Results 1 to 8 of 8
Thread: Turn Signal Relay Location
    mcoupemindy's Avatar
    mcoupemindy is offline Senior Member BMW CCA Member
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Can someone help me out with the location of the turn signal relay?
    This gem just stopped working the other day and I doubt the local authorities will agree that my use of hand signals is sufficient.
    Kansas City, Missouri
    89 750iL | 91 325iX
    Thought it was under the drivers side dash.
    Could be wrong though
    If it is stretch before trying to get it
    Princeton New Jersey
    z3 m coupe
    Here you go:
    http://www.bmwtechinfo.com/etm/data/e36_7/e36z3_99.pdf
    Its gonna be under the turn/hazard lights
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    The usual cause of no turn signals is a bad / sticky hazard switch. Hazards and turn use the same flasher, so if you can get some action out of one or the other, the flasher is good.
    /.randy
    Supporting Vendor
    Jan 2005
    Haymarket, VA
    '99 M Coupe
    Nothing out of anything. Heard a fizzle under the dash when it gave out so my gut says the relay just gave up. Of course I'll check the fuses first.
    Feb 2010
    SoCal
    Z3, M5
    Quote Originally Posted by drdre0728 View Post
    Here you go:
    Awsome link~ Thanks for sharing!
    Jan 2020
    Atlanta ga
    BMW 540i
    I need to know we're the blinker relay is for my 2001 BMW 540i
    My flashers work but no turn signals
    Dec 2007
    Great Dismal Swamp
    Quote Originally Posted by Jenny b View Post
    It's all computer controlled.
    Wrong sub-forum. You have an E39. But no matter, you'll likely get more help here. The short answer is there is no flasher relay. It's all computer controlled. If you have a scanner, look into the LCM module and see if it's seeing the turn signal switch commands.
    /.randy
