Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 151 to 175 of 266
Thread: E34 540i/6 Turbo Build
  1. #151
    Northwest Ohio
    2001 750iL
    Quote Originally Posted by DUDMD View Post
    Soon, might end up changing up a few things for this build.
    I'm hoping to resume work on this project soon.
    Yes. Looking forward to how things are progressing for you.
    2005 X5 4.8is (DD winter) * 2001 750iL (DD summer) * 2001 Ford Excursion 7.3 L <> 2005 X5 3.0 * 2003 X5 4.4i * 2009 X3 3.0 * 2009 X5 3.0 * 2007 Toyota Avalon Limited
  2. #152
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Well, now that winter is here, I've decided to roll the car up on my 4 post lift here in the shop and not take it off until it's done. Hoping to have it running by new years, tons of parts are being changed and some of my original plan has changed as well.
    My DTA S80 is for sale ($900 if anyone wants it), which is getting replaced by the MaxxECU
    Anyways, here's pictures of new updates:
    Harness removed, intake manifold removed for PCV delete and new gaskets. Not pictured, but valve cover gaskets and timing cover gaskets are also being replace and cleaner, valve covers we just painted today with wrinkle black finish.
    Bank 2 to Bank 1 crossover pipe has finally been finished. I used a flex pipe to compensate for flex and temperature differences, connected the manifold to crossover pipe with a small v-band.
    Front side view of the cross over pipe
    Bottom view of the cross over pipe, runs along the steering linkage. It will be wrapped with exhaust wrap to keep heat away from ball joints/bushings. The sway bar bracket will get some love too after the turbo build is done, car will get a new suspension overhaul.
    Added EGT bung to the manifold and crossover pipe, starter on the wastegate addition to the manifold.
    Both gates tacked on, space here is very tight for these huge tial 44mm. Would love to buy the new 38mm mvs gates, but dont want to wait longer and these still fit in the A/C compressor space.
    Turbo manifold is completely done, other than a brace I will still add to help it support the big heavy turbo.
    Manifold picture with the cross over pipe.
    Modified the factory traction elbow. Removed the entire throttle plate and guts from it, cut off all brackets and unnecessary casting.
    Welded on a 1" barb bung and used 90 degree silicone hose to plumb to the ICV.
    Welded on the Tial Q 50mm BOV right onto it as well.
    New ecu has arrived from Steve Nichols (Dyno Dynamics owner and my technical support guy for my dyno, that also uses and resells these unit)
    Everything I wanted is built right into this bad boy. Lambda closed loop, traction control, boost by gear/speed, egt support, and bluetooth output to any android device for all gauge and switches. No need to install real switches or gauges, all digital on to a tablet I'll mount to the dash.
    Software interface is nice and very easy to use. I will be reusing my factory coil packs, just have to wire up 2 of 4 channel ignition modules, used by 4 cyl audi, part number: 138055 That is all that is needed to use the factory coil packs with pretty much any standalone.
    Unit is very small and compact, should fit into the factory ebox no problem, which DTA would not, and I didn't want to run the DTA from inside the globebox.
    Good stopping point for this weekend.
    Injectors are in, turbo manifold 100% done with a reinforcement bracket, waste gates installed and dump tubes are done.
    Next week need to install radiator, turbo lines and start on the charge pipe. Maybe standalone wiring if time permits
    Even after sitting for over 3 years, engine is still spotless. The same engine I had oil pump gear come off the oil pump a long time ago, where it stalled due to lack of oil pressure. All cam lobes look perfect still, and I drove 10k miles after the oil pump gear came off the oil pump.
    Valve covers painted in wrinkle black finish, my favorite valve cover finish.
    Added a 3/8" metal rod, to help support the turbo a bit.
    Welded it to to Cyl 1 head flange.
    Rear PCV delete plate is finally installed and fittings are installed.
    1. Extra port capped. 2&3 - 1/4" Quick release for BOV and one for extra boost source for the dyno. 4. Barb output to FPR 5. Quick connect output to map sensor for MaxxECU
    Bosch EV14 1000cc Injectors installed. Factory retaining clips wont work with these injectors, but the perfect height is the key. They can't go anywhere.
    Dump tube weld, best weld of the day. I rarely ever TIG weld anything, so I'd say not bad after years of not tig welding anything.
    Bottom shot of the dump tubes.
