Results 1 to 21 of 21
Thread: Reducing Engine Bay Temperatures
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    We all have the same problem. Heat Soak. I started brainstorming on ways to get cooler air to the turbo. With a top mount, AC, and barely any room for ducting, the struggle is real.
    A vented hood is out of the question.
    Im exploring using the brake duct hole in the bumper since my stock brake ducts can no longer fit with the IC piping. Im also seeing what I can do with an old fog light housing.
    Im doing to pull down the under tray to see how I can fit something. Maybe a marine style blower motor....I can see that the turbo is getting hot air from the radiator fan while the hood is closed.
    Any suggestions?
    Mar 2012
    Renton, Wa
    98 m3
    I made an air duct to the holes in front of the radiator. The kidney grill holes. Air dam around to the turbo intake.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Apr 2006
    Minnesota eh?
    86 325es
    I take my hood off at the track and lean it against the fence. Taking the gasket off from around the hood helps too.
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Venting the hood is out of the question?
    I know you have a super clean car.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
    Jul 2005
    California
    Bima
    you already have a turbo blanket?
    because that shit WORKS. it's amazing the temp control it provides.
    Toronto, Canada
    E36 Turbo
    Convert to Bottom mount
    Nov 2013
    VA
    E36
    Also interested in a solution without hacking the hood with vents. But it is a non m so I might just hack away....
    Netherlands
    Euro S50B30 BEP S372
    Engine bay pic?
    I double taped the downpipe as tight as possible,plus a good quality turbo blanket and i had no high temp problems......
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    You can also use some of this stuff with metal ties. I've had much better luck with the aluminum backed insulation mat like this than the fiberglass insulation wrap.
    https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by Kevin325i View Post
    THAT STUFF LOOKS GOOD!
    1989 535i - sold
    Jul 2002
    Long Island, NY
    will try this. Thanks
    Quote Originally Posted by 3literheater View Post
    No way Im venting the hood, the sleeper factor is high here.
    Quote Originally Posted by Robocop View Post
    yes, still tons of heat.
    Quote Originally Posted by NOTORIOUS VR View Post
    Bottom mount limits the size of the turbo
    Will look into this over the winter since the dp would need to be taken off to wrap it. 3.5" is 1/8" away from the strut tower.
    Im going to try and route some ducting up to get "some" cooler air in there.
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    So, we all know that the e36 was never designed to have a turbo, much less have a turbo in the engine bay. The options are evac the heat or combat it....vented hood is a no go (evac), removing gasket will only do so much and probably not enough (evac), you are running a turbo blanket (combat). I'm guessing there are no other options to evac the heat sufficiently, so maybe a solution is a little radical:
    http://www.enginebasics.com/Advanced...0Sprayers.html
    You could run a line along the fender, behind the shock tower, and maybe trigger a mist/fogger using your windshield washer fluid container. I don't know if you still use it for your windows. I don't know where the ideal place to aim the jets, but maybe something to think about?
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Jun 2004
    The D, MI
    Quote Originally Posted by NY98M3 View Post
    I'm using the 1/4" thick stuff and it can be compressed quite a bit. I would bet money you'll be fine. Also you typically want to leave a small gap in it so it can expand and moisture can fall out. You could just make sure the gap lines up with the strut tower. I'm using the 12" wide stuff around a 3.5" downpipe and it's about a 1-2" gap that it leaves depending on the bends you're making.
    Another solution might just be a second fan underhood. I added a mechanical fan back in. I'm also pretty ocd about a factory appearance for the car and I picked up an e46 m3 HVAC plastic vent to put a hole just behind the radiator. It might look a little funny on a coupe though because you'll have the slots in the hood for hvac and a plastic piece inserted in it.
    www.ecstuning. com/b-genuine-bmw-parts/hood-vent/51132694723/?gclid=EAIaIQobChMI5NKrhLXM3AIVzbjACh0RBQAIEAQYAyA BEgLTfvD_BwE
    I haven't installed it yet because I suck and this new turbo setup is taking forever but I don't think it will even register to the average person. Most 'car' people have trouble finding the bottom mount turbo on these cars if the hood is open..
    Oct 2012
    washington, dc
    96 E36 Vert 03 E39 M5
    Wrapping or ceramic coating the downpipe and manifold will help a lot .
    http://www.bmwmregistry.com/detail.php?id=13792
    * E39 M5 SterlingGray -RIP 11/2018
    * E36 328 vert Schwarz - ~TurboProject underway
    * E90 335i Sedan MonocoBlau - Daily ToddlerTaxi
    Jul 2005
    California
    Bima
    but by how much? any numbers?
    Feb 2014
    Galt,CA
    2002 M Coupe
    Wrapping or ceramic coating the outside only will reduce the underhood temperatures, but the downside is that it will also kill the pipes themselves by holding all of the heat in them. Ceramic coating inside and outside will reduce the temps while protecting the pipe itself.
    Marty
    Apr 2006
    Minnesota eh?
    86 325es
    There is no way I would put a coating upstream of my turbine wheel. The jet hot type exterior coatings do work really well. DEI titanium wrap is great as well. You can put your hand on it when the manifold is several hundred degrees.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    The op has ceramic coated pipes, turbo blanket, and heat wrap......
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by E36 HateR View Post
    Sounds like he is doing all he can to keep the heat in the exhaust. Only thing left is to get the heat out of the engine bay, IE airflow in and out.
    Mar 2011
    Canadian in California
    Makes whoosh noises
    Have you considered a vented hood for events and having your minty OE hood for the rest of the time? This is what I've done although I do end up running the vented hood most of the time right now as I love how much cooling it provides.
    1000+RWHP, Lab22 Built Turbo S54 - BMW Half Mile Record Holder
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    Hey man
    the vented hood was probably the best part of this entire build, it really looks killer in person, car turns tons of heads when people see that s366 through the vents at stoplights
    not to mention my thermo gun shows a significant reduction in ambient temps in there, I say get the hood.
    99 Turbo M3 - BWs366 - RSI - Fuse Fabrication - JE Cutring -
  1. Exhaust Header Wrapper to reduce engine bay temp?
    By bimmerpwr in forum Forced Induction
    Last Post: 08-24-2003, 02:09 PM
  2. How Do I Clean Engine Bay - Help
    By 318 - KR in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 01-21-2002, 08:44 AM
  3. Engine Bay cleaning: The lazy way.
    By jsp98m3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-02-2001, 03:35 AM
  4. clean engine bay
    By e46driver in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-10-2001, 10:29 AM
  5. Suggestions on cleaning engine bay??
    By JT-KGY in forum 1992 - 1999 M3 (E36)
    Last Post: 04-04-2001, 11:45 PM
