Results 1 to 16 of 16
Thread: E30 4x100 to 5x130 adapters: Any good?
    Gulfport, MS
    1991 325ic
    Hi all,
    Today, looking for something totally different, I came across these adapters. Check them out:
    Here:
    http://www.r3vlimited.com/board/showthread.php?t=148958
    and here:
    http://www.8380labs.com/products/42-...acers-adapters
    For all of us E30 owners, it looks like a much cheaper, faster, and easier solution than a full 5-lug conversion, and will allow us to really expand our horizons while searching for wheels (I am not personally looking for new wheels, but some of you might be)
    Have any of you tried them?
    Aloha!
    Luciano
    Glacier blue metallic 1991 BMW 325ic
    honolulu
    E28M5 325es '79R65 Z32TT
    Quote Originally Posted by Luciano36
    Hi all,
    Here:
    and here:
    Aloha!
    Luciano
    No.
    Don't.
    Build a five lug swap, or find a set of 4x100 you like.
    imagine the damage that Honolulu potholes do to your car's OEM suspension, wheel bearings, hubs, etc. Imagine the millions of dollars and engineering PHD's that developed said suspension.
    Imagine Cletus with a CNC machine making those adapters...
    -ken
    DD: 1986 Cosmosblau 528e Dinan Chip, BBS RS05, 3.46, H&R over Bilsteins
    Mar 2001
    STR, MUC, LHR
    I love turbos!
    You're gonna put Porsche rims on your car?
    honolulu
    Quote Originally Posted by The Beastmaster
    Haha, I was pretty sure that was a typo. What are common Porsche offsets?
    -ken
    Mar 2001
    STR, MUC, LHR
    I love turbos!
    Quote Originally Posted by swerved300 View Post
    -ken
    Later ones from 89+ are high, in the 50s.
    Gulfport, MS
    1991 325ic
    Not looking for wheels myself right now. I just wanted to know whether these adapters are good or not, just in case I want to get new wheels in the future. I guess it's a "no"?
    And I meant 120! (I think) :P
    honolulu, hawaii, usa
    Euro Cars
    I have had porsche turbo twist on a new beetle, been using the adapters on the car for about 6 years with no issues. Granted a beetle is a lot different from a E30
    honolulu
    You'll end up spending close to the same amount to run adapters, and then you've got to run higher offset wheels, which means less lip, which means less asthetics; so what's the point really?
    I've looked for a while into any option I could think of.
    Nothing really works and actually gives you a good look except M3/318ti or e30M3 swaps. I've postulated you could use a few bits and pieces to make regular E36 spindles work, but it'll require a welder and some interesting geometry.
    If you're game- grab an e36 control arm and spindle from the junkyard and we can attack it together.
    -ken
    Gulfport, MS
    1991 325ic
    I don't know men, lots of E30 enthusiast seem to be buying them (the ones selling on r3vlimted) with no regrets.
    Lots of people these days do the swap just for the much broader option of wheels. I mean, if you're gonna do the swap JUST to use "cooler" wheels, don't you think the adapter is worth a try?
    Now if you're doing the swap to improve performance (brakes, etc), that's another story. I read threads on 5-lug full swaps with final budgets from $500 to $2000...
    Obviously, I have no experience in this matter, just debating (since I won't change my 14" basketweaves for anything...well, maybe for a good set of 15" Euroweaves)
    Jul 2010
    Honolulu, Hawaii
    98 E36M V8
    cool post.
    Luciano, i sent you a PM.
    May 2009
    Felgen Man's TeePee
    '90 E30
    to address some of the concerns that have been mentioned:
    i'll start by saying i'm an e30 driver myself, so i'm familiar with all the options available and how they work. OEM 5-lug style 5's are the most popular example of a wide range stock BMW (and other manufacturers') wheels that people like to run on 4-lug e30s.
    as i see it, there are several factors that must be taken into account when considering a modification like running 5-lug wheels on a 4-lug car:
    1) what are the available options?
    - full 5-lug suspension swap, redrill or adapters
    2) are you planning on driving the car on the track or the street?
    - i would not recommend adapters or a redrill for track applications
    3) what is your budget?