    Front view of the dump tube. (My other beast in the background, 05 SL65 AMG - doing a single turbo conversion with a Precision 7675 after this 540i6 turbo build is done)
    Bottom wastegate clearance to upper oil pan, it's tight, but clears.
    Top wastegate clearance to AC bracket, tight but clears as well.
    Top view of the front ends of the manifold with both gates and dump tubes.
    Stopping point for the day. Starting to look like an engine again.
    Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
    Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
  3. #153
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Looks great man. Any reason you cant ditch the AC bracket? Ive done enough m62 stuff where i should know but i cant remember if it does something else.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  4. #154
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    It's part of the engine mount bracket. I might hack off the unnecessary parts of it that stick out, but if everything clears, I'll just leave it alone for now. Maybe if I pop this motor, I'll clean it up with the engine out of the car.
  5. #155
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Looks like your front covers are starting to leak - very common on M62 (or any BMW V8 for that matter). I'd probably replace the gaskets while you've got the front end accessible.
  6. #156
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by Def View Post
    Just did the timing cover gaskets and valve covers
    Sent from my iPhone using BF.com
  7. #157
    Aug 2012
    CT
    Any reason your not using the stock DME? I know the m62 DME's are right up your wheelhouse
    Beleive me, im not trying to talk you out of standalone, not by any means.lol.
  8. #158
    Apr 2006
    Minnesota eh?
    86 325es
    Cool project. Its suprizing to me the V8 cars don't get any attention. I have always wanted to sleeve an M62 and try to get it up in the 1000-1200 whp range.
  9. #159
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by dburt86 View Post
    This is a 95, so it's an obd1 m60. Factory DME is very limited on what maps I can find to tune for boost. Standalone just going to be so much easier, built in map/boost/traction/lambda control and tons of safety features. Easy datalogging and easy to tune.
    Not worth the headache of tuning with factory DME.
    If it were OBD2 M62 DME, I'd have a lot more flexibility in tuning it, as I have access to all maps/adjustments on that factory DME, but still limited to the MAF and no safety features/boost and crappy dataloggnig.
    Maybe one day, but I have other toys I'd rather spend that money on than sleeving this car.
    I have an SL65 AMG I want to push close to 1000hp on with stock internals, just a single turbo conversion and a built transmission.
  10. #160
    Def's Avatar
    Aug 2002
    SW22, Volt
    They're absolute maintenance hogs in stock form. Add an aftermarket turbo kit and you're talking about a lot of TLC to keep it going in decent shape. Not many DIYers would be up for that task.
    This is a cool build tho' - good you got all the gaskets out of the way - it was probably just some residual leakage I was seeing from before the job. I'm guessing you've also gone over the timing guides?
  11. #161
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    M62 is not bad for maintenance wise if you do everything right away in one go. A lot of people just fix it one part at a time.
    This is an m60 engine, double chains and no U-guide. It does not suffer the timing chain guide failure like the newer M62 engine.
  12. #162
    That's good to know! I was counting the days until the chains/guides on my mother's 95 540i/6 with 230k miles were going to finally bite the dust. I just figured her car was a unicorn and would last forever. Maybe it is! Hellrot, '95 model, 6 speed, sport package and seats, etc.
  13. #163
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Spent a few hours today taking apart the DME connector. Going to install/wire the standalone tomorrow hopefully.
    Should easily fit in the ebox, hence I didn't want to make an adapter to convert from stock 88pin connector to standalone, as that would take up a lot of room.
    So I decided to just hardwired it straight into the original harness. Also gives me a time to clean up the harness a little and remove most of the unnecessary wires. Some I'll keep in there and repurpose those wires for other functions.
  14. #164
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Wired up the injector wires directly, ignition modules and coil pack wires to Bosch 4 pin and 5 pin connectors. Used a new crimper I bought and installed new pins/connectorfor ignition modules, actually fairly easy and fun crimping those pins.
  15. #165
    Nov 2011
    Derby UK
    1999 BMW540 Supercharged
    I'm watching this thread with interest and may use the max ecu for my supercharged installation.
    Sent from my SM-G920F using Tapatalk
    1999 540 Auto with Eaton M112 supercharger
    Airlift 3H/P management, M5 steering box, M5 LSD, Eibach/Dinan front and rear anti roll bars, PM Modifich door boards, 4 Eton 6.5s, Sound Magus VS3500.1, 2 x 10" Kove audio subs, Alpine ICS X7 Headunit, 19" BBS Hammer Sports RT245/RT246, Muffler delete, electric coolant fan.
