Sent you a PM
Also sent you a pm
Sent from my SM-G960U1 using Tapatalk
PM'd
Sent you a PM?
K i got into the forum. Where do i pm you at?
replied
so if I decided to do some kind of m50tu/m52/m54 hybrid...this is the hot setup i hear?
Got one of these ecu’s about over a month ago just haven’t had the time to leave a comment. Install flawless, car fired right up! Great product! You know what your doing and I’m very happy with the results of the cars performance. Can’t wait to buy another car and get another ecu/chip from you thanks again!
P.s the best part about is that my emissions here in California are no longer a problem
Bought this ECU tune from you a few years ago... can't remember exactly when... 2015? Ran great for many years but recently it started acting strange. High cold idle, over 2,000 rpms, that took a long time to settle down. Drop and rise... drop and rise... drop and rise. Then when it does lower idle at about 700 rpms, it runs slightly rough for about 2 minutes and then will smooth out for about 30 secs... then rough again for 2 minutes. Very strange behavior. I swapped the stock DME back in and it runs normal again. Cold idle about 1600 rpms, settles at about 630 rpms and smooth.
Any thoughts on this? I haven't opened it up but willing to stick my nose in it.
Lime Rock Park... the most fun you can have in a mile and a half.
Sorry if you mentioned this before... I would have PM'd you but the system wont let being a new member. Will this work on a 2003 330ci? Tired of chasing a cat problem when I already have two new cats and 4 new o2 sensors...
Can you flash software for forced induction?
1989 535i - sold
1999 M3 Tiag/Dove - sold
Hi, I’m new to forum, I’m searching someone who can program ecu for my e30, with m54b30 engine swap. DME MS43
Thanks in advance
I got more
so this would be 100% plug and play with a full m52b28 harness and adapter to an e30? I would not need a new key and transmitter? would have PM'd but new on the form
Im interested in buy one. Could you email me at jrshrrchr@gmail.com? Im too new to PM. Thanks in advance!
