Page 11 of 11 FirstFirst ... 234567891011
Results 251 to 266 of 266
Thread: E34 540i/6 Turbo Build
  1. #251
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Congrats! Install looks tidy. What's your boost target on this?
  2. #252
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by philly98540 View Post
    10psi on pump
    15psi in ms109 or c16/q16
    Sent from my iPhone using BF.com
    Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
    Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
  3. #253
    DeWitt, Michigan
    '97 540i/6, '97 328i
  4. #254
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Got the ProVent200 installed, thanks to 93FIM5
    Modified the provent bracket a bit, relocated the power steering pump reservoir and shortened PS hoses. Ran the 3/4" intlet, into a 3/4" to 1" silicone adapter elbow.
    Then a 1" elbow into 1" vibrant hose into the intake.
    The silicone adapter elbows, and the aluminum hose joiners were bought from Pegasus, really nice quality parts.
    The bottom of the provent has a hose leading to a sealed catch can under drivers headlight.
    Got the car on the dyno, and the vent setup worked really well. The oil filled up the can really quick, while nothing went into the intake. But that also means I need to change the source of the crankcase to vent. So I'll be sealing the current source and going to the top of the drivers valve cover to get a cleaner crankcase source with less oil.
  5. #255
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    And then onto the dyno.
    It made 316WHP at 6psi, and 386WHP 391WTQ at 9.5-10psi, very conservative timing. AFR at around 11.5 to be on the safe end of pump 92.
    Need to remember that this is a very low reading dyno dynamics. 386WHP here is around 430WHP on a dynojet, and 500HP crank.
    I would need to install some higher psi springs if I want to raise the boost any higher on pump. On race I can set it a little higher before maxing out the boost solenoid on current 5psi springs and throw some timing at it, should be possible to hit 450whp current setup with good fuel.
    Currently at 76% duty cycle of the boost solenoid to hit 10psi on 5psi springs. I will keep it like this for now, and see if boost by gear is needed with my drag radials in 1st and 2nd, if it holds all 10psi down low, then I can throw some 10psi springs and turn up the boost later on once all the little bugs are worked out.
    Injector duty cycle is only at 40%, so tons of room there.
  6. #256
    Aug 2012
    CT
    Twin turbo LS E36 M3
    What frequency are you running the solenoid? On a 8psi spring, i got an easy 21 pounds.
    Possible boost leak?
    Do you make 5psi with the solenoid off? where is your source for the solenoid?
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
  7. #257
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Not sure on frequency, would have to check. MaxxECU has preset settings for the MAC solenoid.
    I'm at about 4.5psi on 0 duty cycle.
    It also matters on how you have the wastegates plumbed, I can re-plumb it and use the top ports to run a little more boost.
    Current setup is compressor housing to solenoid inlet, solenoid outlet into a tee, tee outputs to each bottom port of waste gates.
    I'll do a boost pressure leak check when I'm re-configuring the oil scavenging/separator.
    I found some really cool fitting that I can use on these magnesium valve covers without having to weld on the bungs.
    -12AN vented/baffled fittings with no welding required.
    I even bought a few more of these fittings to run on my SL65 AMG, as that factory PCV system is a POS. I'll be blocking off the factory PCV system on that car completely, then use a speedfactory low profile catch can with a -12an breather hose from each valve cover. Should work much better than stock.
    Quote Originally Posted by dburt86 View Post
  8. #258
    Aug 2012
    CT
    use those top ports and gain some spool!!
  9. #259
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    Where did you find those vent fittings, they look interesting.
  10. #260
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by vr6dubny View Post
    JEGS 555-52231
    That's the only place I could find that carried them.
  11. #261
    Dec 2014
    Marin,Ca.
    4.9L 540i/Porsche 997
    How did this turbo project turn out? Any words of wisdom for another E34 540i turbo project? Vollosso is putting together a turbo system for my 540i to replace my Vortech based S/C system.
    22RPD Tuning '95 540i/6 custom turbo mit Borg Warner S400sxe/Rebello Racing 4.9L M62/JE pistons/Arrow rods/custom cams/S62 crankshaft/Darton sleeved/Focal custom stereo
    Porsche 996 Turbo Evosport GT 700-[700hp]-my daily
  12. #262
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Lol.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  13. #263
    Dec 2014
    Marin,Ca.
    I would laugh too if I was in your situation.
  14. #264
    Mar 2010
    You mean if you just had a super sweet, solid modded, well running daily, vs being a crank who keeps changing his username and his story, and can't spell "Porsche" yet claims to own one? yes if you were me, indeed you would be laughing at you. Regularly.
    2003 M3CicM6 TiAg
    Former:
  15. #265
    Dec 2014
    Marin,Ca.
    I edited my response because after re-reading it and many others, my humor is sorely lacking when written rather than talking face to face. And yes, I can be a "crank" at times and I apologize for that. I changed my username because I could not log in a few years back and was told to just start over, so I did. And I did not add the e to Porsche because there was not enough room to also then add 911. And in truth I have a 997. Also, you do have some sweet cars. I have always entertained the idea of turboing my 540i, and now decided to try it after talking with a member here on BFC who seems to know his way around turbos.
  16. #266
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    Has there been any more development of this setup?
    Has all the activities gone to Facebook these days
    tyese
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
