Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 101 to 125 of 266
Thread: E34 540i/6 Turbo Build
  1. #101
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Cool, thank you!
  2. #102
    Villa Rica, GA
    E34 525it, e30 318is
    updates?
    E34 525it/5 S52
    E30 318is slicktop M50T
    F15 X5 50i M Sport
  3. #103
    Denver, CO, USA
    93 M5 88 M3 14 i3
    DUDMD you've got a PM.
  4. #104
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by Analog View Post
    updates?
    Not much done since the last time, when I installed the driver's side manifold on.
    I have been doing a bunch of E38 stuff recently (complete suspension rebuild and coilover install on my brother's 740i, soon a blower and a 6 speed conversion), parted out an E38 750il, and now have to stuff that engine from the parts car into my newly acquired 98 750il.
    We have hit the rain season during my last update, so if we're lucky, we get one dry day a week. Since the e34 is outside, not much is being done.
    After I complete the 750il motor swap, and get it roadworthy, I'll try to get the 540i6 into the garage and keep working on it. There's not much left, but every little tiny details sucks up time like crazy. It took my brother and I like 3-4 years to build his integra the way we wanted it to. It's still not done, little details need to be worked out, but it's one little crazy monster.
    Here's a few shots, a little old but not much has changed.
    Quote Originally Posted by 93FIM5 View Post
    Greg, thanks for your offer and time. Can't wait to see it.
    Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
    Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
  5. #105
    Dec 2012
    Finland
    540 SC -89, Compact M60
    [QUOTE=DUDMD;24638445
    As far as I could find, only about 6 of the M60 engines were ever turbocharged, 4 were not in an E34. One was in an E28 that made 700whp+, one in a Volvo that made 640whp on E85, and one that is a funny car build that makes 1200WHP with twins. There was also an E32 740i build with twin GT35Rs. Looks like I'll be 7th M60 to be turbocharged on the web.
    This is nice build and reason why i put my video to the web. Youtube and BMW 516 , so you can see my DD.
    Any updates?
  6. #106
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by 516SC View Post
    Any updates?
    Unfortunately no, other than sending out the rear PCV plate to Greg to make a delete plate out of aluminum.
    I have been focused and working on the 750iL recently, this will go into the garage after the 750il is back together and running. Then I can work on the turbo build, regardless of the weather outside.
  7. #107
    Saudi Arabia
    e34 540i
    i have a question how much hp power produce the m60 from a turbo with the stock engine ..
  8. #108
    Denver, CO, USA
    93 M5 88 M3 14 i3
    PM me your address I seemed to have lost it.
    IMAG0156.jpg by 93FIM5, on Flickr
    This is the rapid prototyped piece let me know if you want to change anything before I cut. Should be to you by the end of the week once I get your address.
    Greg
  9. #109
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Greg
    Thanks, Greg
    That looks awesome, better than I imagined it. I sent you a PM with the address. I just got back home yesterday, and now can test it whenever it gets here.
  10. #110
    DeWitt, Michigan
    This is the same intake manifold as on an M62b44 (early non-vanos), right?
    If so, I might be interested in having you knock out on of those for me too if you're willing?
  11. #111
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by tptrsn View Post
    Yes, the m62/m62tu and the m60 all share the same Pcv plate.
  12. #112
    DeWitt, Michigan
    Cool, maybe I can get in on having him knock one out for me while he's at it? I haven't really looked at the PCV situation on these, but I take it that this plate will fix things up for pressurization.
    Is there a tube that runs down the center of the intake to that plate for some purpose that I can't really remember? I've been working on a lot of other stuff since I redid my valley pan and intake stuff...
    Thanks!
  13. #113
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Thanks!
