Can someone help me out with the location of the turn signal relay?
This gem just stopped working the other day and I doubt the local authorities will agree that my use of hand signals is sufficient.
Here you go:
http://www.bmwtechinfo.com/etm/data/e36_7/e36z3_99.pdf
Its gonna be under the turn/hazard lights
The usual cause of no turn signals is a bad / sticky hazard switch. Hazards and turn use the same flasher, so if you can get some action out of one or the other, the flasher is good.
/.randy
I need to know we're the blinker relay is for my 2001 BMW 540i
My flashers work but no turn signals
It's all computer controlled.
Wrong sub-forum. You have an E39. But no matter, you'll likely get more help here. The short answer is there is no flasher relay. It's all computer controlled. If you have a scanner, look into the LCM module and see if it's seeing the turn signal switch commands.
/.randy
