Page 11 of 11 FirstFirst ... 234567891011
Results 251 to 262 of 262
Thread: E34 540i/6 Turbo Build
  1. #251
    Raleigh, NC
    2001 M5
    Nasty!
  2. #252
    Atlanta, GA
    2014 Toyota Tundra SR5
    Looks awesome! Keep us updated.
    BMW Level 1 Master Technician
    2011 Chevy Tahoe LT
    2014 Moomba Mobius LSV
  3. #253
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46 M3Cic6MT, E39 540iT
    Rock on Dimitri. That intercooler fix should be much much better all around, interested in how the Provent works out - I remember hearing good things about those for tricky PCV motors a few years back, somebody used it on a big power Audi build.
    2003 M3CicM6 TiAg
    1985 Euro 300SL
    2008 Audi A3 2.0T DSG (hers)
    1999 Cherokee Sport 4L (trailer-hitched in-law-loaner bomber)
    And a recent former:
    Some Stuff FS
  4. #254
    Mar 2012
    Lansdale, Pa
    6/98 BMW 540 6sp VF S/C
    Congrats! Install looks tidy. What's your boost target on this?
    6/98 540i 6sp, Mods: VF S/C, Custom Pulleys, 16 psi Boost, Tuning Tech FS Tune, 42# Injectors, Supersprint Headers, HJS Cats, 3" Custom Exhaust, D.O. Progressive Meth, AEM 320 Fuel Pump, Aeromotive FPR, AEM Failsafe AFR/Boost Gauge, Wavetrac LSD, Style 65 w/275's square, M5 bits;[Steering Box, Clutch, Motor Mounts, Front Sway Bar], Powerflex, Eibach Rear Bar, M3 Shifter, Evans Coolant, 85 Deg Stat, Clutch fan replaced with PWM fan, 10" DVC rear subs, B.A. speakers, Grom Aux and BT, Euro Console, Brushed Ti Trim. DIY everything!
  5. #255
    DUDMD's Avatar
    DUDMD is offline BMW Maniac Supporting Vendor
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Quote Originally Posted by philly98540 View Post
    10psi on pump
    15psi in ms109 or c16/q16
    Sent from my iPhone using BF.com
    Performance Tuning and Chips currently available for all: M60B30, M60B40, M62B44, M62B44TU, 07/97+ M73B54 and M73B54TU
    Performance Tuning for 335D and X5 35D M57 engine - optional offroad use EGR/DPF/SCR Removal. Tunes available in stage 1 or stage 2 options.
    EWS Delete for MSS52/MSS54/MSS54HP/MS41/ME7.2/M5.2
    DTC Removal Service for most BMW ecus from 99+ etc: MS42/MS43/ME7.2/ME9/M9+/MSV70/MSV80/MSD80/MSS52/MSS54, including the newer EDC17/MEVD17.
    Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43 and more.
    MSS52/MSS54/MSS54HP tuning is almost done and will be released soon.
    Don't be afraid to ask, worst I can say is no.
    Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
    540i/6 E34 Turbo Build
    750iL Work Log
  6. #256
    DeWitt, Michigan
    '97 540i/6, '97 328i
  7. #257
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Got the ProVent200 installed, thanks to 93FIM5
    Modified the provent bracket a bit, relocated the power steering pump reservoir and shortened PS hoses. Ran the 3/4" intlet, into a 3/4" to 1" silicone adapter elbow.
    Then a 1" elbow into 1" vibrant hose into the intake.
    The silicone adapter elbows, and the aluminum hose joiners were bought from Pegasus, really nice quality parts.
    The bottom of the provent has a hose leading to a sealed catch can under drivers headlight.
    Got the car on the dyno, and the vent setup worked really well. The oil filled up the can really quick, while nothing went into the intake. But that also means I need to change the source of the crankcase to vent. So I'll be sealing the current source and going to the top of the drivers valve cover to get a cleaner crankcase source with less oil.
    750iL Work Log
  8. #258
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    And then onto the dyno.
    It made 316WHP at 6psi, and 386WHP 391WTQ at 9.5-10psi, very conservative timing. AFR at around 11.5 to be on the safe end of pump 92.
    Need to remember that this is a very low reading dyno dynamics. 386WHP here is around 430WHP on a dynojet, and 500HP crank.
    I would need to install some higher psi springs if I want to raise the boost any higher on pump. On race I can set it a little higher before maxing out the boost solenoid on current 5psi springs and throw some timing at it, should be possible to hit 450whp current setup with good fuel.
    Currently at 76% duty cycle of the boost solenoid to hit 10psi on 5psi springs. I will keep it like this for now, and see if boost by gear is needed with my drag radials in 1st and 2nd, if it holds all 10psi down low, then I can throw some 10psi springs and turn up the boost later on once all the little bugs are worked out.
    Injector duty cycle is only at 40%, so tons of room there.
    750iL Work Log
  9. #259
    Aug 2012
    CT
    Twin turbo LS E36 M3
    What frequency are you running the solenoid? On a 8psi spring, i got an easy 21 pounds.
    Possible boost leak?
    Do you make 5psi with the solenoid off? where is your source for the solenoid?
  10. #260
    DUDMD's Avatar
    Aug 2009
    Kent, WA
    95-540i/6 98-750iL
    Not sure on frequency, would have to check. MaxxECU has preset settings for the MAC solenoid.
    I'm at about 4.5psi on 0 duty cycle.
    It also matters on how you have the wastegates plumbed, I can re-plumb it and use the top ports to run a little more boost.
    Current setup is compressor housing to solenoid inlet, solenoid outlet into a tee, tee outputs to each bottom port of waste gates.
    I'll do a boost pressure leak check when I'm re-configuring the oil scavenging/separator.
    I found some really cool fitting that I can use on these magnesium valve covers without having to weld on the bungs.
    -12AN vented/baffled fittings with no welding required.
    I even bought a few more of these fittings to run on my SL65 AMG, as that factory PCV system is a POS. I'll be blocking off the factory PCV system on that car completely, then use a speedfactory low profile catch can with a -12an breather hose from each valve cover. Should work much better than stock.
    Quote Originally Posted by dburt86 View Post
    750iL Work Log
  11. #261
    Aug 2012
    CT
  12. #262
    Sep 2009
    Syracuse, NY
    95 M3, 08 535xiT
    Where did you find those vent fittings, they look interesting.
    95 Hellrot...filling the void after a 5 year hiatus
