Hi there, I have a question, what do I need to code when I replace the DME from a e46 for another used one from another e46, both are the same year and the same motor...
Can I just only need to align the EWS with the new (used) DME?
thanks,
E39, 523i, 1999, M52TUB30, 5 SPEED MANUAL, UUC SHORT SHIFTER, EURO SPECS, KONI YELLOWS, OEM SPORTS SPRINGS, OEM SPORTS SEATS, ALCANTARA HEADLINER AND /A/B/C PILLARS, OEM M-TECHNIC AERODYNAMIC, OEM M5 FRONT GRILLS, OEM M5 REAR FOLDING MIRRORS, OEM M5 REAR SWAYBAR, OEM M-TECHNIC II FRONT SWAYBAR, REMUS DUAL TIP MUFFLER, TITANSILVER, BIXENON, M PARALLEL SPOKE 66 STAGGERED, OEM M-AUDIO SYSTEM, NAV SCREEN 16:9, INTRAVEE II iPOD INTERFACE, OEM TCM WITH BLUETOOTH, Y RESONATOR DELETE, INTAKE HORN DELETE, CDV DELETE, CHARCOAL TITANIUM BRUSHED TRIM, FAN CLUTCH DELETE, ELECTRIC FAN, 3.15LSD DIFFERENTIAL, ESS TS2+ SUPERCHARGER, AQUAMIST METHANOL + WATER INJECTION
PANAMA, CIUDAD DE PANAMA
No it is not feasible with the e46 BMW coding tools.
The EWS 3.3 in E46 can only connect one time to a DME.
You can replace just the DME but you will need an Autologic or GT1 to align the EWS with the new DME.
Performance Tuning and EWS Delete for MSS52/MSS54/MSS54HP/MS41/MS42/MS43/ME7.2/M5.2
Virgnize DME service available to unlock DME to sync to another vehicle on EWS3 vehicles 98+. M5.2.1, M7.2, MS42, MS43, MS45, ME9.2 and more.
Easiest way to contact me is to send me a message on my facebook page "DUDMD Tuning"
do I need to recode my DME using the WinKFP and put there the VIN of the car?
you yourself cannot install a used DME into another car. you will have to send the used dme to a shop that refurbishes them...even if its good, it needs to be wiped out to a virgin state. That requries special software and hardware thats just not downloaded for free like what you might have. only way you could put a used dme in your car is if you have the matching EWS and KEYS for the other donor car.
clint
thanks, and you guys are right!!!!! thank you very very very much!!!
Next step, I will put now the EWS (the same of the DMW I want to recode)...
cheers
This a big problem for independent mechanics and BMW owners.
BMW DMEs used to be non-interchangeable to other cars because BMW cars have a rolling code, and VIN # verification on their modules. A lot of indy mechanics ended up giving up the job to the dealer.
I understand how complicated BMW made these ECUs since I rebuild them.
The only other option people have is to get a matching set (Key, EWS, DME) from a junked car, because the matching set will have the same VIN and EWS Rolling Code.
Yea, that was finally I do, put the ews and the key of the donor car, know the car start perfectly ....Originally Posted by S ECU Repair
i just soldered the eprom from the dead DME to new same bosch number DME and car runs fine... Shouldnt the DME need to be coded for my cars VIN? How to do it???
I guess when you swapped the EPROM AM49fF00, all the data is in the new DME. No need to do any work.
The chassis number and ISN are in the flash chip (although the VIN is encrypted)
1)Swapping the flash chip between them,
2)swapping the DME, EWS and keychips will work, or the final option is
3) a used DME, the flash has then to be read fully (I think it has to be unsoldered, because I can't think of anything that reads the complete memory) and it can be programmed with the matching VIN and a clear ID which is essentially what you'd get if you ordered a new DME from BMW.
On the third option, you'd then need to sync your existing EWS to the (what appears brand new..) DME.
So the easiest is the chip swap, next up is swapping DME/EWS but you wouldn't be able to order any replacement keys, as they would be set up for the EWS you've binned earlier) and the last option is there for those times when you take out the DME and somehow destroy it.
MS41 is E36 328's, that can be synced to EWS as often as you like; MS42 (E46 and the twin vanos M52TU's) and MS43 (M54 engines) can't be resynced, so chip swaps or professional help.
In the event you've done one of the above, and it still isn't working, or you haven't touched anything, but after a low battery you are getting DME/EWS sync errors, then try the "start value synchronisation" in INPA.
This doesn't "marry" the ECU->EWS like you could in E36s, but it resets the rolling code tables as occasionally the DME or EWS can glitch and jump up a code by itself.
Giftschrank Projekt
S ecu repair.... Can't pm you so when you have enough posts pm me.
Hey I know This is old but anyone still watching? I'm trying to do the chip swap for a 00 323 e46 dme and I'm trying to find some kind of guide
thanks
E46 with ecu Bosch M43 and Siemens MS42, MS43 just swap the flashrom.
Which chip?
It's the 29F400, the other one would be known as the eeprom and that's where stuff like adaptation and fault codes are stored.
Just swapping the 29f is enough to reuse a different ECU with the same part number.
Giftschrank Projekt
Yea, I think so, but it might take a bit more work.
Giftschrank Projekt
