 2005
    E24, E34 x2, E36
    Often people are a little fixated on the dyno numbers their car makes. Just go out an enjoy it.
    My old v8 Ute with cammed L98 v8 makes nice power ok the dyno (410rwhp) but feels not as fast or enjoyable to drive as other cars with less power make. I guess with the GM v8 they are all mid range power so a little flat at low rpm and no ramp up at the top end.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