    The factory piece would've worked somewhat with slight modifications, but take a look at it still. Notice how it has a huge diaphragm that fails often on factory engine, I will now went the OSV to the atmosphere with a catch can, or do an exhaust vent setup. Then there's the useless 3/8" barbed fitting that is only used on the E38/X5/maybe E39 chassis for the brake booster? The FPR and an extra 1/8" ports are not barbed, and will likely pop off hoses under pressure. I also needed more ports to attach the map sensor, boost gauge, and the blow off valve. Thanks to Greg, we're solving many issues with his custom piece. I think that he needs to start producing a lot of them and sell them. There's plenty of supercharged M60/M62s out there that can use it.
  14. #114
    Sep 2002
    USA
    BMWs
    Quote Originally Posted by DUDMD View Post
    Just be careful there - Greg knows, too. What you think is a marketable item for FI BMWs that are 15+ years old.. well.. sometimes isn't
  15. #115
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by 5mall5nail5 View Post
    I know, there's only a handful around that actually are FI. The thing is, I would recommend this piece for a factory replacement. The factory plate bends a lot when you install a new gasket and only lasts a few years, if that. At $50-80 for a factory replacement, this would be a great investment and a permanent fix.
  16. #116
    Dec 2012
    Hurst, Texas
    BMW
    +1+1 I would buy one.. can you ask him if he will make a few to sell?
  17. #117
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by Boosted540i View Post
    You guys need to PM Greg directly, his user name is a few posts above. I don't know if he wants or can make more, what the cost is, any of that.
  18. #118
    Dec 2012
    Hurst, Texas
    BMW
    Greg
    Hi Greg I sent you a PM
  19. #119
    Denver, CO, USA
    93 M5 88 M3 14 i3
    Im interested in doing a few more, I would prefer to fine tune the design some more with DUD but after that sure. Could also do some custom things depending on what you guys want but please keep in mind this is a hobby for me and really just a good diversion from working on my S38 setup when I get frustrated so you may have to be patient with me.
    Greg
  20. #120
    DeWitt, Michigan
    I'm able to wait a while, I probably won't be getting to the actual build of the turbo setup until at least late spring. Well, at the soonest.....
    Haha...
  21. #121
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Greg,
    The prototype showed up this morning. The first thing I did was go in the garage and test fit.
    The piece fit perfect. Every bolt hole lines up nicely and the plate overall fits perfect.
    Thanks again for doing this. I don't think anything needs to be changed from the prototype.
    Sorry for the iphone pictures:
  22. #122
    DeWitt, Michigan
  23. #123
    Charlotte
    '97 Estoril M3 Turbo
    stupid question: intake manifold pressure tester?
    | 1997 Estoril M3 - TURBO - |
    | GT35R | 8.5:1 forged internals | ARP stuffs | SS Oring Block w/ elring | Fully balanced & blueprinted 3.3L S52 | Nick G Tuning |
    | 46mm Precision gate| 62# injectors | Dual Walbro's |
    Goal: 600+ whp pump gas reliable 10 second car.
    -2007 335i Sport Package
  24. #124
    Louisville, KY
    turbo m3
    I'm sorry, but what exactly is the prototype?
    This is my signature....
  25. #125
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by rt turbo View Post
    No. If you look up a few posts above you'll see what the factory piece looks like. It contains a PCV valve with a huge diaphragm that frequently fails. The way the factory PCV is setup, it will never work for a FI engine, and I'll be venting to atmosphere for now. The 2 little vacuum outputs are not enough, and it will be hard to secure the hoses on them under boost. The large barbed fitting on the factory piece is not used on the E34, making it useless and just another potential failure.
    What Greg did is delete all these problems, and gave me up to 5 vacuum/boost connections. I need at least 4 sources (map sensor, boost gauge, fuel pressure regulator, blow off valve). The factory piece is also plastic, which bends quite a lot when you tighten it down, causing the gasket to fail faster.
    Quote Originally Posted by BadBoostedBmwM3 View Post
    A test piece he machined out of plastic for a test fit. Now that I confirmed that it's perfect and nothing needs to be modified, he is going to machine some out of 1/2" thick aluminum.
