Results 1 to 5 of 5
Thread: Question regarding raising psi from 9-10 to 12ish for vortech v3 si with s52b32
    Feb 2004
    san diego
    ...it depands
    (I edited the post so it is more concise.)
    Hello,
    Can anyone please let me know how much whp/chp the s52b32 engine is good for without going out of its limit? And if it does, what are the things to what out for?
    I am currently running about 9-10psi with 3.33 pulley and VF's vortech v3 si (about 351whp) with custom tune; the engine is running very smoothly. No heat soak. And no sign of running lean (slightly rich actually). But I've been thinking about switching to 3.15 pulley which will raise to about 11-12 psi (I'm hoping to reach 400whp potentially which is also my whp goal).
    Any suggestion or advise would be appreciated very much, TIA!
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
    Feb 2015
    USA
    2000 540i SC'd | 2001 M5
    So first of all, getting a belt to grip a 3.15'' pulley might be a project. You may need a lot of tension or an idler to wrap around it. Is a 3.15 a standard upgrade on this car or is this custom?
    Sold: 2000-BMW-E39-540i/Biarritz-Blue/Gray-Interior/DSP Sound.
    Engine/Drivetrain: VF-Engineering (Vortech V3 Si-Trim, 3.25''/6'' Pulleys/Tial QRJ -1.5PSI/Bosch Green Giants),Manifold,Magnaflow 16858 (Dual Exhaust/X-Pipe),High-Flow Cats/S62 Clutch & Plate/AEM 320 Fuel Pump/TTFS-Tune/AEM Wideband/Boost Failsafe/E60 SSK/ZHP Knob/CDV Delete.
    Handling: ECSTuning Cup Kit (Koni Yellow/H&R 50464)/BF-Goodrich Comp-2 A/S.
    Cosmetic: Front & Rear M-Tech Bumpers/Finned Rear Diffuser/Piano Black Interior Trim/Style 37's.
    Current: 2001-BMW-E39-M5/Carbon-Black/Silverstone-Interior/Sport Seats/Dinan Exhaust
    YouTube Channel
    Instagram
    Twitter
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by mcgnms View Post
    3.66 was the standard on mine, and I replaced it with 3.33. Since then, I have switched the tensioner (spring type), idler and belt to counter balance the grip.
    As you mentioned, I am guessing I probably would need to do something similar this time as well.
    I did some additional research since the original post, and it seems stock s52b32 motor is able to handle safely upto 450whp (or similar in wtq) with an assumption that afr and cooling are well balanced (not including tranny, drivetrain, and axles into a consideration). Does it sound right? Thanks again!
    - Zach
    Vancouver, B.C., Canada
    '97 M3
    What charge cooling do you have? Detonation will be your enemy.
    Feb 2004
    san diego
    ...it depands
    Yes, I will definitely have to watch the denotation until the motor is properly dialed-in.
    Aside from the radiator and clutch fan (will be replacing it with a electric fan when radiator is due for replacement), I only have indirect cooling method with an oil cooler (oil temp is consistently just shy of 200F) with richer fuel. It's worked until now. And I was going to continue with the same approach (I believe there is still more room to adjust). I'm trying to see if I can get it to work without adding a "custom" intercooler... But I'm also unsure how it will handle additional boost... Thanks again!
    - Zach
  1. Question regarding ECU on my '96 M3 (more)..
    By SilverM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-28-2001, 01:08 AM
  2. Questions Regarding Swapping out Stock Head-Unit
    By scottsby in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-27-2001, 08:49 PM
  3. question regarding my gas tank lid
    By Dean in forum 1991 - 1999 (E36)
    Last Post: 05-21-2001, 05:12 PM
  4. Questions regarding m3 purchase in near future
    By spork in forum 1992 - 1999 M3 (E36)
    Last Post: 04-20-2001, 12:25 PM
  5. Question regarding camber imbalances
    By SJTrance in forum 1991 - 1999 (E36)
    Last Post: 04-15-2001, 08:17 PM