    - if we're talking about running a set of wheels for purely aesthetic purposes on a street car, only two of these options make sense from a budget/effort standpoint, and that would be a redrill or adapters.
    4) which option will fit the best?
    - let's say you were hell bent on a 5-lug swap. unless you're planning on purchasing a $1,500+ e30 m3 setup, a hacked together e36/z3/whatever setup is going to totally bugger the geometry (especially the front castor) those german engineers worked so hard to perfect. an e36/etc 5-lug swap also widens the track significantly, so your 5-lug wheels now bolt up directly, but fit the same way as they would with $400 adapters - except you spent way more money and effort to get there.
    - fill and drill will allow you to retain the stock offsets, but you'll most likely end up needing to buy spacers to get the wheels to sit properly in
    the fenders - there's another $150+ on top of the $300+ you spent on the redrill...if you can find a place who will touch that project.
    - we've sold quite a few sets of 18mm 4x100 > 5x120 adapters to e30 guys running style 5s and other 5-lug wheels - there are a bunch of pics
    and reviews in our thread on r3v...people have been really receptive to them and are realizing the degree to which this 4-to-5-lug design has
    opened up their wheel options.
    http://www.r3vlimited.com/board/show...6&postcount=98
    http://www.r3vlimited.com/board/show...&postcount=124
    http://www.r3vlimited.com/board/show...&postcount=174
    http://www.r3vlimited.com/board/show...&postcount=178
    http://www.r3vlimited.com/board/show...&postcount=185
    5) which option is the safest?
    - if you've ever seen a 4x100 redrilled style 5 wheel, you'll know that to do that they must machine into the centerbore of the wheels. i personally
    wouldn't want to run those on my car, and it's the same reason many machinists will refuse to do the work. i know there are people out there
    who have run redrilled wheels safely, but if there's a price-competitive option that's more readily available and less of a safety gamble, i'd
    go that route, personally.
    - if you take a minute to look through the pics in our ad on r3v and on the 42 draft website, it should become pretty obvious that these adapters
    weren't machined by cletus with a lathe. a considerable amount of time was put into the research and development of this product line, and the
    result is a 4-to-5 lug adapter design that is revolutionary. i've been using adapters in some form or another for about 8 years now, and these are
    the best i've ever seen.
    - from the modular hubcentric rings, to the use of studs (which makes installs much easier) and the design of the kidney-shaped adapter plate,
    which means no moving parts (compared to all other 4-to-5-lug adapter designs) - these are by far the best designed/built and safest adapters
    on the market, and the best choice if you want to quickly/easily/cheaply/safely run 5-lug wheels on your 4-lug car.
    let me know if you have any questions, thanks.
    Gulfport, MS
    1991 325ic
    Thanks so much for the info, and well put. As I implied before, I have no experience with adapters, or wheels, or 5-lug conversions. I am just an E30 enthusiast and an avid reader that sometimes find interesting stuff that might help me and others to make future decisions, and I just post and ask about it to the people that are actually much more knowledgeable than I am on the matter. Then the debate begins, which is how is supposed to go
    Aloha!
    Luciano
    May 2009
    Felgen Man's TeePee
    '90 E30
    surely, glad to offer some help.
    Jan 2002
    Aventura
    87 325ic
    Lucho, I have a set of RS224's in Los Angeles, they are 15x6.5 et45 and 5x114.
    They'll come with adaptors, no redrilling and perfect fit.
    http://store.42draftdesigns.com/VWAu...Set_p_445.html
    or cheaper version ... http://wheeladapters.us/4x100mm-3-94...-00-Thick.html
    Gulfport, MS
    1991 325ic
    Aloha Frank, those are nice wheels and cheap (but good looking) adapters! I am actually not on the market for wheels yet, but I'll let you know as soon as I decide to go for it!
    Nov 2016
    Los Angeles, CA, USA
    1987 BMW 325e
    Hey guys,
    Ive spent the last couple of years doing my e30 homework and I've finally got one. I would like a second opinion on getting adapters for the 5-lug 525i 17in. rims. Do they rub? What problems will I (do you think i'll) have?
