1995 540i/6 E34 Black/Black
Today was the day it all begins. I have had plans for this happen for over a year now and have been collecting parts since then. Today I have finally moved the car into the spot where the build will happen.
I'm shooting for about 500-600whp with 100% stock internals. I have never even removed the valve covers yet. I will during this build, only to paint them and replace the gaskets.
As far as I could find, only about 6 of the M60 engines were ever turbocharged, 4 were not in an E34. One was in an E28 that made 700whp+, one in a Volvo that made 640whp on E85, and one that is a funny car build that makes 1200WHP with twins. There was also an E32 740i build with twin GT35Rs. Looks like I'll be 7th M60 to be turbocharged on the web.
Build will consist of:
Tial Q 50mm BOV
Twin Tial 44mm waste gates, one per bank
Turbonetics Ball Bearing T70, T3 divided/twin scroll.
E32 750iL Dual Fuel pump assembly
Twin Walbro 255lph HP pumps
1000cc Bosch EV14 Injectors
3" Stainless steel exhaust
Custom TIG welded manifold, 1.5" SCH10
MaxxECU - bluetooth table for gauges/switches.
Spec Stage 3+ clutch (Already installed)
Revshift Motor and Tranny mounts
E32 750il 3.15LSD
Plus more that I'm missing right now or can't remember at the moment.
7/2/2012:
Washed the car
Removed permanently:
Airbox
MAF
AC System entirely
Mechanical Fan
Shroud
Radiator(going back in later)
I then test fit the turbo and it looks like it will be a nice home for it, pictures are going to show about where the turbo will sit. Not so much luck with the air to water intercooler. It would work but I didn't like the fitment and decided to use the normal air to air intercooler due to a much simpler install and less problems down the road.
Pictures from today:
Enough clearance to stuff a fat front mount in front of the radiator.
Last edited by DUDMD; 12-04-2016 at 01:49 AM. Reason: updates and changes over the years.
Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
Oh dang. Subscribed.
how many miles on the M60?
I hope to some day see this thing. ps are your wheels 18s?
91 318is and a 93 jeep xj.
Right on... that is gonna be burley. Wished I could have stopped by yesterday... It got late and I was running on 3 hrs of sleep and 700 miles logged. Get going on this already!
I hope to have the 2.8 stroker and a five speed eventually
in.
subscribed friend!
-Alex
I love when a respected member of the board does a project like this...
So down for this.
I'll be the 8th soon.
Congratulations on starting this. I actually started collecting parts only yesterday. I'm going to go bottom mount using 2 WRX turbos. Not aiming for your hp goal. :P
Please, PLEASE take tons of pics. Also, why are you installing the intercooler behind the radiator? If you removed everything A/C related like I have, there's ample space in front of the radiator (behind the kidneys). Also, what injectors are you going to use? That's something I'm still looking into. Wouldn't S62 injectors work?
1992 BMW 850i/6speed. Stock as stock can be.
Subscribed!!! Look forward to progress pics.
I'm using Ford Motorsport injectors.
991 | 964 | G55 | D90 | LX570 |
Past: SC'd e34 540/6, CSL'd E46 M3, E36 M3/4/5, E36 M3 turbo, E36 M3, 335D, Porsche 951, 80 Series LC, Kleeman E55 Wagon, LX470, 970 Panamera TT, E92 M3
It's absolutely mind-boggling the amount of kilowatts that can be had from these relatively small displacement BMW V8s and i6s. Good luck with the mods, it will be a beast.
I wave my private parts at your aunties you empty headed animal food trough wiper.
Are you planning on running uneven length headers? Any idea on how you will be running the driver's side bank to the turbo?
Sick!!
I've going back and forth with plans to turbo mine since i did the swap... I'm pumped to see how this works out!
link to e30pickuptruck build thread
^driven coast to coast
this is going to be badass.
got any links to those other turbo M60s thta you mention?
Damn. Subscribed.
Aha. Thanks for the info. I had no idea.No, not at all. They are a special design, twice as long as a standard injector. There have been lots of supercharged M60's built, any information those builders have on injectors should apply to turbos as well.
Link? Flow rate? Bolt on or modification required? Those are available locally, so I'm interested.I'm using Ford Motorsport injectors.
