MS41.2 racing DME ECU for your 328i or M3
Tune is official BMW software used on the testing track on 96-99 M3. This ecu will also work great on your 328i M52, but perfect when doing engine swap into E30. This DME also can be used to pass emissions test(my special coding). Update January 2015: I now improved my coding to make the DME fully adaptive, this means nothing is deleted, this means that you can remove these sensors from the car and DME will adapt itself and not throw a check engine light, DME will adapt itself and be fully emissions compliant, all monitors are permanently set to pass.
DME features:
1. No EWS. Works with your existing module or without the module, so no EWS drama.
2. No secondary air pump system(pump,valve,solenoid,relay) you can remove all of these
3. No post catalyst 02 sensors, you can leave them there or take them out
4. No need to have catalytic converters, no muffler flap valve
5. No fuel tank pressure sensor, no spare tire tank vent valve, you can leave both there or remove them. This ecu uses only the fuel tank valve near the front strut tower for tank venting like obd1 bmw does.
6. Works for manual or automatic transmissions. trans ecu works fine with it. AC works. Cruise control works.
7. Full OBD2 diagnostics supported, it will even pass emissions, all readiness monitors are permanently set to pass.
8. 7200 rev limit, no speed limiter, maps are for 91 octane or higher.
9. No core charge, keep your own dme for backup
Price is $380 shipped
I have paypal, PM me if interested.