  16. #166
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Finished wiring up the maxxecu today, minus extra options for boost solenoid and traction control, ill do those later
    Very few unnecessary wires left in the original harness, just need to clean them up and tuck them out of the way, just in case I need to reuse some them later.
    Had to rewire the main relay a bit (flip the activation wire from ground to 12v on from ignition terminal 15), and used an oem fuse holder from a spare Bmw engine harness to protect the ecu with a 15amp fuse.
    Maxxecu sent me a basemap from a turbo m60 Volvo on e85, so I had to change a few settings around to get the tach to properly work, select my injectors and set the timing map for pump gas.
    Harness pretty much completed.
    Unnecessary wires remaining
    Removed a no longer functioning knock sensor connector and replaced it with an ev1 injector connector. Tapped it into injector #1. Makes it super easy to connect my Dyno into it for a perfect reliable RPM source.
    First time connecting, asked for a firmware update automatically. I guess wiring went well since it powered up no problem.
    Tablet successfully connected and gauges/diagnostics work perfect. This is just a simple quick gauge setup. Will customize for my preference later
  17. #167
    Aug 2012
    CT
    Nice progress!!! That's great stuff man
  18. #168
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Such a cool and not typical build here. Nice work. In for updates.
  19. #169
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by philly98540 View Post
    Thanks, typical is not my style.
    I'll have updates almost daily, as I want to get it as close to done by new years as possible. Only thing slowing me down a bit is the freezing temps.
  20. #170
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Minor updates today.
    Finally got the exhaust housing loose off the center cartridge, soaking in pb blaster helped for a few days. I can now clock the center oil cartridge into proper position.
    My 518i radiator mount arrived from Latvia. No one states side could get it, but I needed it to be able to use the e36 m3 radiator as a bolt on. Just need to modify the lower radiator hose to make up for the shorter distance
    My P2M aluminum coupler clamps also showed up. No more need for t-bolts, no long stud sticking out, and they're in my choice of color.
  21. #171
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Mounted the intercooler by welding in brackets.
    Notched one corner for better clearance. Cut off the outlet and welded on a 90* elbow. Did not want to run more than one 90* coupler per connection.
    Also welded the 3" vband outlet to my exhaust housing.
  22. #172
    Dec 2016
    uk
    m1
    Nice plan and build so far!
  23. #173
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Very small update:
    Received the radiator hose coupler, to connect my lower radiator halves together. Since no other hose I can buy will easily fit, I removed a few inches from the center of the straight section of my original lower radiator hose.
    This is a 35mm Pegasus Pro Design hose joiner. Should seal up really and not have the hose pop off. Looks awesome, too bad it will never be visible again.
  24. #174
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Almost ready for a first start up.
    Just need to tidy up a few things, install the power steering pump and radiator back in.
    Ran the oil lines today, mounted the turbo for it's final time, shouldn't have to come off again unless there's an issue with it.
    Built the downpipe as well, ran my best weld ever actually while building it.
    Might also have to remove the turbonetics oil filter from the turbo, since the oil feed line sits kinda high, might not clear the hood. Removing this filter will drop the oil feed line down enough to be same height as the compressor cover or lower.
    Used my 7/8" holesaw I bought to drill for o2 bungs, and it was the perfect size for the 10an bulkhead fitting.
    Bulkhead installed through the upper oil pan, hoping it doesn't leak. If it does, I'll ditch it and weld one on instead.
    M12x1.5 oil press sender spacer with a 1/8" NPT outlet for the oil feed line.
    4an feed line
    10an drain line
    Routing of the oil lines to and from the turbo.
    One last shot of the manifold from underneath, before mounting the downpipe/crossover pipe.
    Downpipe and turbo blanket
    Downpipe routing and o2 sensor location. 3" is about the max that would safely fit between valvecover/head and the fram rail. Leaves just enough room there to use exhaust wrap to keep the heat down around wires/hoses/gaskets in that area.
    Turned out to be the best weld bead I ever put down
    A little bit of gold heat protection, so many contours that wrinkle free is practically impossible.
    Final shot for now, will be ready to test start it soon.
  25. #175
    Nov 2011
    Derby UK
    Great progress looking forward to seeing how this runs with the new ecu.
